Replace Denon AVR-4810ci - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 05-24-2014, 06:01 PM - Thread Starter
fab68's Avatar
I have a Denon AVR 4810 in perfect working condition. My question is, one of my other Denon AVR has failed and I need to replace. If you had the opportunity to replace the Denon AVR 4810, what would you go after? I like the sound quality,3D or 4K is not important to me. I am using all B&W 600 speakers and two SVS subs on a 7.2 set up.
fab68 is offline
post #2 of 11 Old 05-24-2014, 07:05 PM
jdsmoothie's Avatar
Quoted: 12182 Post(s)
Liked: 5550
You'll likely want to replace it with an XT32 unit for better audio quality, so just depends on your budget as both the X4000 and the current flagship that replaced the 4810CI, the 4520CI both use XT32 as well as Audyssey Sub EQ HT (dual subs).
jdsmoothie is offline
post #3 of 11 Old 05-24-2014, 07:27 PM - Thread Starter
fab68's Avatar
Thanks jdsmoothie, I understand that the AVR 4520 does not have the transformers and sound quality as the AVR 4810? Could you give me your point of view? I am willing to spend up to $2,500.
fab68 is offline
post #4 of 11 Old 05-25-2014, 05:21 AM
jdsmoothie's Avatar
Liked: 5550
Actually the 4520CI would have better quality as it uses the much more advanced Audyssey MultEQ XT32 vs. only MultEQ XT on your 4810. It is also 150W vs. 140W on the 4810CI and is designed to power 4-ohm speakers to reference volume levels so would be comparable in power to the 4810CI.
post #5 of 11 Old 05-25-2014, 06:47 AM
commsysman's Avatar
Quoted: 974 Post(s)
Liked: 525
For best sound quality, I suggest that you go to a NAD T758 receiver, or a Cambridge 651R receiver.
IMO they will have better sound quality/less distortion driving those speakers.
The Denon power ratings are grossly overstated IMO, and do not reflect real power when driving real speakers systems,, which are far more demanding than the simple resistor load used on the test bench, and cause more distortion.
The NAD and Cambridge receivers are better designed when it comes to driving that type of speakers and still maintaining low distortion levels.
commsysman is offline
post #6 of 11 Old 05-25-2014, 07:01 AM - Thread Starter
fab68's Avatar
Thank you commsysman, I will look these two up…..Have you had the chance to listen to them?
fab68 is offline
post #7 of 11 Old 05-25-2014, 07:36 AM
commsysman's Avatar
Quoted: 974 Post(s)
Liked: 525
Yes I have.
A close friend of mine went from another receiver to the Cambridge 651R, and he couldn't believe how dramatic the improvement was.
You couldn't get the smile off of his face for a week.
The NAD is almost as good, but IMO the Cambridge is unquestionably the best-sounding, if you can afford it.
post #8 of 11 Old 05-25-2014, 07:44 AM
jdsmoothie's Avatar
Liked: 5550
Note too the 4520CI also features Audyssey Sub EQ HT which will independently set the level and delay of each of your SVS subs with independent volume control of each sub as well as opposed to the single volume control of the sub pre-outs on the 4810CI.
post #9 of 11 Old 05-25-2014, 04:39 PM
Lttrader's Avatar
Quoted: 13 Post(s)
Liked: 27
** Think the AVR is defective?  Reset the microprocessor 4-5 times.
JD your tagline quoted above says to reset the microprocessor. How is this accomplished, simply by unplugging for a few minutes?  Thanks.
Lttrader is offline
post #10 of 11 Old 05-26-2014, 05:08 AM
jdsmoothie's Avatar
Liked: 5550
Unplugging the power cord from the AVR for 10 minutes would result in a "soft reset" which will resolve some issues without changing any settings while resetting the microprocessor is a "hard reset" procedure listed in the Owner's manual (Troubleshooting section p. 96 for your 929) which will reset all settings back to factory defaults. Although a single reset will generally resolve the issue, when it does not, some owners have found that doing several resets in a row was more successful in resolving their issue.
post #11 of 11 Old 05-26-2014, 09:24 AM
Lttrader's Avatar
Quoted: 13 Post(s)
Liked: 27
Thanks JD. Your advice is appreciated. Last night I figured out my problem was the damn DVR again and not the 929. When I reset the DVR it did a firmware upgrade and all is well now.
Lttrader is offline
