Replacing old Denon 3805 receiver worth it - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 06-14-2014, 05:59 AM - Thread Starter
patfraley's Avatar
I currently use the AVR-3805 as a pre amp connected to a Adcom 5 channel Amp. It has been a great receiver and this set up works well, particularly for movies. That said I would like some modern day functionality and am considering a change. A Marantz SR6008 can be had for $699 (originally $1200) and would use as pre amp. I only want to do this if the sonic improvements are worth it, especially for music. I know I could get a true pre amp from Outlaw or Emotiva for around the same price but I like what the Marantz offers.
Worth the effort?
patfraley is offline
post #2 of 14 Old 06-14-2014, 10:27 AM
commsysman's Avatar
Quoted: 987 Post(s)
Liked: 526
Worth the effort?
I think you would get even better performance with a NAD T748, which is available for $600.
It has 4 HDMI inputs and 8-channel preouts.
commsysman is offline
post #3 of 14 Old 06-14-2014, 10:48 AM - Thread Starter
patfraley's Avatar
It has 4 HDMI inputs and 8-channel preouts.[/QUOTE]
Interesting and worth considering but need two HDMI outs. A big point in making the switch
post #4 of 14 Old 06-14-2014, 03:07 PM - Thread Starter
patfraley's Avatar
BUMP
post #5 of 14 Old 06-14-2014, 10:34 PM
jdsmoothie's Avatar
Quoted: 12252 Post(s)
Liked: 5583
Yes, Audyssey MultEQ XT on the SR6008 would most likely provide a noticeable improvement in your listening experience. However, when considering a refurbished unit, the factory warranty is only 1 year and replacing an HDMI board will set you back $400-$500 out of warranty, so also consider adding a 3-5 year extended warranty from a reliable 3rd party source that will stand behind their warranty (eg. SquareTrade).
jdsmoothie is online now
post #6 of 14 Old 06-15-2014, 12:12 AM - Thread Starter
patfraley's Avatar
You touched on the next conundrum. I currently use a DVDO green upscaler/switcher for all video. Not sure best way to mate the two if I get the 6008. I want on screen from both so I can either route all sources to DVDO and then out that to 6008 and then to TV or do opposite. I guess the good news is I have video switching options outside the 6008
Thoughts?
post #7 of 14 Old 06-15-2014, 12:14 AM - Thread Starter
patfraley's Avatar
Ps.....purchased the DVDO from AVS so thank you for that. Got a great deal and service was top notch!
post #8 of 14 Old 06-15-2014, 06:53 AM
jdsmoothie's Avatar
Liked: 5583
You can set the i/pScaling setting on the AVR to OFF and just let the DVDO Edge handle that. Experiment to see which configuration works best for you.
post #9 of 14 Old 06-15-2014, 08:07 PM - Thread Starter
patfraley's Avatar
Is it redundant keeping the Edge in the mix? I like some of the picture adjustments I can make but not certain how much improvement it makes on my Panasonic Plasma
post #10 of 14 Old 06-16-2014, 12:48 AM
UofAZ1's Avatar
Quoted: 50 Post(s)
Liked: 75
Your DVDO edge will have far more enhancements than a receiver will have. Since you already have an outboard amp I would stop looking at receivers and look at buying a great used preamp for your budget. Like a Marantz AV7005. Route the audio thru the preamp and the video thru the DVDO to your display.
UofAZ1 is offline
post #11 of 14 Old 07-06-2014, 04:47 PM - Thread Starter
patfraley's Avatar
Re-visiting thread. I can get a used Marantz AV7005 pre pro that came out in 2010 or the SR7007 receiver that came out in 2012 new in box. Both for $750. Leaning towards 7007. Which way would you go?
post #12 of 14 Old 07-06-2014, 05:13 PM
jdsmoothie's Avatar
Liked: 5583
Depends on the features you want. Compare each to determine which is better suited for your needs.
post #13 of 14 Old 07-06-2014, 08:30 PM
wes182's Avatar
Quoted: 51 Post(s)
Liked: 26
I'd recommend going with the receiver unless you are always an external amp guy. Reasoning being if the amp goes then you don't have to run out and get a new amp right away. Just my 2 cents.
wes182 is offline
post #14 of 14 Old 07-06-2014, 08:34 PM - Thread Starter
patfraley's Avatar
Thanks Wes....I tend to agree. I like the flexibility of being able to use as a receiver if/when necessary.
