Pass 4k 3D - AVS Forum | Home Theater Discussions And Reviews
Old 06-13-2014, 04:42 PM - Thread Starter
vetboy's Avatar
Pass 4k 3D
I've been considering upgrading my current receiver to one that can pass 4k video but I was wondering if anyone knows if the currently available models will pass 4k 3d? I want to get something that will be able to handle all the currently expected formats so I can finally get an OSD from my audio components. I upgraded to 1080p then found out I needed to upgrade to 3D if I wanted to pass the signal. Now we have 4K but will all those require an upgrade relatively quickly?
Vetboy
The average dog is a nicer person than the average person
vetboy is offline
Old 06-14-2014, 08:28 PM - Thread Starter
vetboy's Avatar
Are there no responses because no one knows or because the answer is obvious?
Vetboy
vetboy is offline
Old 06-14-2014, 08:58 PM
CinemaAndy's Avatar
Quoted: 701 Post(s)
Liked: 136
I would wait until HDMI 2.0 is released later in the year. There is no 4K 3D. You can have 4K or 3D you can not have them both. In 2D, if by content or up conversion you get 4K. In 3D you get 1080P 60 refresh rate per eye or 120, unless you have the newer 3D that offers 144 or 240 refresh rate. So to make it simple, in 2D you get 4K. In 3D you get 1080P. And before others try to post more technical meaningless information, 1080P in each eye does not equal 4K. It equals 1080P.
HDMI version 1.4 nor 1.4a supports 4K 3D. HDMI 2.0 will support this and the higher 144 and 240 refresh rates.
I never said 4K 3D was impossible, the component limits prevent it. Theaters are just now getting to 4K 3D projectors thinks the Laser projection, that can technically project a 8K image if such a beast was made.
CinemaAndy is offline
Old 06-24-2014, 09:28 PM - Thread Starter
vetboy's Avatar
Thank you for the response. Makes sense to me.
Vetboy
vetboy is offline
