which receiver for my system - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 05-07-2014, 04:21 AM - Thread Starter
dudumagic's Avatar
1 ProCenter 2000
4 ProMonitor 1000's
1 SVS  SB-2000
Thank you.
dudumagic is offline
post #2 of 11 Old 05-07-2014, 07:56 AM
GIEGAR's Avatar
Quoted: 707 Post(s)
Liked: 1221
1 Denon AVR-X2000
You're welcome.
GIEGAR is offline
post #3 of 11 Old 05-07-2014, 08:14 AM - Thread Starter
dudumagic's Avatar
Originally Posted by GIEGAR View Post
1 Denon AVR-X2000
You're welcome.
Are you sure ?
Some friend tell me this no take this system up ...  the avr-x2000 only 95w output .
post #4 of 11 Old 05-07-2014, 08:15 AM
Kimeran's Avatar
Quoted: 14 Post(s)
Liked: 123
What is more important to you? Amplifier power or room correction?
Your speakers a decently sensitive at 91db at 8ohm load. So a good option would be the Anthem MRX AVR as they have probably the best room correction you can get. Otherwise I would go with a Pioneer if I needed the higher amount of power from the Class D amps. If you want more of a compromise between the two of these I would look more at the Denon. The Yamahas are nice too but I really don't like YPAO personally.
Trying to enjoy the simple things in life.
Steam: madbrayniak
Kimeran is offline
post #5 of 11 Old 05-07-2014, 09:10 AM - Thread Starter
dudumagic's Avatar
this my living room
post #6 of 11 Old 05-08-2014, 06:16 AM - Thread Starter
dudumagic's Avatar
help
post #7 of 11 Old 05-08-2014, 08:15 AM
smurraybhm's Avatar
Quoted: 1487 Post(s)
Liked: 1780
I have a similar but bigger open space on the first floor of our house - we like the big space for entertaining. We can have 50 people in that area still have plenty of room. That keeps the wife happy since she likes to entertain occasionally. I use def techs (LR - 1000s, ProCenter 2000, and 800s for back surrounds along with Outlaw 10 inch sub) in that space with a 46" Sony XBR. I am just using a Pioneer 1220 for that system - my main HT is downstairs. I do have a Pio Elite SC-07 in a box that was replaced with a Denon 4311 in the HT room, the 1220 has worked well enough that I haven't been motivated to go through moving the Elite upstairs - for over two years now.
GIEGAR's recommendation of the Denon would work as well - personally I think you can't go wrong with a Denon, Pioneer, Marantz or Yamaha. About $600 to $750 should cover it unless you check out A4L and go refurbished to save/buy more or find a good close-out deal. A room like that is never going to equal one that is more typically used for HT, too big and too open and I doubt your planning on building a wall to enclose the right side of the room any time soon smile.gif I like my Def Techs, but they have their limits as well. Given that I wouldn't get too crazy with the receiver and your speakers don't require a great deal of power as noted above. Just buy the receiver that has the features you need (Airplay, etc.) that fits your budget. I would stay away from Onkyo given the QA issues, I owned 2 different ones in the past, one of which suffered the too common HDMI board failure.
RIP Cricket - my pug and little buddy Jan. 10, 2017
Panasonic 60VT60 (cal by DNice)
Ascend's with RAAL, Love my PSA v1800 and a 7.2.4 speaker config, Oppo 203 w/ 2500+ blu-rays and growing. Yes I still have HD-DVDs too.
smurraybhm is online now
post #8 of 11 Old 05-08-2014, 08:28 AM
afrogt's Avatar
Quoted: 1061 Post(s)
Liked: 764
the Denon x2000 can be had for $399 from Amazon or Crutchfield so one is getting bang for your buck.
http://www.crutchfield.com/p_033AVX2000/Denon-AVR-X2000.html?tp=179
Afro GT
afrogt is offline
post #9 of 11 Old 05-08-2014, 09:16 AM - Thread Starter
dudumagic's Avatar
so Denon x2000 ( or 3000 ) is enough  for this system ?
post #10 of 11 Old 05-08-2014, 11:48 AM
smurraybhm's Avatar
Liked: 1780
Yes to the thread starters question above. If the 3000 fits your budget go for it or the 2000. Denon has served me well for nearly 3 years now.
post #11 of 11 Old 05-08-2014, 02:21 PM - Thread Starter
dudumagic's Avatar
ok , i bought today denon x3000 .
