The 'Official' 2014 Denon "S Series" / "X Series" AVR Model Owner's Thread & FAQ - Page 22 - AVS Forum | Home Theater Discussions And Reviews
 296Likes
post #631 of 4753 Old 06-26-2014, 12:18 PM
Selden Ball's Avatar
Quoted: 3216 Post(s)
Liked: 1579
Originally Posted by laggerific View Post
Ah, great info. I'm curious, though, is there is an advantage of upscaling on the AVR side vs. letting the TV handle it?
It depends on the relative quality of their scalers. My understanding is that some of the inexpensive 4K TVs have very rudimentary scalers which just double the pixels instead of interpolating.
Selden
Selden Ball is offline
post #632 of 4753 Old 06-26-2014, 02:17 PM
jdsmoothie's Avatar
Quoted: 12955 Post(s)
Liked: 5980
Depends on which can do it better or if no difference, just turn it off in the AVR to reduce any video lag.
jdsmoothie is offline
post #633 of 4753 Old 06-26-2014, 04:56 PM
mogorf's Avatar
Quoted: 1099 Post(s)
Liked: 672
Also depends on how the "enduser" can detect which is better. Any tips for the "enduser" on what to look for? That would be great help, indeed.
mogorf is offline
post #634 of 4753 Old 06-27-2014, 01:03 AM
DoctorM's Avatar
Quoted: 665 Post(s)
Liked: 202
The 4-ohm thing is a tack on, but done poorly?
Protection Mode: If the AVR shuts off in protection mode and the power indicator light flashes red, it generally means the following based on the frequency of flashes:
  • Every 1/2 sec = speaker wire from one post touching another post (most common); driving 4Ω speakers too loud (ie. >-10db); or amp failure
Audioholics.com (http://www.audioholics.com/av-receiv...ries-receivers)
And remember that Eco mode we mentioned? The folks at Denon smartly tied that in with 4 ohm certification. No, the S700W won’t deliver huge output into low impedance loads. However, the current limiting aspect of the Eco mode (a requirement for the European market) was something that engineers found they could retool slightly to allow folks to safely drive a 4 ohm load without excessive heat buildup. Just realize that once you flip the switch to low impedance mode, you also significantly reduce available output power to your speaker system.
Honestly, most AVR are considered to be able to handle 4 ohm if you don't turn the volume up too loud even if the manufacturer doesn't support it. This sounds like the same thing or worse. Anyone have a chance to test drive this with 4-ohm speakers yet?
DoctorM is offline
post #635 of 4753 Old 06-27-2014, 03:58 AM
Oppo Beta Group
RichB's Avatar
Quoted: 964 Post(s)
Liked: 636
Originally Posted by DoctorM View Post
The 4-ohm thing is a tack on, but done poorly?[/LIST]Audioholics.com (http://www.audioholics.com/av-receiv...ries-receivers)
ECO mode is required?
Is that a current limiter, low power idle (low bias), a nanny to tell you it is too loud?
- Rich
Oppo UPD-203 | Sonica DAC | BDP-105D | HA-1 | PM-1 | Emotiva XMC-1 | ATI Signature AT6002 x 2 + AT6006 | Revel Salon2s, Voice2, Studio2s | Velodyne HGS-15 | LG B6 | Lumagen 2020
RichB is offline
post #636 of 4753 Old 06-27-2014, 05:25 PM
hackztor's Avatar
Nvidia says useful for movies only not gaming. It drops the color down from 4:4:4 to 4:2:0 (same as bluray)
Hmm...does that mean I can also get 1080p 3D @ 60Hz over HDMI? That would be excellent...
Still, great news...now I need to figure out how to get it to detect the 4k abilities of the AVR/UHD on the backend. Does the Denon pass through the capabilities of the display to the source input? So, is it a Denon issue at this point?
hackztor is offline
post #637 of 4753 Old 06-27-2014, 06:35 PM
sdurani's Avatar
Quoted: 4668 Post(s)
Liked: 3071
Originally Posted by sdurani View Post
Speaking of heights, I'm hoping there will be a little more flexibility (hopefully a couple more locations) than the three you mentioned.
Guess it was worth hoping, since it looks like those couple more overhead locations will be a reality eventually.
From the Atmos FAQ:
"If you have the space and budget, you can build a Dolby Atmos system with as many as 24 speakers on the floor and 10 overhead speakers."
http://blog.dolby.com/2014/06/dolby-...ions-answered/
Sanjay
sdurani is offline
post #638 of 4753 Old 06-27-2014, 06:51 PM
ahmedreda's Avatar
Quoted: 314 Post(s)
Liked: 252
Do you know if Top Front and Top Middle can be used for 7.1.4 or does it have to be Top Front and Top Rear? It seems to me the Top Middle might be a better choice since the back is covered by the surrounds.
More clarification ....
1) Audyssey can tell the distance and level of any speaker in the system from the main listening position.
2) Ceiling speakers point straight down and Dolby as a spec/recommendation on the angle these speakers need to be placed relative to the main listening position (see diagram on the right below).
3) D&M will use the same object method as any other brand - Dolby has a specification - they would not allow any manufacturer to have a different method of decoding/playback.
In both diagrams below, only the "top" speakers are used with Atmos in addition to the standard 5.1. or 7.1 (rear surround) setup. The Height speakers are only shown to reference their position in relation to the "top" speakers.
My home theater
Speakers: 3 JTR 212HTR (LCR), 2 Jtr Single 8LP (S), 2 JTR Triple 12LF (SB)) , 4 Volt 10LX (Atmos)
Subwoofers: 10 Sealed UXL-18, 5 Crowson Shadow 8 transducers, 3 Buttkicker LFE
Display: JVC RS400
ahmedreda is online now
post #639 of 4753 Old 06-27-2014, 07:07 PM
kikkenit2's Avatar
Quoted: 822 Post(s)
Liked: 303
The pioneer rep claims no 2014 denon, pioneer or yamaha receivers have hdcp 2.2.
Pioneer SC LX88 - 9.2 ch, Dolby Amos, HDMI 2.0
"Regarding HDCP 2.2, none of our AVR's support it this year. Pioneer (As well as Denon and Yamaha) opted for full bandwidth HDMI 2.0 (18gbps) so that we can support 4:4:4 content as well as high dynamic range and expanded color gamut signals which require more that 10.2gbps. There currently is not a single chip solution that offers both 18gbps and HDCP 2.2. Onkyo decided to go with HDCP 2.2 by using a different brand HDMI repeater, however there HDMI 2.0 solution only offers 10.2gbps of bandwidth (Same has HDMI 1.4)."
iscariot likes this.
kikkenit2 is offline
post #640 of 4753 Old 06-27-2014, 07:50 PM
Schwa's Avatar
Quoted: 1050 Post(s)
Liked: 1116
Asked and answered. Plus, it's looking like "top middle" might be the only supported x.x.2 configuration.
Schwa is offline
post #641 of 4753 Old 06-27-2014, 11:49 PM
esappy's Avatar
Quoted: 165 Post(s)
Liked: 94
Question Question about x5200/7200 multi-zone capabilities
I can't remember if this has already been asked but do we know what the multi-zone capabilities of the two top models coming soon will be. Particularly dealing with zone 3 and possibly being able to get analog output from another HDMI source or will it stay limited to zone 2 like the x4000/4100? I have the potential to use at least 3 separate zones maybe even 4 if the x5200 or x7200 would go that far but I would like to know what limitations there will be and I didn't really see anything in post 3 that covers this (unless I missed it). Thanks.
"One of the penalties for refusing to participate in politics is that you end up being governed by your inferiors." - Plato
esappy is offline
post #642 of 4753 Old 06-28-2014, 01:42 AM
Dalumberjack's Avatar
Quoted: 75 Post(s)
Liked: 80
So I get the advantage of having hdmi 2.0, but the units can't accept a 4k feed from any future source that will require HDCP 2.2? I get keeping costs down by not having another chip in the unit, but you would think HDCP 2.2 and hdmi 2.0 go hand in hand....
and that's not something you can enable with a firmware update...
Drive Fast Take Chances
Speakers: Klipsch KLF 30's, Klipsch C-7, Klipsch RS-52
Sub's: 2 x HSU VTF 3.3's
Receiver: Denon X7200
Dalumberjack is offline
post #643 of 4753 Old 06-28-2014, 04:15 AM
FilmMixer's Avatar
Quoted: 1785 Post(s)
Liked: 2214
Originally Posted by kbarnes701 View Post
Roger Dressler pretty much booted FM out of the park on that one. FM knows a lot about the commercial side of Atmos but that isn't the same thing as the domestic side.
Care to revise that comment on how I was "booted out of the park" by Roger?
Again..... For the cheap seats....
Home Atmos offers no benefit for those with only 5.1, or even 7.1, setups.
At this time, "legacy" systems will get legacy payload playback.
While there are difference in the maximum number of objects and outputs in the consumer versions, the way in which objects will be encoded and rendered should create virtually no audible subjective difference.
Because of the vast size differences between almost any cinema and 99% of home theaters, the scale of the changes won't be detrimental.
Dolby spent plenty of time with the cinema professionals in developing the home iteration. Many of us were invited to see the system as it has been developed and the company was very open to feedback and comment along the way.... Since all of the current content came from the cinema side, I'm not quite sure why you think I wouldn't have any insight into what was coming home.
There are other things yet to be revealed about Home Atmos, and I am ultra excited about it.
They still have some really cool tricks up their sleeves that will be revealed in the coming months.
FilmMixer is online now
post #644 of 4753 Old 06-28-2014, 04:34 AM
jdsmoothie's Avatar
Liked: 5980
We don't yet have the full details on the 7200, but it looks like it will be losing the Zone 4 capability found on the 4520CI, but both the 5200 and 7200 will gain the same current Zone 2/3 capability as is on the X3000/X4000.
post #645 of 4753 Old 06-28-2014, 04:58 AM - Thread Starter
batpig's Avatar
Quoted: 3624 Post(s)
Liked: 3470
Better hurry FM, Sanjay and Keith already have severe whiplash from whipping the bandwagon around so fast, not sure if their necks can handle another high velocity u-turn
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #646 of 4753 Old 06-28-2014, 06:59 AM
rec head's Avatar
Quoted: 95 Post(s)
Liked: 76
Do these threads normally have 20+ pages before anybody has really heard the new units? I know there is some relevant info in this thread but should it be renamed to the "Denon 2014 speculation and ATMOS arguments" thread? I'm not joking. It is a lot to wade through and most of it is pretty irrelevant. I have enjoyed learning about object based audio though.
Dmanindfw, gcoupe and sikclown like this.
rec head is offline
post #647 of 4753 Old 06-28-2014, 07:25 AM
chi_guy50's Avatar
Quoted: 1394 Post(s)
Liked: 974
I, for one, am enjoying the discussion very much.
Like any published source, you can always skim through the items that hold no interest for you (even if that includes batpig's irreverent humor ).
esappy likes this.
chi_guy50 is offline
post #648 of 4753 Old 06-28-2014, 07:30 AM
Oppo Beta Group
RichB's Avatar
Quoted: 964 Post(s)
Liked: 636
Me too. It has been a hoot.
Originally Posted by batpig View Post
Yeah, we've gotten some updated info on how Atmos will be implemented at home in these Denons:
1. Atmos will provide ZERO benefit for traditional 5.1 or 7.1 setups. All of the fancy object based audio rendering will not be translated to these AVRs. Atmos processing will ONLY be available when using at least two height speakers.
2. There will be no additional info about angles, elevation, etc. Just standard calibration (distance and level) for each speaker and otherwise it's effectively still "channel" based. So the other benefit -- that it would "know" if your surrounds were at 110 degrees instead of 90 and thus render the positional object properly in the horizontal plane -- will not be realized in the home version at this point.
And the attached Atmos speaker placement diagram.
The HDMI 2.0 limitation might be a concern for those who want to move to 4K, a new AVR may be required if you want it to do the switching.
- Rich
RichB is offline
post #649 of 4753 Old 06-28-2014, 07:34 AM
Chise's Avatar
Quoted: 339 Post(s)
Liked: 133
I played around X-1100 and 2100 they both ran hot and shut down after 1 hour playing a movie they are making these receivers cheaper!!!!!
Chise is offline
post #650 of 4753 Old 06-28-2014, 08:15 AM
Mr. Wonderful's Avatar
Quoted: 74 Post(s)
Liked: 49
My thought is that by the time not having HDCP 2.2 becomes a concern, we're going to be a few years into these receivers' lives anyways.
Mr. Wonderful is online now
post #651 of 4753 Old 06-28-2014, 08:40 AM
upstate-avfan-da's Avatar
Quoted: 83 Post(s)
Liked: 41
Ok, been going back and forth in my head and need some nudging lol
I am really up in the air over which one to get to replace my AVR-591.
My budget is mainly in the S900 / X1100 range, but if I really can convince myself I may swing the X2100. I won't kid myself to think I can fit the X3100 in my budget lol.
My current set up probably does not warrant anything too fancy:
Samsung F9000 (2014 One Connect)
Polk 5.1 (Monitor II's + PSW505)
The main differences I see are: S900/X2100 vs X1100 - Audessey, HDMI inputs (5 rear vs 7 rear, latter all 2.0), bump in power.
I am leaning a little to the S900, will I really see a benefit in Audessey XT with Monitor II's in a 5.1 set up? Although on the other hand, I don't believe I need any help upscaling my 4K signals, Samsung has a really good upscaler in the F9000 w/ 2014 upgraded One Connect Box. I can probably get by with 2x HDMI 2.0 ports (we don't even have anything to take advantage of this yet lol, I can only see the new BD players requiring this for 4K BD discs? maybe in a yr or two?). All my devices will fit to 5 rear HDMI ports (PS3, PS4, NTV550, Chromecast, BD player, Skype cam - doesn't matter if this is in the AVR or to my TV).
I guess basically, is the Audessey enough to push me to go for the X1100/X2100? I don't care about 4k upscaling, 5 rear HDMI inputs seem sufficient - 2 being 2.0, or am I missing something else to consider? I should probably write the X2100 off, I think my wife may kill me for dropping another $700 (just built a new PC for about $1500, Samsung One Connect Box was another $400... I think she already wants to cause harm lol). Although I can stomach the $100 difference between X1100 / S900 if all things considered, the additional HDMI is worth it.
Bit by the upgrade bug, limited by the WAF
upstate-avfan-da is offline
post #652 of 4753 Old 06-28-2014, 08:55 AM
Keith Lashinski's Avatar
I hope this isn't true as i will be using my AV receiver for all normal operations.
Keith Lashinski is offline
post #653 of 4753 Old 06-28-2014, 09:13 AM
Chise's Avatar
Quoted: 339 Post(s)
Liked: 133
I was running it 60 and 65 percent volume.
Chise is offline
post #654 of 4753 Old 06-28-2014, 09:25 AM
esappy's Avatar
Quoted: 165 Post(s)
Liked: 94
Depending on who you ask, will get you different answers about Audyssey. Some will tell you that XT is a big step up from the basic MultEq. Some will say you will be hard pressed to hear the difference. And others flat out hate Audyssey and they will tell you to not waste your time. Me personally, I only have experience with the XT version in my older Denon AVR-3808ci, but to me in my space it makes a noticeable difference and for the better. Now I haven't had the time, patience, or money to do proper room treatments yet so that may negate some of the 'benefits' of Audyssey but my theater is still a work in progress.
Another big benefit of going with the X series is that extra year of manufacturers warranty. In this day and age of 'disposable electronics' I take all the warranties I can get.
esappy is offline
post #655 of 4753 Old 06-28-2014, 09:31 AM
Keenan's Avatar
Quoted: 2281 Post(s)
Liked: 2113
And you're absolutely sure all your speakers connections on the back of the unit were nice and clean with no stray strands? There's been many posts where the poster swears they are good but then goes back and double-checks very carefully and it turns out there were some problems with the connections. If those models take banana plugs I highly recommend using them. Be sure to check connections at the speaker end as well.
And the unit has adequate ventilation?
Keenan is offline
post #656 of 4753 Old 06-28-2014, 09:34 AM
esappy's Avatar
Quoted: 165 Post(s)
Liked: 94
Forgive me as I am mostly clueless with these capabilities, but does this mean that zones 2 & 3 will be able to use an HDMI source independently, or will zone 3 be limited to something 'less'. I understand the all zone stereo or whatever it's called will play the same HDMI source simultaneously to all 3 zones but I want to be able to playback audio from 3 separate HDMI sources to each of the 3 zones independently if I want to. Does that make sense? It's not a deal breaker, but something that would be nice (and beneficial) to me.
esappy is offline
post #657 of 4753 Old 06-28-2014, 09:38 AM
kokishin's Avatar
Quoted: 837 Post(s)
Liked: 518
What make/model speakers were they driving?
My signature:
Link: avsforum Members Atmos & Auro Configuration Spreadsheet
I'm just a caveman. Your modern world frightens and confuses me.
kokishin is offline
post #658 of 4753 Old 06-28-2014, 10:37 AM
jdsmoothie's Avatar
Liked: 5980
It means independent 2CH HDMI/optical/coax digital stereo to Zone 2 and the same minus the HDMI to Zone 3.
post #659 of 4753 Old 06-28-2014, 10:40 AM
jdsmoothie's Avatar
Liked: 5980
What does this mean? Played around? Did you bring both of them home to test? What ohm speakers and what is their sensitivity/efficiency rating? How much free space is around the AVR? Did they shut down with a slow or fast blinking red light? Without details, this post is incomplete.
post #660 of 4753 Old 06-28-2014, 10:43 AM
esappy's Avatar
Quoted: 165 Post(s)
Liked: 94
Ok. Got it now. Thanks JD.
esappy is offline
denon s500bt , X1100W , X2100W , x3100w , X4100W
