Yamaha R-S201 and Pioneer SP-BS22LR - AVS Forum | Home Theater Discussions And Reviews
Old 06-11-2014, 07:13 AM - Thread Starter
ikylerobert's Avatar
Hey all,
I have a question about the compatibility of this Yamaha stereo receiver and these Pioneer speakers. The former is rated to handle only 8 ohms and above, but the speakers are 6ohm. Will there be a problem if I put these two together? I'm just looking for an inexpensive apartments bookshelf system.
ikylerobert is offline
Old 06-11-2014, 10:38 PM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 148
Originally Posted by ikylerobert View Post
Hey all,<br>
I have a question about the compatibility of this Yamaha stereo receiver and these Pioneer speakers. The former is rated to handle only 8 ohms and above, but the speakers are 6ohm. Will there be a problem if I put these two together? I'm just looking for an inexpensive apartments bookshelf system.<br>
Yamaha receiver's should work with 6 ohm speakers. The ones I have owned say they do. Check the manual if in doubt.
"But this one goes up to 11"
MichaelJHuman is offline
Old 06-13-2014, 09:26 PM - Thread Starter
The manual only mentions 8ohm speakers, but it has a "High dynamic power/channel" section that mentions 8/6/4 ohm power output.
http://m.usa.yamaha.com/products/audio-visual/hi-fi-components/stereo-receivers/r-s201.html
Old 06-14-2014, 12:59 AM
afrogt's Avatar
Quoted: 1057 Post(s)
Liked: 758
you'll be fine driving 6 ohm speakers.
The specs mention 8/6/4/2 ohm loads so you shouldn't worry about 6 ohm speakers.
Afro GT
afrogt is offline
Old 06-16-2014, 05:45 PM - Thread Starter
Thank you! I appreciate your help and have some more peace of mind now.
