Reciever to reciever - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 06-13-2014, 12:31 PM - Thread Starter
chambers1517's Avatar
Quoted: 13 Post(s)
I have a Onkyo 818 which sounds good. I also Have a Harmon Kardon 7200 which really sounds much better. I want to use the preamp in the Onkyo since it has Hdmi and Audyssey but I want to use the amps in the HK since they are more powerful and sound better. My front 3 are Klipsch Lascalas and they like the HK amps. The HK has direct inputs but my question is where to set the volume on the HK. I have an IB sub setup so I also have a sub amp. I thought about setting both volumes so there is minimal trim required in the Onkyo. What do you guys think.
chambers1517 is offline
post #2 of 6 Old 06-13-2014, 02:14 PM
DonH50's Avatar
Quoted: 1824 Post(s)
Liked: 1355
I think there is a lot more going on than just the amplifiers so unless you know that is causing the difference you may be disappointed. Or not, bias can be great.
Setting gains in a chain can be complicated. If you set the output of the Onkyo too high it will distort the input of the HK. Too low and noise will be higher and you might not be able to drive the HK to maximum output. If you are using the Onkyo's processing then I would do as you said and adjust the HK so that the Onkyo's trim levels are near 0 dB, after verifying that the Onkyo's output won't overdrive the HK (probably be fine).
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #3 of 6 Old 06-14-2014, 03:14 AM
jdsmoothie's Avatar
Quoted: 12280 Post(s)
Liked: 5598
Yup. Prior to running Audyssey on the Onkyo, just as is the case with a powered sub, set the HK to about 50% power level, and then adjust accordingly to get the Onkyo trim about 0db.
jdsmoothie is offline
post #4 of 6 Old 06-14-2014, 03:34 AM
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 519
Personally I'd sell the HK and buy a power amplifier, using the Onkyo as a pre. Rather than faffing about. That's if you prefer the sound of the Onyko as a pre, rather the HK.
fatbottom is offline
post #5 of 6 Old 06-14-2014, 04:38 PM
M Code's Avatar
Quoted: 719 Post(s)
Liked: 424
Here how I would set it up..
1. Set the 7200 to 6/8 Channel DIRECT
2. Set the 7200 channel trims to 0dB
3. Set the 7200 Volume Control to -10dB
4. Connect 7200 Pre-Outs to the Onkyo multi-channel inputs
Double check the 7200 volume control, U may have to adjust this up/down slightly to balance with the Onkyo's other sources. The 7200 had a robust power supply and amplifier section, and will outperform many separate component power amplifiers. Its amplifier topology was designed by Richie Miller who developed many of the legacy JBL and HK amplifiers including the Citation series..
Just my $0.05...
M Code is online now
post #6 of 6 Old 06-14-2014, 09:52 PM - Thread Starter
Quoted: 13 Post(s)
Just my $0.05...
I did exactly as you suggested. The front trims ended up at about -4 in the Onkyo and the rears and sides ended up at about +3. The sides and rears are Klipsch Heresys. I think this is really good. You are right, I don't know why but the amps in the HK sound incredible. I have had several other recievers and nothing compares. The HK amps really brought the Onkyo to life. This thing weighs about twice what the Onkyo does. Thanks, this is about perfect.
