Denon AVR 3801 wonky OSD - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-21-2014, 03:41 AM - Thread Starter
speaker dave's Avatar
Hi all,
Connecting a new Sony 65" and BluRay player into my old system and I am having trouble with the on screen display. My ultimate goal is to assign the BluRay players digital audio to Optical 1 input. This is via a Denon AVR3801 receiver.
I've connected an old TV to the composite monitor output as OSD only works in composite or S video. I can get the Setup OSD up but as soon as I try to scroll up or down to any setup options the display goes wonky then mutes the video output.
I've tried just counting button presses but that isn't working and I don't think I am really scrolling through any options.
The manual implies that Opt 1 should be assigned to DVD by default, but it isn't, so I am stuck.
Any ideas?
speaker dave is offline
post #2 of 4 Old 06-21-2014, 03:57 AM
jdsmoothie's Avatar
Quoted: 15033 Post(s)
Liked: 7250
Have you tried resetting the microprocessor per the instructions in the Owner's manual?
jdsmoothie is online now
post #3 of 4 Old 06-21-2014, 04:36 AM - Thread Starter
Thanks, good suggestion.
The display is still wonky, but at least that did set the inputs back to default. Opt1 is on DVD and Dig Coax on CD, which is usable.
Still, now I can't set channel levels. Not much you can do without a display!
David
post #4 of 4 Old 06-21-2014, 04:52 AM
jdsmoothie's Avatar
Liked: 7250
The benefit of a newer model with networking (in addition to better audio quality), is that in addition to the HDMI OSD on the TV, you can also use the OSD via a laptop or tablet as well as control the unit with a smartphone.
