instructable for streaming from an Android phone? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 05-04-2014, 08:02 AM - Thread Starter
carl333's Avatar
Can someone kindly lend a hand on helping me learn how to stream music from my android phone to my 2113, wired is fine if that's easier. tks
After some thinking, will this work? Use the 3.5 mm out port from my android and use a RCA 3.5mm Stereo F to 2 RCA M Cable Adapter and plug it into the 2 RCA ports on the front of the receiver. Will that work?
See cable below.
http://compare.ebay.ca/like/271276118420?var=lv&ltyp=AllFixedPriceItemTypes&var=sbar&_lwgsi=y&cbt=y&lpid=33&item_id=271276118420
Montreal
carl333 is offline
post #2 of 13 Old 05-04-2014, 09:00 AM
jdsmoothie's Avatar
Quoted: 12216 Post(s)
Liked: 5562
There are a number of Android apps that can be used to include BubbleUPnP and Skifta.
jdsmoothie is offline
post #3 of 13 Old 05-04-2014, 10:45 AM - Thread Starter
carl333's Avatar
TY JDS. Your such a great source for info.
Once I DL the apps, will it allow me to stream live music from say a source like Pandora on my phone to my smart TV or will the app. only permit me to listen to music already stored in my smart phone?
ok, I DL Skifta and works absolutely great and friendly but it only looks for music, video's... stored on my phone. Am I asking for too much?
Montreal
carl333 is offline
post #4 of 13 Old 05-04-2014, 11:21 AM
jdsmoothie's Avatar
Liked: 5562
I am only familiar with streaming audio from music on the phone although not sure why you would need to stream Pandora as it is already a source on the 2113CI as well as likely on your TV as well.
post #5 of 13 Old 05-04-2014, 12:18 PM - Thread Starter
carl333's Avatar
Pandora doesn't work from my 2113. It says "Pandora is not available in this country" I used to get it fore several months and now I can not. From canada. This is why I am trying to stream live music from my android phone to my receiver. I realize this is a dedicated Denon forum and we appear to be moving away from this, sorry. I was only looking for advice on if my possible solution by hard wiring my android phone audio out jack to an RCA right and left adapter to the front panel would work.
Montreal
carl333 is offline
post #6 of 13 Old 05-04-2014, 12:39 PM
afrogt's Avatar
Quoted: 1058 Post(s)
Liked: 761
hard wiring your phone thru the headphone jack to the rca inputs on the Denon 2113 will definitely work. I do that all the time with my android phone and denon 591.
if you have a cable just give it a try...
Afro GT
afrogt is online now
post #7 of 13 Old 05-04-2014, 02:11 PM
jdsmoothie's Avatar
Liked: 5562
This is why it helps to put your Location in your profile so it displays as such and assistance can be more to point as you never indicated you were outside of the USA. Also this is not a dedicated Denon thread as you entitled it "streaming from an android phone" so it's dedicated to that. smile.gif
post #8 of 13 Old 05-05-2014, 10:35 AM - Thread Starter
carl333's Avatar
Tks, I will purchase a cable and test it out.
Montreal
carl333 is offline
post #9 of 13 Old 05-05-2014, 10:49 AM - Thread Starter
carl333's Avatar
Tks JD. I accepted the fact that Pandora was not available to me through the 2113 any longer. Could the loss of it been caused by a firmware update?
That's why I was trying to find another way of making music available on my phone to go to the 2113 via hardwire. I tried the 2 suggested programs that you suggested but i haven't had success in getting this to work as yet. I'll keep trying.
Trying to change my signature to add my city but doesn't seem to work.
Montreal
carl333 is offline
post #10 of 13 Old 05-05-2014, 02:21 PM
jdsmoothie's Avatar
Liked: 5562
AFAIK, Pandora is not available in Canada on any brand of AVR.
post #11 of 13 Old 05-05-2014, 07:47 PM - Thread Starter
carl333's Avatar
Will it permit music from my phone to zone 2 as well? tks
Montreal
carl333 is offline
post #12 of 13 Old 05-05-2014, 08:44 PM
afrogt's Avatar
Liked: 761
Yes it will since it's a analog connection.
Afro GT
post #13 of 13 Old 05-06-2014, 05:02 AM - Thread Starter
carl333's Avatar
Tks AFROGT
Montreal
carl333 is offline
