AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   Receivers, Amps, and Processors (http://www.avsforum.com/forum/90-receivers-amps-processors/)
-   -   Good upgrade from Denon AVR 1613? (http://www.avsforum.com/forum/90-receivers-amps-processors/1535325-good-upgrade-denon-avr-1613-a.html)
Paul Light 06-10-2014 09:23 PM
Hi y'all
Is this a good upgrade from the Denon AVR 1613?
http://www.amazon.com/Yamaha-RX-V675-Channel-Network-Receiver/dp/B00B981F1U/ref=sr_1_1?s=tv&ie=UTF8&qid=1402460064&sr=1-1&keywords=yamaha
I'll be using it to drive Sierra-2's LCR, CBM-170SE surrounds and a Rythmik LV12R sub.
I have a direct Ethernet connection and will be using JRiver, Spotify, video content from UVerse and HTPC.
Paul
kikkenit2 06-10-2014 09:49 PM
Yamaha is the top rated brand on most a/v websites and the 675 is rock solid reliable and clean sounding. It will play 5.1 hdmi in the main zone while streaming stereo to zone 2 with all those network sources you listed. The best compatibility around on any kind of input.
jdsmoothie 06-10-2014 11:39 PM
If you like Audyssey on your 1613, another good upgrade would be the Denon X2000 (successor to the 2113CI) which is on clearance now and uses the more advanced MultEQ XT with a 3 year warranty and Spotify.
kikkenit2 06-10-2014 11:55 PM
jdsmoothie 06-11-2014 12:00 AM
Paul Light 06-18-2014 09:07 PM
Originally Posted by jdsmoothie (Post 24817115)
Nah ... just shifted over to CA time. <img alt="tongue.gif" class="bbcode_smiley" src="http://files.avsforum.com/images/smilies/tongue.gif">
Well, I pulled the trigger on a Yamaha RX-1030. So far, so good. :)
Can't wait for my Sierra 2's. :)
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
