Amp? If so which one - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 06-13-2014, 08:11 PM - Thread Starter
codyaaron2's Avatar
I recently purchased the speakers below and was wandering if i needed an amp.
I have the Denon 2307ci and speakers below, any suggestions would be appreciated. Thanks
MAIN
RTI A7
CENTER
CSI A6
SURROUND
FXI A6
SUB
DSWPRO660WI
codyaaron2 is offline
post #2 of 7 Old 06-13-2014, 08:51 PM
bass addict's Avatar
Quoted: 360 Post(s)
Liked: 438
Polk sensitivities are good, not great, but better than a lot of others. They will play plenty loud with very little power.
Room size, listening habits; x overs, etc; will all play into whether you might see an improvement from external amplification.
Why do you think you might need one? Have you hooked them up and listened to them?
Achievement Unlocked
Psychotic Episode Averted
bass addict is offline
post #3 of 7 Old 06-13-2014, 08:51 PM
Knucklehead90's Avatar
Quoted: 391 Post(s)
Liked: 335
Does your 2807 have preamp out jacks?
Yamaha CX-A5000 - Acurus A100x3 & Outlaw 7075 - Salk Song Towers - Custom Selah Audio Center - Oppo 103 - Marantz TT42
***GO SEAHAWKS ***
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is offline
post #4 of 7 Old 06-13-2014, 08:53 PM
Quoted: 360 Post(s)
Liked: 438
Yeah, they do.
post #5 of 7 Old 06-13-2014, 10:10 PM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 148
MAIN
RTI A7
CENTER
CSI A6
SURROUND
FXI A6
SUB
DSWPRO660WI
Do you hear distortion at your typical volume level?
"But this one goes up to 11"
MichaelJHuman is offline
post #6 of 7 Old 06-14-2014, 12:32 PM
dsmith901's Avatar
IMO adding a higher power amp to a receiver used as a preamp is a good idea, especially if you like to listen at higher volumes, or have a large listening room. It also gives you more options if and when you decide to upgrade your speakers. You don't mention budget, but in another recent post I suggested the OP take a look/listen to the ATI line of amps. Here's a link:
http://www.classicaudioparts.com/ind...mplifiers.html
"The truth is out there!"
dsmith901 is offline
post #7 of 7 Old 06-14-2014, 07:35 PM
IntelliVolume's Avatar
Quoted: 1487 Post(s)
Liked: 696
Just as an aside and to add my two cents, I'm running RTi12s as mains off an Onkyo 605 with zero problems (no fatiguing, no distortion at our comfort levels, no shrillness, etc.). The RTis/RTi As can pretty much be run with any AVR from my experience; it's when you get into the LSis that there are issues with higher power and better amplification needs due to their low impedances/quasi-low efficiency...
IntelliVolume is offline
