Purchased new House, Looking for Recievers and Speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 06-04-2014, 09:07 PM - Thread Starter
rinku2012's Avatar
Quoted: 24 Post(s)
Hello,
Recently i have purchased new house and i got pre wired for 7.1 audio system. i am looking for speakers that are to be installed in wall and a good high end receiver
Does everyone thinks that below receiver is good enough for my needs ?
i am looking for good high end 7.1 receiver which supports 4K up scaling as well
http://www.newegg.com/Product/Product.aspx?Item=9SIA2GA1JV6946
Please give your valuable suggestions
rinku2012 is offline
post #2 of 13 Old 06-05-2014, 01:55 AM
jdsmoothie's Avatar
Quoted: 12221 Post(s)
Liked: 5564
Although certainly not high end (more mid range), this model would certainly work well, although note the version of YPAO it uses cannot EQ the subwoofer whereas the next model up, the A2030 can. You may also want to consider the Denon X2000 (on clearance) with Audyssey MultEQ XT which can EQ the subwoofer and which would allow you to put more money into better quality speakers.
jdsmoothie is online now
post #3 of 13 Old 06-05-2014, 08:23 AM - Thread Starter
rinku2012's Avatar
Quoted: 24 Post(s)
Thanks jdsmoothie. I see that A2030 is 9 speaker receiever. but i do have only 7 speakers allocated to the walls.
post #4 of 13 Old 06-07-2014, 07:38 PM - Thread Starter
rinku2012's Avatar
Quoted: 24 Post(s)
can anyone please respond to this thread. i need 7 speakers and a sub woofer too. which one should i be buying ?
post #5 of 13 Old 06-08-2014, 12:06 AM
kikkenit2's Avatar
Quoted: 822 Post(s)
Liked: 303
If you are really serious about 4k it would be smarter to buy a 2014 model that has hdmi 2.0. Upscaling is probably best handled by the tv. Give a realistic maximum budget for each item for best results. Comparing a receiver that costs 3 times as much is not rational. Better to have too many amp channels but the price goes up a lot and not required. Speaker questions go in a different forum for the most part.
kikkenit2 is offline
post #6 of 13 Old 06-08-2014, 05:09 AM
jdsmoothie's Avatar
Liked: 5564
post #7 of 13 Old 06-24-2014, 10:37 AM - Thread Starter
rinku2012's Avatar
Quoted: 24 Post(s)
Hello,
i was looking through some recievers and i have seen that Onkyo is plannign to sell Doly Atmos sound system recievers. Can someone please suggest me whether the below 2 recievers are better then the Yamaha one which i have kept in this thread ?
http://www.onkyousa.com/Products/mod...rce=comparison
I do have 7 pre wired surround speaker system. will there be any positive or negatives for me if i go with 9.1 receiver or should i just be sticking with 7.2 receiver system ?
post #8 of 13 Old 06-25-2014, 09:31 AM - Thread Starter
rinku2012's Avatar
Quoted: 24 Post(s)
can someone reply to the thread
post #9 of 13 Old 06-25-2014, 02:01 PM
kikkenit2's Avatar
Quoted: 822 Post(s)
Liked: 303
Just in the last few days the game has changed. Dolby atmos 3 dimensional surround sound has been announced by all the main players. Onkyo is dropping any audyssey room correction because it requires twice as many audio processing chips. Denon and Marantz doubled the chips at great cost. What is the realistic maximum budget on the receiver? Same with sub and speakers?
A 9 channel receiver will have more connections and/or features than a 7 channel receiver. You don't have to use every channel. They cost more too. With atmos you will want more speakers. Mainly 2 or 4 more in the ceiling. Nothing fancy though. None of the hdmi 2.0 with dolby atmos receivers will be out for a few months. When are you ready to buy?
post #10 of 13 Old 06-25-2014, 10:55 PM - Thread Starter
rinku2012's Avatar
Quoted: 24 Post(s)
I am planning to buy after a month. i can even wait for future proof ones.
which one do you guys recommend me ? ( like features)
post #11 of 13 Old 07-18-2014, 01:16 AM - Thread Starter
rinku2012's Avatar
Quoted: 24 Post(s)
Hi Everyone,
can anyone please suggest me ASAP so that i will buy the speakers and receivers within 2 weeks. i want to buy HDMI2.0 and Dolby Atmos receiver and speakers
post #12 of 13 Old 07-18-2014, 11:33 AM
jdsmoothie's Avatar
Liked: 5564
Need a max budget first as well as what features/inputs/outputs you want.
post #13 of 13 Old 07-18-2014, 11:34 AM - Thread Starter
rinku2012's Avatar
Quoted: 24 Post(s)
My budget is around 3000 to 4000$ ( including speakers, sub woofer and receiver) or little bit more if i get a good product
