Marantz SR7009 - Page 5 - AVS Forum | Home Theater Discussions And Reviews
 315Likes
Old 08-29-2014, 02:12 PM - Thread Starter
wse
wse's Avatar
Quoted: 2041 Post(s)
Liked: 749
wse is offline
Old 08-29-2014, 02:29 PM
NorthSky's Avatar
Quoted: 7012 Post(s)
Liked: 3546
Originally Posted by Selden Ball View Post
NorthSky: yes.
Even without Main In on my Kenwood's rear axe? ...Tape monitor (In)?
NorthSky is offline
Old 08-29-2014, 02:32 PM
NorthSky's Avatar
Liked: 3546
Originally Posted by wse View Post
Here you go 9.2.2 or 7.2.4 any one http://smile.amazon.com/Marantz-MM70...pr_product_top
or better get one of these: http://www.parasound.com/halo/a23.php
and be happy
Are you nuts or what!
* You can get a stereo amp @ your local flee market for ten box or less.
NorthSky is offline
Old 08-29-2014, 02:33 PM
Selden Ball's Avatar
Quoted: 3127 Post(s)
Liked: 1535
You can use any stereo input on the Kenwood that you want. You just have to be careful that the Kenwood's settings are always the same (volume control, tone controls, etc) so that the Audyssey calibration stays valid.
Selden
Selden Ball is online now
Old 08-29-2014, 02:35 PM
NorthSky's Avatar
Liked: 3546
Hey, thx a bunch Selden.
NorthSky is offline
Old 08-30-2014, 06:18 AM
jdsmoothie's Avatar
Quoted: 12328 Post(s)
Liked: 5629
I have a Kenwood stereo receiver, with a total of two channels of amplification.
Some Marantz and Denon receivers have only nine channels of amplification (some Onkyo models have eleven):
Can I use my Kenwood with say a Marantz SR7009 receiver having only nine amps inside? ...To make eleven total, for a 7.1.4 Atmos setup.
Or do you think the next Marantz SR7010 will have eleven internal amps?
Currently only 1 Onkyo model (new 5010) has 11CH of on board amps, likely only desired by <1% of owners with >90% of households only having 5.1 or less setup. You can use either a dedicated 2CH amp (eg. AudioSource100) or a 2CH receiver or even a 5.1/7.1 multi channel AVR to power the extra 2CH to expand the SR7009 from 9CH to 11CH. Unknown as to what the 2015 models will feature.
jdsmoothie is online now
Old 08-30-2014, 10:17 AM
joerod's Avatar
Quoted: 619 Post(s)
Liked: 498
The sweet spot.
My Sony 5000ES Review PART 2 FINISHED:
http://hstrial-jrodriguez996.homeste...=1462841668379
joerod is offline
Old 08-30-2014, 11:36 AM
jdsmoothie's Avatar
Liked: 5629
Those of you potential SR7009 owners who want to learn more about the various Atmos configurations may want to join us in the Denon X4100/X5200/X7200 thread as the SR7009 will have the same settings as those on the X5200W. One of the issues already pointed out is that the Dolby Atmos "AMP ASSIGN" mode is not intuitive in that it only includes the Height speakers and excludes the Dolby Enabled speakers however you can still configure them for Atmos BDs using the 9.1 or 11.1 AMP ASSIGN configurations instead.
The "Official" 2014 Denon Atmos+XT32 Model Thread (X4100/X5200/X7200)
The first X5200W was received on 8/23 by forum member FilmMixer with his review/comments starting here ...
Old 08-31-2014, 02:55 PM
rprice54's Avatar
Quoted: 92 Post(s)
Liked: 45
Okay. So I've been reading that thread. Any significant differences between the 7009 and X5200?
rprice54 is offline
Old 08-31-2014, 03:05 PM
joerod's Avatar
Quoted: 619 Post(s)
Liked: 498
Here's my write up. I still can't call it finished until we have true Atmos Blu-ray titles in our hands!
http://hstrial-jrodriguez996.homeste...=1409517748063
r.furborough likes this.
joerod is offline
Old 08-31-2014, 03:48 PM
jdsmoothie's Avatar
Liked: 5629
One difference is the SR7009 uses a "Dialog Level Adjust" setting as was used on last years D&M models which simply adjusts the center channel volume, while the X5200W and X7200W inherit the "Dialog Enhancer" setting (low, med, high; adjusts human voice frequencies, 300Hz - 3Khz) from the 4520CI in addition to having separate center channel volume control, although not certain of it's actual effectiveness.
Old 08-31-2014, 08:07 PM
channelserf's Avatar
I'm getting ready to pull the trigger on the 7009 (coming in Tues.) I'd like to go 7.1.4. I just need to add the 4 OH speakers But yeah spending 2k on the AVR and another $700 on the Marantz 2-ch Amp to get 2 more channels is a bit much to swallow.
I run the system 90% for HT but I'm wondering what amps would be a good match performance wise and bit more cost effective. I'd really appreciate your recommendations Thanks!
channelserf is offline
Old 08-31-2014, 10:13 PM
steveting99's Avatar
Quoted: 1800 Post(s)
Liked: 615
^channelserf,
Emotiva makes excellent amps. Check out their Ultra Series two channel option here: http://emotiva.com/products/amplifiers/upa-200
If you want something cheaper with a little lower in power to drive just a pair of ceiling speakers, this one from Audiosource should do: http://www.amazon.com/gp/product/B00...pf_rd_i=507846
channelserf likes this.
Marantz SR-7009, Oppo BPD-93, MTV 7000D, aTV, Harmony Home Control remote, KEF E301+T101, MiniDSP (2x4)+(10x10HD)+(DDRC-88A), Emotiva 2xXPA-5 (Gen2), Rythmik 2xF12G+2xF8, HiMedia Q16, LG 55EC9300.
steveting99 is offline
Old 09-01-2014, 04:13 AM
jdsmoothie's Avatar
Liked: 5629
With a 7.1.4 configuration, you have the option of externally powering the Front, Wide, Top Front, or Top Rear speakers. If you want to provide even more power to the Front speakers than what the SR7009 can provide, a more powerful 2CH amp would be in order, however, the Top Front and Top Rear speakers will require much less power. The AudioSource100 suggested above (or even an older AVR the SR7009 is replacing) is often recommended for Zone 2/3 duty and would work well for the Top speakers as well and at a much lower cost.
Old 09-01-2014, 06:11 AM
Liked: 1535
One difference that I came across in the manuals is that the SR7009 seems to have more options than the X5200W for the "Height2" channel when Dolby-enabled up-firing speakers are used. Of course, this is irrelevant if you plan to use direct-firing overhead speakers. In that case, both AVRs have the same set of options. I haven't seen a screenshot of what the X5000W actually provides, though.
ID:	240057   Click image for larger version
Selden
Old 09-01-2014, 06:21 AM
jdsmoothie's Avatar
Liked: 5629
Actually, both models have the exact same configuration capabilities, rather the difference is due to you posting the 9.1 configuration for the X5200W and the 11.1 configuration for the SR7009.
Old 09-01-2014, 06:28 AM
Liked: 1535
JD,
Thanks for the clarification!
Selden
Old 09-01-2014, 06:46 AM
rprice54's Avatar
Quoted: 92 Post(s)
Liked: 45
Hadn't thought of that. I do have an older Sony 5.1 AVR that came with the new house I could use for channels 10 and 11.
rprice54 is offline
Old 09-01-2014, 06:50 AM
smurraybhm's Avatar
Quoted: 1494 Post(s)
Liked: 1795
Joe - Thanks as always for another well done review even if it is incomplete. So what exactly did you use for speakers when running the Dolby Surround mode? Couldn't figure that out since the Heights according to the white paper can be at either 45 degrees or overhead. Curious if you used any "traditional" heights or just nixed those as you did with the wides. Finally, any plans to review any upfiring modules? Thanks again. Steve
smurraybhm is offline
Old 09-01-2014, 07:05 AM
joerod's Avatar
Quoted: 619 Post(s)
Liked: 498
Thanks I appreciate it. I used Martin Logan Vanquish ceiling speakers. A pair in the front and a pair in the rear. Results are a lot better than I was anticipating. I did test back and forth with my "classic height" which was just up front and the wides. I then would change the Amp assign so the Rear Heights were silent.
On another note I did speak with Onkyo last week and they were offering to send me their modules so I can compare them to the ceiling speakers. That may go down with my 3030 Review.
joerod is offline
Old 09-01-2014, 10:18 AM
petetherock's Avatar
Quoted: 1085 Post(s)
Liked: 520
Can you point me to a link where I can also read up on the SR 7009 owner's manual?
Cheers
petetherock is offline
Old 09-01-2014, 11:05 AM
Liked: 1535
Cheers
http://manuals.marantz.com/SR7009/NA/EN/
petetherock likes this.
Selden
Old 09-01-2014, 11:08 AM - Thread Starter
wse
wse's Avatar
Liked: 749
Originally Posted by steveting99 View Post
^channelserf,
EMOTIVA
wse is offline
Old 09-01-2014, 11:23 AM - Thread Starter
wse
wse's Avatar
Liked: 749
THANK YOU, I ordered mine and should get it September 8th I can not wait for it to arrive!
If it is that good DTS is going to have a thought time to catch up
So from your perspective 7.2.4 is better than 9.2.2 (with wide)?
wse is offline
Old 09-01-2014, 06:42 PM
joerod's Avatar
Quoted: 619 Post(s)
Liked: 498
Definitely better. Sound from above draws you more in. Actually we just finished watching a movie and having my dogs down there is going to take some getting used to. At times when there is a sound from the ceiling they think someone is upstairs! They ran up the stairs barking 3 times during the first half of the movie. Before they would do it occasionally but now!!!
joerod is offline
Old 09-01-2014, 06:44 PM
joerod's Avatar
Quoted: 619 Post(s)
Liked: 498
And congrats! You made a good choice.
joerod is offline
Old 09-01-2014, 06:57 PM
NorthSky's Avatar
Liked: 3546
I'm waiting for the next receiver with onboard thirteen separate channel amplifiers.
I don't have much space in my rack.
NorthSky is offline
Old 09-01-2014, 06:59 PM
NorthSky's Avatar
Liked: 3546
Emotiva makes excellent amps. Check out their Ultra UPA Series two channel option here: http://emotiva.com/products/amplifiers/upa-200
That, excellent.
NorthSky is offline
Old 09-01-2014, 07:01 PM
Thanks for the write up joerod. I'm really pumped for mine to arrive!
Since the height & surrounds are the only channels labeled as assignable does this mean I have to use my external amp to power one of those pairs or can I use it to power the L/R channels and assign the freed internal amp for an assignable set? In looking at the manual it's a bit unclear?
Old 09-01-2014, 07:02 PM
NorthSky's Avatar
Liked: 3546
Do you think the Marantz sounds better overall compared to the Denon?
NorthSky is offline
media mode , second sub , svs 20-39 , usb dac
