Add a two, five or seven channel Emotiva Amp to my Denon AVR-X4000? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By MichaelJHuman
post #1 of 12 Old 06-19-2014, 10:36 AM - Thread Starter
bmwetr's Avatar
My new Denon AVR-X4000 does not have the same "punch" or warmth as my old AVR-2809. It also runs a good bit hotter.
I'm considering adding an Emotiva UPA-200, 500 or 700.
Since the UPA-200 is cheaper, weighs less, and would provide more power to my two front main speakers (Dahlquist 9-Cs), it seems like the most logical choice. The Denon should have plenty of power for the center and surrounds, especially with no load on the front amps. Am I missing something in my thought process?
Also, is it safe to assume that Audyssey will compensate for the extra power in the front two channels, and not overpower the main speakers during the setup process?
bmwetr is offline
post #2 of 12 Old 06-19-2014, 10:42 AM
KidHorn's Avatar
Quoted: 1374 Post(s)
Liked: 877
Also, is it safe to assume that Audyssey will compensate for the extra power in the front two channels,and not overpower the main speakers during the setup process?
You are correct in your assessments. Taking the 2 front channels off the receiver should keep it cooler. Plus you can run a 9 channel system with an external amp. Audyssey will handle the gain the same as if the receiver were driving all the channels.
I doubt you'll notice any improvement in sound quality unless there was something wrong with your receiver.
KidHorn is online now
post #3 of 12 Old 06-19-2014, 10:54 AM
jdsmoothie's Avatar
Quoted: 12079 Post(s)
Liked: 5501
After running Audyssey, there should be a noticeable improvement in quality as compared to your older 2809CI. Also there should be no difference in power so unless you have the X4000 volume maxed out (ie > 80 or 0db) and are hearing distortion, adding the Emo amp is not likely to make a difference. Did you run Audyssey using either a mic boom stand or camera tripod as indicated in the manual? My X4000 does not get any hotter than about 115 degrees F when powering 7 fairly efficient 8-ohm speakers to near reference volume level for several hours. Also note that as most of the heat is generated from the video chip, using an external amp may not drop the unit's temp much.
jdsmoothie is offline
post #4 of 12 Old 06-19-2014, 10:59 AM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 148
Personally, I would do the XPA-3 to provide equal power to all channels. The center seems to need equal power, especially if your center is like mine, and has a lower sensitivity. It's heavy though, and maybe outside your budget. Of course it will help somewhat to take some load off the receiver with any of your options.
Not sure about this missing "punch", can't help there, but if it's power you lack, the XPA-3 will likely provide more than you can use
The UPA might be ok, but it puts out only 80 watts into 8 and which on paper isn't much more than your typical AVR. As it has a nice 4 ohm spec it might do better in real world use. Not sure if it's power supply is substantially better than your AVRs. The price is nice though
Bassment likes this.
"But this one goes up to 11"
MichaelJHuman is offline
post #5 of 12 Old 06-19-2014, 11:08 AM
sikclown's Avatar
Quoted: 1377 Post(s)
Liked: 691
the UPA-200 is 125 watt into 8. I am using it to run my front wides.
sikclown is offline
post #6 of 12 Old 07-02-2014, 10:20 AM - Thread Starter
bmwetr's Avatar
Thanks to everyone who provided their guidance. Based on your posts I decided not to add an additional amp.
I did purchase a Coolerguys Quiet120mm AC Powered Receiver/Component Cooling Fan to reduce the temperature of the receiver. It has made a huge difference, and the top of the receiver is now cool to the touch after many hours of operation. I hooked it up through a Smart Strip PowerStrip, so the fan only runs when the receiver is on.
Last edited by bmwetr; 07-02-2014 at 10:21 AM. Reason: Site eliminates spaces between words
bmwetr is offline
post #7 of 12 Old 07-02-2014, 11:26 AM
Ricanmeng's Avatar
Hello,
I had the X4000 with an Emotiva XPA-5 and the Denon preouts weren't strong enough to properly drive the amp. I also could hear DAC noise from the Denon I could not hear from other units I have tried (I am an Integrator and have access to alot of things to try). In the end I bought a Emotiva UMC-200 and sold the Denon, and returned the other items and never looks back.
Other Items:
Integra DHC-80.2
Integra DTR-40.3
Integra DTC-9.8
Marantz SR6008
Ricanmeng is offline
post #8 of 12 Old 07-04-2014, 12:20 AM
Mav99l's Avatar
Quoted: 13 Post(s)
Originally Posted by Ricanmeng View Post
Hello,
Other Items:
Integra DHC-80.2
Integra DTR-40.3
Integra DTC-9.8
Marantz SR6008
Hi,
I have the XPA-2 and XPA-5 and was planning to add the Denon x-4000. Can you please explain the problems you had with this combo? Does anyone else have input on this? When the x-4100 comes out, I suspect the x-4000 will price drop significantly (to about $650) and that's when I was planning to pull the trigger, but would reconsider if there would be an issue with the sound.
Mav99l is offline
post #9 of 12 Old 07-04-2014, 03:55 AM
jdsmoothie's Avatar
Liked: 5501
There have been a number of X4000 owners who have posted in the Owner's thread of using an Emotiva amp,none of which have had any issues doing so.
post #10 of 12 Old 07-04-2014, 07:03 AM
smurraybhm's Avatar
Quoted: 1469 Post(s)
Liked: 1760
Hello,
Other Items:
Integra DHC-80.2
Integra DTR-40.3
Integra DTC-9.8
Marantz SR6008
Receiver doesn't "drive" the amp
That noise you heard was most likely an issue with a ground or the amp. Emo threads have a number of users who report a small amount of audible noise after installing their amps to which the Emo expert - Keith - has said was normal (that guy is a joke by the way). If you heard "noise" just using the receiver that may have implied an issue with the receiver. The Emo pre is good unit/value but requires the user to put up with some bugs - see its thread. Implying that it is a superior solution to the units you listed based on its ability to drive an amp
smurraybhm is offline
post #11 of 12 Old 07-04-2014, 10:14 AM
FMW
FMW's Avatar
Quoted: 1652 Post(s)
Liked: 1681
The AVR should handle things famously without any help from an external amp.
FMW is offline
post #12 of 12 Old 07-04-2014, 01:13 PM
Quoted: 59 Post(s)
Liked: 6
From personal experience with the X4000 it will shut down running it at reference level all 7 channels driven for 15 + minutes!
audio.hobby is offline
