Marantz AV8802 13.2 XLR processor - HDMI 2.0 ISF - Wifi + Bluetooth details - Page 6 - AVS Forum
post #151 of 581 Old 07-02-2014, 03:13 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 1106 Post(s)
Liked: 1524
Originally Posted by WestCoastD View Post
ah, I see, thanks. So, essentially, the basic requirement are two additional rear-height speakers? Giving us 5.1.2 ?
The "height" speakers are generally at the front or rear of the room while the "ceiling" speakers will be closer to your seated position (ie. forward of the height speakers).
"JD" –
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
; shop.avscience.com ; 585-645-1006, AVScience - Authorized dealer for AVRs, Speakers, etc.
Mon - Fri: 10am – 10pm EST (Sat/Sun too if you leave message)
Call for pricing on Denon, Marantz, Yamaha, Def Tech, Atlantic Tech, Parasound
** Think the AVR is defective?  Reset the microprocessor 4-5 times.
jdsmoothie is online now
post #152 of 581 Old 07-02-2014, 12:06 PM
SoundChex's Avatar
Quoted: 113 Post(s)
Liked: 97
Originally Posted by kikkenit2 View Post
Originally Posted by SoundChex View Post
In a 01/07/2014 Press Release, "DTS Demonstrates DTS-UHD™ Decoder Using Single-Chip Audio DSP at Consumer Electronics Show" (link), DTS stated: "AVR, HTiB and soundbar licensee partners of DTS that utilize Cirrus Logic quad-core audio DSPs will be able to license the DTS-UHD decoder into their product designs beginning Q2 2014".
The inference I draw is that at least some AVRs will use the Cirrus Logic quad-core audio DSP to decode|render DTS-UHD content, so that for a portion of those AVR lines, a 'model year hardware' update may be required, rather than just a firmware update...?!
I can't find any quad core dsp chips on cirrus logic website or google. This looks like the current best model. Only dual core and no atmos or dts 3d mentioned.
http://www.cirrus.com/en/products/cs...odKey=CS4970xx
It appears (link) that the Krell Foundation Surround Processor feature set is "based upon a pair of [these] dual-core 32-bit Cirrus Logic CS497024 DSPs" . . . which seem capable of performing 'everything including the kitchen sink' audio decoding and post-processing!
_
"My AV systems were created by man. They evolved. They rebelled. There are many speakers. And they have . . . A PLAN."
SoundChex is online now
post #153 of 581 Old 07-02-2014, 01:53 PM
wse
wse's Avatar
Quoted: 418 Post(s)
Liked: 339
As previously mentioned, all 2014/2015 D&M Atmos units are scheduled to be released with Atmos pre-loaded, to include the 8802, starting with the SR7009 and AV7702 in Sep.
Good preloaded is best no surprises then
My humble Cinema
wse is offline
post #154 of 581 Old 07-02-2014, 01:57 PM
wse
wse's Avatar
Quoted: 418 Post(s)
Liked: 339
The Marantz doesn't include it
So no DTS UHD in 2015
http://www.dts.com/corporate/press-r...nics-show.aspx
My humble Cinema
wse is offline
post #155 of 581 Old 07-02-2014, 02:02 PM
wse
wse's Avatar
Quoted: 418 Post(s)
Liked: 339
It appears (link) that the Krell Foundation Surround Processor feature set is "based upon a pair of [these] dual-core 32-bit Cirrus Logic CS497024 DSPs" . . . which seem capable of performing 'everything including the kitchen sink' audio decoding and post-processing!_
It is only 7.1 ! So no ATMOS no DTS UHD
My humble Cinema
wse is offline
post #156 of 581 Old 07-02-2014, 04:06 PM
JonFo's Avatar
Quoted: 20 Post(s)
I read that Marantz had to retool from 2 to 4 dsp chips for audyssey and atmos combined. Does anybody know what brand/model chips those are?
D&M typically uses AnalogDevices, SHARC 32's mostly, the Marantz 8801 uses three ADSP21487. So I'd expect that's what they use in the upcoming unit, but four of them for added channel capacity and Atmos decoding.
Jonathan
JonFo is offline
post #157 of 581 Old 07-02-2014, 05:03 PM
wse
wse's Avatar
Quoted: 418 Post(s)
Liked: 339
Originally Posted by mdrums View Post
I just replaced my Integra DHC80.3 processor with the Marantz AV8801. ......I will continue to work and improve my rooms acoustics.
How do you like the upgrade, I assume it is an upgrade?
Great idea a lot of people neglect room acoustics
My humble Cinema
wse is offline
post #158 of 581 Old 07-03-2014, 11:14 AM
mdrums's Avatar
Liked: 26
I do have acoustic room treatments now...like whole front wall is acoustical treated and I have a make shift bass trap in the back. I need a better looking commercially made bass trap and I want to do a little room treatment in the back on the room as I get a very slight slap back in the rear. When I built the room the installer said to keep the rear of the room very live for the surround speakers. I've found this not totally true and the rear of my room needs a little treatment to stop that slight slap back echo. You can see some of my room on the profile pics I have.
The Marantz AV8801 is nice. I like its operation better than the Intgra. I never really warmed up to the Intgra. As far as sound goes its really hard to tell a huge difference but it seems to do surround a little better with more pin point accuracy. It also seems to do 2ch better as well. Also the HDI switching is nicer too. I really wanted a McIntosh to go with my McIntosh amps....but...it's hard to throw $12k to a processor that will be out of date in a year or 2.
I am still playing with Audessey xt32. I'm not completely sold on it's calibrations. I tend to want to go it and tweak the eq settings. Audessey is basically getting my distance correct but is putting odd crossover points on all my speakers and they are a complete set of Klipsch Ref7 speakers so they should pretty much have the same sound from the kids and higher.
Mikes Stuff
McIntosh MC207 Amps.........................DarbyVision Darblet
Marantz AV8801 Processor.................Da-Lite Screen
Klipsch Reference Series 7.2................Panasonic BluRay BDT500
Epson Pro 6010 Projector.....................Sony Playstation used for SACD and BluRay
mdrums is offline
post #159 of 581 Old 07-03-2014, 11:39 AM
Selden Ball's Avatar
Quoted: 326 Post(s)
Liked: 400
The Audyssey calibration procedure is essentially identical in both the Integra and Marantz pre/pros. If you haven't already, please take the time to look through the Audyssey FAQ and 101 at "Official" Audyssey thread (FAQ in post #51779)
Bear in mind that Audyssey determines the point at which it hears a 3dB falloff in sound level (the f3 point) and then the pre/pro's separate firmware decides which crossover frequency to use. Manually raising the crossover frequency setting is fine. Lowering it is not: Audyssey does not attempt to do any corrections below a speaker's f3 point. See
c)1. Why are my Crossovers set differently to my speaker manufacturer's specification?
and
c)4. Is it OK to change the Crossovers from Audyssey's recommendation?
Hopefully you're using a microphone boom stand to hold the microphone. They can be had for less than $30 and make it relatively easy to always position the microphone in the same places when redoing a calibration. Small displacements sometimes make a big difference. See
d)1. Do I really need to put the Audyssey mic on a tripod or stand?
If you use the relatively crude graphics equalizer, it completely disables Audyssey EQ. This is the same for both Denon/Marantz and Onkyo/Integra systems, but D&M also provide separate tone controls. See
a)12. What is the relationship between the Equaliser setting in my Onkyo/Integra AVR and Audyssey?
Selden
Selden Ball is online now
post #160 of 581 Old 07-03-2014, 11:53 AM
mdrums's Avatar
Liked: 26
Hi Selden, thanks for your post and links. I am using a boom mic stand...I have plenty of them for my drums. I totally forgot about the F3 crossover deal. My rears were set at 100...my sides at 70 which to me was odd as they are the same as the rears and my front LR and 40 and center at 50. The sub volume was extremely set low. I have re-done Audessey around 4 times now after reading about mic placement. I got better results with only moving the mic 2-4" max around my LP.
I fight with myself about using the eq setting in the AV8801. I guess it's a pro audio sound man in me and the drummer in me. I fight with this because I really want to use Audessey and I know it improves my low end. However I am not happy with upper mids and highs with Audessey on....so I tend to want to tweak the settings myself.
Mikes Stuff
mdrums is offline
post #161 of 581 Old 07-03-2014, 12:07 PM
Quoted: 326 Post(s)
Liked: 400
Room reinforcement (reflections) can make identical speakers sound quite different depending on where they're located in the room. If you haven't already, you might want to consider room treatments (absorbers). When placed properly, they often can make a substantial improvement.
Selden
post #162 of 581 Old 07-03-2014, 03:06 PM
mdrums's Avatar
Liked: 26
Yep that is what I am planing on doing. Just need to find something that looks nice and interesting but isn't super expensive.
Mikes Stuff
mdrums is offline
post #163 of 581 Old 07-03-2014, 06:40 PM
Woof Woof's Avatar
Quoted: 13 Post(s)
Liked: 38
Any word on whether the 8802 with the quad DSP will be able to handle full 192kHz resolution with Audyssey XT32 enabled without downsampling to 48kHz?
Woof Woof is offline
post #164 of 581 Old 07-03-2014, 06:54 PM
Marcus Gan's Avatar
Hi,
Will be watching T4 @ Atmos GVmax on Sunday. May I know is there any 3D Auro Cinema in Singapore.?
Marcus Gan is offline
post #165 of 581 Old 07-03-2014, 06:56 PM
Ericks89's Avatar
Well that's good that it will be pre-loaded and also the av7702 will be available sometime in september
But that's not too far off, I'm surprised they haven't updated their website that new pre/pro and avrs are coming... Yamaha and Onkyo have their's up, denon as well if you know the link otherwise not listed.
I'm debating whether or not I need atmos as I'm only doing 7.2 and maybe go 9 channels if or when movies and games will add it.
If the 8802 really is $5Gs there better be a reason and not just snake oil...
Ericks89 is offline
post #166 of 581 Old 07-03-2014, 07:18 PM
585-645-1006
jdsmoothie's Avatar
Liked: 1524
It will not, ie. no change from the 8801.
"JD" –
post #167 of 581 Old 07-04-2014, 01:24 AM
Webmonkey's Avatar
Liked: 25
Now this is a letdown........ :-(
Webmonkey is offline
post #168 of 581 Old 07-04-2014, 01:58 AM
585-645-1006
jdsmoothie's Avatar
Liked: 1524
Not at all .. no real audible difference either way.
"JD" –
post #169 of 581 Old 07-04-2014, 08:14 PM
coli's Avatar
Quoted: 70 Post(s)
Liked: 27
Audyssey is getting quite old at this point, hopefully more company switch to Dirac.
coli is offline
post #170 of 581 Old 07-05-2014, 03:55 AM
Quoted: 129 Post(s)
Liked: 192
...snip...
...snip...
So no subwoofer equalization in my 8801???????
Samsung 64F8500, Panasonic 65VT50, Oppo 95, Tivo Roamio for OTA, Dish VIP722, Marantz AV8801 preamp, Rotel Amps, Atlantic Tech 8200 speakers, Seaton Submersive HP, Calman 5, Chromapure, Accupel DVG-5000, i1Display3pro, i1pro2, eecolor colorbox.
JimP is offline
post #171 of 581 Old 07-05-2014, 04:15 AM
585-645-1006
jdsmoothie's Avatar
Liked: 1524
Yes, of course there is. All versions of Audyssey (except 2EQ) can EQ the subwoofer. The post you quoted is referring specifically to "speaker" EQ.
"JD" –
post #172 of 581 Old 07-05-2014, 05:38 AM
CIH USER
Franin's Avatar
Quoted: 157 Post(s)
Liked: 213
Have to agree, or Audyssey to come out with something new.
_________________________
Frank
Franin is offline
post #173 of 581 Old 07-05-2014, 06:02 AM
Woof Woof's Avatar
Quoted: 13 Post(s)
Liked: 38
There's nothing wrong with Audyssey.
XT32 already provides a lot of resolution. In fact the 48kHz limitation is due to the lack of processing power in current DSPs. Audyssey can process it at higher resolutions as long as they have enough horsepower to do the number crunching.
There's perhaps no reason for them to do so if as JD says there's no audible reason. But then it seems a waste when there are some BDs with 192kHz material.
post #174 of 581 Old 07-05-2014, 06:57 AM
BCWookie's Avatar
Get your marantz 8801 audessey pro calibrated and it will be close to perfect. Before it was done my system sounded good, but after it is amazing. I was doing the same thing with adjustments- back and forth etc until it was calibrated by Chad B. We'll worth the money!
Marantz AV 8801
Goldenear 11.4
Oppo 105D
HTPC
BCWookie is offline
post #175 of 581 Old 07-10-2014, 06:31 PM
DrMichael's Avatar
How much to have it calibrated?
Panasonic TC-P65ZT60
Marantz AV8801 pre-pro / MM8077 amp
Martin Logan Motion 50XT Center
Martin Logan Motion 60XT Fronts/40 Rears
REL R-528 SE (2)
Oppo BDP-103D/Playstation 4/Furman ELITE-20 PF i
DrMichael is offline
post #176 of 581 Old 07-10-2014, 08:33 PM
BCWookie's Avatar
I think I paid $600 or so for both the projector and audessey pro done, but he spent a whole day working on fine tuning the system. Check out his website hdtvbychadb.com, he is out of Ohio but travels around the country. There is also a thread that talks about calibrators and where they are located on Avs. Look for someone that does the calibration!!!! Highly recommended!!!
Marantz AV 8801
Goldenear 11.4
Oppo 105D
HTPC
BCWookie is offline
post #177 of 581 Old 07-11-2014, 11:01 AM
ssabripo's Avatar
Very good features and as always, great looking unit.
But I just don't see enough value or added functionality/features to make one jump from the AV8801 to the AV8802...perhaps I'm wrong
ssabripo is offline
post #178 of 581 Old 07-13-2014, 12:48 AM
Roger Dressler's Avatar
Quoted: 508 Post(s)
Liked: 276
Originally Posted by tfboy View Post
How sure are we that those rear panels are what the real product will be and not mock-ups?
Easy way to tell. If all the Philips screws heads are the same alignment, its a photoshop job. And so they are!
Hugo S likes this.
Roger
Roger Dressler is offline
post #179 of 581 Old 07-13-2014, 06:41 AM - Thread Starter
AVS Club Gold
Hugo S's Avatar
Quoted: 71 Post(s)
Liked: 38
Hi Roger,
Excellent!!!
H.
Hugo S is offline
post #180 of 581 Old 07-13-2014, 06:45 AM
wse
wse's Avatar
Quoted: 418 Post(s)
Liked: 339
Question
I want one but can't understand why manufacturer still include compnent and composite video!!!
What a waist of space and money, in 2014 one would hope that all new AV would forget about these inpunt and outputs HDMi rules! Why live in the past!
My humble Cinema
wse is offline
marantz av8802
