The official Dolby Atmos thread (home theater version) - Page 106 - AVS Forum | Home Theater Discussions And Reviews
 15541Likes
post #3151 of 42773 Old 08-06-2014, 09:20 AM
Hugo S's Avatar
Quoted: 223 Post(s)
Liked: 137
Bonjour Jeff,
Originally Posted by chi_guy50 View Post
Keith,
But I am fairly certain this is already on your list, but could you please ask for an evaluation of the relative authenticity of using a traditional Dolby front height speaker configuration to play back an Atmos track? IOW, how will we benefit from Atmos if we don't change our layout?
Not Keith, but I don't see any Dolby representative giving any other answer to your above question, beyond what is included in the whitepaper (p9):
"While the arrangements recommended above will yield the best experience, a Dolby Atmos
system can support many other configurations you may already have in your home. For
instance, Dolby Atmos supports the standard “wide” speaker positions on the floor and the
“front vertical height” positions usually found on the top of the front wall, as well as many
other speaker positions.
Now as far as I'm concerned, I'm convinced that if the angle of location of an actual Height speaker, is within the tolerance for allowed angles of a Top/ceiling speaker, then the subjective Atmos effect will be similar, if not the same.
In other words a Height speaker (on wall or independently positioned) located at an 45° elevation will produce the same effect as a Ceiling speaker located at the same 45° elevation.
Now what would be the subjective Atmos difference between a 45° and 55° speakers elevation? This is something I'd personally like to experience... the same as comparing a complete 55° 4 speakers elevation configuration to another one composed with 4 Heights at 45° and 2 Tops located at @ 75° (a hemisphere-like configuration, which has my preference).
Then in a slightly different context, yesterday we went to see "Apes" in an Atmos Cinéma... and in French. As I was really curious to see (hear) how this movie would sound with a remixing in another language than its' original English.
And I must admit that we were quite pleased with what we heard, which was subjectively very "immersive". Is it better in English? I can't say. But for this movie, the Atmos mix in French is excellent.
Hugo
Name:	Dolby Atmos speakers layout.JPG
Hugo S is offline
post #3152 of 42773 Old 08-06-2014, 09:30 AM
Zen Traveler's Avatar
Quoted: 521 Post(s)
Liked: 530
Keith,
I am also curious about this. We currently have a 9.1 setup using Heights (about 9 ft up) with SS that are exactly parallel (and within 5 ft of the LP) and rears that are about 8 ft behind along with my second sub (limited placement issues). It's a about a 2,000 cu ft space where the MLP (only LP) is between 2 spaces/rooms.
We sit about 9.5 ft from the front soundstage which is also our Library so we have some natural room treatment but have a high cathedral ceiling (not symmetrical with the room). Behind the LP we have a small, 8 ft x 8 ft "cubby" with a slanted ceiling going from about 4.5 ft to 6ft towards the loveseat....Right above our heads is a shelf that is approx. 8ft up that we could attach some speakers, but seems to be the only practical place for atomos speakers, and if so I wonder how this layout would work with the new format. {Note: I understand that the cathedral ceiling isn't conducive).
Anyway, right now I use this HT primarily for Multichannel Music but both it and Movies sound awesome.
Zen Traveler is offline
post #3153 of 42773 Old 08-06-2014, 09:32 AM
Dan Hitchman's Avatar
Quoted: 3349 Post(s)
Liked: 1704
Has anyone actually parsed the wording of the new at home Atmos white paper?
What I find interesting is Dolby's use of the term "spatial audio coding" (psychoacoustic mixing?) and their mentioning that the Dolby TrueHD codec now has an attached fourth substream that contains a "losslessly encoded fully object-based mix."
Is Dolby saying what I think they're saying? That Dolby Atmos for the home is a pure object bitstream and not a hybrid channel+object format as in the cinema? I understand DTS had mentioned at earlier press events that MDA could also be delivered in a pure metadata infused object stream with no traditional channels. So, unless they were being cagey it seems as if the Blu-ray version has two separate lossless soundtracks... a channel based track and a pure object track. If someone knows differently, please correct my assumption.
They also mentioned that their new, efficient coding scheme via Dolby Media Producer software allows all the objects (and positional metadata?) from a theatrical mix to migrate to the near-field, home theater version.
I would also have liked for them to sketch out various potential speaker layouts and degrees and angles of separation for said speakers. Their one 24.1.10 diagram and explanation of "super Atmos" really doesn't go into very great detail like their cinema white paper. A more in-depth white paper should be created that goes into more of the technical nitty gritty for home Atmos installations.
One specification they did briefly mention was that true ceiling speaker dispersion patterns should be greater than 90 degrees x 90 degrees.
Listen up, studios! Just say "NO" to DNR and EE!!
Dan Hitchman is offline
post #3154 of 42773 Old 08-06-2014, 09:46 AM
bargervais's Avatar
Quoted: 1422 Post(s)
Liked: 660
My question... I see that most of the Blu-Ray's i have are DTS-HD Master Audio as the main audio... now is Dolby trying to replace those with Atmos or will DTS have it's own DTS UHD-will any of the new AVR include DTS UHD and Dolby Atmos HT?.... if i'm going to invest in an atmos receiver i want the ability to do both Atmos and DTS. or will i have to upgrade once more down the road.
DEN Atmos Samsung UN65KS8000 Roku Ultra Onkyo TX-NR 747 5.2.2 Atmos/DTS:X. Polk Audio OWM3 Speakers / top middle on Ceiling / Directv Genie / Samsung UBD-K8500 Blu-Ray Player / 26 UHD Blu-Rays Living Room Atmos Samsung PN60E8000+SEK2000 / Onkyo TX-NR 1030 7.2.4 /Onkyo M-5010 Amplifier for top middle/ Directv genie / Panasonic 3D blu-ray Bic Acoustech speakers, MICCA M-8S FH on wall /TM in ceiling speakers / 2 Bic F12 subs. BEDROOM Samsung 55JS8500 using tv speakers for now
bargervais is online now
post #3155 of 42773 Old 08-06-2014, 09:48 AM
FilmMixer's Avatar
Quoted: 1628 Post(s)
Liked: 1988
Originally Posted by markus767 View Post
Looks like near-field mix re-recording is an integral part of the Atmos home content creation workflow:
It is not "integral"... it's optional. That diagram only shows it can be integrated as it is now.
"Filmmakers frequently remix a film to sound its best in home theaters (a process known as the near-field mix). Spatial audio coding is a tool available during the near-field mix so that the filmmakers can hear exactly how the film will sound when it is encoded to Dolby Digital Plus for streaming or encoded losslessly in Dolby TrueHD for Blu-ray."
FilmMixer is online now
post #3156 of 42773 Old 08-06-2014, 09:48 AM
Liked: 1704
Originally Posted by bargervais View Post
My question... I see that most of the Blu-Ray's i have are DTS-HD Master Audio as the main audio... now is Dolby trying to replace those with Atmos or will DTS have it's own DTS UHD-will the new AVR including DTS UHD and Dolby Atmos HT?.... if i'm going to invest in an atmos receiver i want the ability to do both Atmos and DTS. or will i have to upgrade once more down the road.
I don't know if current Atmos receivers and pre-amps will be able to get a firmware update that adds DTS-UHD. Their chips seem to be pretty crammed to the gunnels as is.
post #3157 of 42773 Old 08-06-2014, 09:51 AM
noah katz's Avatar
Quoted: 843 Post(s)
Liked: 293
Originally Posted by SoundChex View Post
...We now replace the boomboxes with an Atmos BD on which the four boomboxes are four static object instances of the same recording. Because the objects all lie on the same radiant, a simplified VBAP algorithm would map the four objects to the same set of speakers, however the distance|time alignment correction for each of the four objects would be different.
I don't think anything different is needed at all; if the mixers want multiple of the same object to be at different distances they'll use the appropriate time delays.
And as I've said, I believe there are already just the two encoded variables of azimuth and elevation for locating the direction of an object, vs. just azimuth that we had before Atmos.
Noah
noah katz is offline
post #3158 of 42773 Old 08-06-2014, 09:54 AM - Thread Starter
markus767's Avatar
Quoted: 3344 Post(s)
Liked: 1197
Do I now get to choose which definition from Merriam Webster is closest to what I've meant to say?
http://www.merriam-webster.com/dictionary/integral
My point was that movie theaters and dubbing stages are acoustically different from living rooms and home theaters hence a remix is warranted. The Dolby paper even says "Filmmakers frequently remix a film". Do you have numbers how many theatrical mixes get the treatment? Will it be more in the future with Atmos?
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is offline
post #3159 of 42773 Old 08-06-2014, 10:01 AM
FilmMixer's Avatar
Liked: 1988
AFAIU No.. it is a bed + objects (7.1 + objects) and will be encoded as one bitstream (the objects in an extension.)
One TrueHD bitstream on a BR
Yes, but you still need to create a near field of the cinema master if desired... it isn't automatic (which isn't what you are implying at al, but I wanted to clarify..)
I believe they have a translation tool to create the DAMF from an RMU (theatrical) "wrapped" file if needed. I will see if I can get you more information on that.
Dan Hitchman likes this.
post #3160 of 42773 Old 08-06-2014, 10:10 AM
noah katz's Avatar
Quoted: 843 Post(s)
Liked: 293
I noticed in the Aug-dated Dolby paper that the bed for cinema Atmos is 9.1, which means some work is involved in going to a home, hopefully not enough to dissuade them from doing it.
Speaking of the nearfield mix, what's involved in creating it; anything more than response shaping?
Noah
post #3161 of 42773 Old 08-06-2014, 10:11 AM
Liked: 1704
Thanks for the clarification.
The way the white paper was written it seemed to imply that the substream contained a complete mix as objects rather than a hybrid approach. Hmmm... easy for the lay person to get confused.
post #3162 of 42773 Old 08-06-2014, 10:13 AM
kbarnes701's Avatar
Quoted: 6740 Post(s)
Liked: 5051
Originally Posted by Hugo S View Post
Bonjour Jeff,
Good points, Hugo. The White Paper is pretty explicit and I, like you, think that so long as the angles are respected, everything should be OK. What I want to explore with Dolby, if possible, is whether there is any degradation from using the Height Speakers and if so, then how much. The WP says that the suggested layouts are the "best" but the Front Heights are "supported". What I want to know is, really, how critical is it that we follow the angles to the letter and if people cannot, then what sort of degradation can they expect?
In my own HT I can follow their recommendations pretty well and remain 'on spec' if I use ceiling mounted speakers for the top fronts, but designate them as 'front heights' (staying all the time within the recommended angles of 30-45 degrees for front heights and also the recommended angles of 30-55 degrees for Top Fronts, by using an angle of 40 degrees - which is on spec for both sets of speaker layout). This will then mean that I can use my other pair of ceiling speakers with a designation of Top Middle (65-100 degrees). What I can't do is use the forward pair designated as Top Front, because you can’t use Top Front and Top Middle, and I cannot achieve the required angles for Top Rear. But Front Height (even though they are on the ceiling) can be used with Top Middle, so that is what I am hoping to do. I am hoping I can get some better info from the Dolby guys than is in the WP.
kbarnes701 is offline
post #3163 of 42773 Old 08-06-2014, 10:15 AM
bargervais's Avatar
Liked: 660
Are studio's going to abandon using DTS In favor of atmos or will they live side by side like DTS HD master audio and Dolby 5.1 do now. Or Instead of Dolby 5.1 will it have Atmos in its place....
post #3164 of 42773 Old 08-06-2014, 10:16 AM
SoundChex's Avatar
Quoted: 345 Post(s)
Liked: 291
Unfortunately Pulkki's paper doesn't address the question I raised because it's really an implementation technology issue: Dolby must attempt to perform as much "pre rendering" before|during the BD authoring process as possible in order to minimize the computational load imposed on the AVR. Just how much can be achieved depends on which rendering calculations are independent of the AVR and speaker configuration, plus listener choices at playback time. I can't tell if object time|distance (or real|apparent volume) normalization can be partially|fully performed before the BD is authored (and even if it could be under the current "architecture", to what extent Dolby chose to do so|not do so in order to avoid foreclosing possible rendering algorithm "upgrades" in the future...?!)
_
[Home Office system schematic]
"My AV systems were created by man. They evolved. They rebelled. There are many speakers. And they have . . . A PLAN."
SoundChex is online now
post #3165 of 42773 Old 08-06-2014, 10:19 AM - Thread Starter
markus767's Avatar
Liked: 1197
Here's a paper explaining the concept of extensions:
http://www.dolby.com/us/en/technolog...hite-paper.pdf
Markus
post #3166 of 42773 Old 08-06-2014, 10:20 AM
Liked: 1704
God only knows what goes on in the studios' heads. If it takes more time and money to prep a home Atmos version that hasn't already been accounted for in a movie's budget, I don't know how supportive these studios will be. Will it be a trickle or will it be a landslide? Will this finally supplant traditional channel based approaches of delivery audio? Who knows...
No one outside the industry seems to know what DTS has planned to answer Dolby's home Atmos format or if DTS-UHD can be easily added to the current crop of Atmos products.
post #3167 of 42773 Old 08-06-2014, 10:20 AM
Kris Deering's Avatar
Quoted: 1415 Post(s)
Liked: 2107
Originally Posted by kbarnes701 View Post
Not many. It is common on AVS for people to confuse "niche market" with "no market". Let me ask you a different, but illustrative, question: Q: How many consumers will run out and buy a Lamborghini?. A: not many. Does that mean Lamborghini should pack up their business and start making $13,000 SUVs?
True but Lamborghini is also charging what amounts to an insane markup on the car due to the volume of sales it has and the demand for that small volume. We see this from niche audio brands all the time, but in most cases with audio you are paying for manufacturing inefficiencies. With Atmos you aren't really paying a premium as you've already pointed out before, so Dolby is making their money by hoping that every AVR and pre-pro company will want to license the tech to have the badge on it regardless of whether the end user needs or wants it. They've already been doing this for years and years with all the other DSP stuff.
Now whether Hollywood reacts the same way is the question. Hopefully they just start putting these soundtracks on by default so they are there if you need them but transparent if you don't. That would be the best you could hope for. If they try to do a special market like they do for 3D where you have to pay a premium for it the results could backfire if there isn't enough market and it could eventually become an issue due to lack of volume in sales. I'm REALLY hoping that they just start including these soundtracks as the default for movies that have an Atmos mix, then sales volume won't really matter.
My Home Theater
Kris Deering is offline
post #3168 of 42773 Old 08-06-2014, 10:26 AM
Liked: 1704
I understand the core+extension approach of DTS and Dolby's codecs, however the language used in the lastest white paper for the Atmos "substream" could leave one with the impression that it contains a full soundtrack encoded as metadata+objects only. That, after all, was always a possibility as a means to deliver soundtracks without using channels.
post #3169 of 42773 Old 08-06-2014, 10:28 AM
Nightlord's Avatar
Quoted: 693 Post(s)
Liked: 233
Given the 24.1.10 maximum number of speakers, I guess you could code how much of each object is going into each 'ideal' speaker... And then you create a translation in the avr on how to transcode those ideal channels into what you've got. Should not require much computing power. If it works? No idea, but that would be my initial attempt at getting it to work...
Under construction: the Larch theater
Nightlord is offline
post #3170 of 42773 Old 08-06-2014, 10:28 AM
kbarnes701's Avatar
Liked: 5051
I hope so too. AFAIK, sound has never commanded a price premium, either in commercial cinema or HT, so I am expecting an Atmos BD will cost the same as a current DTS-HD MA or TrueHD BD. We'll know soon enough...
post #3171 of 42773 Old 08-06-2014, 10:33 AM
Liked: 1704
Actually, Atmos does command a higher price per ticket because theater owners have wrapped it within their "premium" auditorium pricing structure. It used to be that giant screen auditoriums were just standard ticketed items, but not any more.
It boils down to whether or not the studios will look at Atmos and DTS-UHD on home video the same way.
post #3172 of 42773 Old 08-06-2014, 10:37 AM
FilmMixer's Avatar
Liked: 1988
Today I would guess the number is 75-80%.
Don't expect the number to change because of Atmos. However, I suspect some of the initial release will not be due to the simple fact that there are very few studios setup to do so at this point. We're sciguring this out now.
post #3173 of 42773 Old 08-06-2014, 10:43 AM
sdurani's Avatar
Quoted: 4263 Post(s)
Liked: 2717
I think TrueHD has used 3 substreams so far: a 2-channel lossless core, the audio data and instructions needed to reconstitute a lossless 5.1 mix, the audio data and instructions needed to reconstitute a lossless 7.1 mix.
The next substream will carry objects. Wonder if it might also carry the audio data and instructions needed to reconstitute 9.1 lossless channels (height beds)? Or has Dolby decided to limit the home version to 7 bed channels?
Don't know how Dolby is using the term "spatial audio coding", but here is what it means to MPEG, as applied to objects: http://mpeg.chiariglione.org/standar...-object-coding
This could get into semantics, since it could be argued that channels are objects that don't go anywhere.
They can play with object parameters (size, location, etc) to mimic a channel.
Interesting they say "all" without actually giving a number.
What's to sketch out? There are 24 possible speaker locations "on the floor" (their short-hand for non-height speakers). 360 ÷ 24 = 15 degrees. You can either think of it as a possible speaker location every 15 degrees or 24 zones of 15-degree arcs (bit of flexibility in placement).
If receivers don't end up allowing you to measure actual speaker angles, like Trinnov or Yamaha does, then I think the diagram in the whitepaper would make a nice interface in the receiver's speaker set-up menu.
Of the 24 possible locations, users simply click to highlight the locations of their 2, 5, 7, 9 or however many speaker they have. Doesn't have to be super precise, just pick the potential locations in the graphic that most closely match the physical locations of your speakers.
Sanjay
sdurani is offline
post #3174 of 42773 Old 08-06-2014, 10:46 AM
chi_guy50's Avatar
Quoted: 1169 Post(s)
Liked: 567
Bonjour Jeff,
Hugo
Salut, mon vieux!
Nous sommes tout à fait d'accord sur ce point. But it will be interesting, from both the technical and marketing aspect, to hear how the Dolby rep addresses this issue. There has been some discussion here on whether Dolby is targeting a "niche of a niche" market. I don't believe that they are; but if they push the angle of "You must have either Dolby speakers or tops to truly appreciate Atmos," then I think you will have your answer. But more than anything, I would like to hear their rep assess in as much detail as possible the results over a "traditional" 9CH or 11CH layout. Jeff
That is precisely what motivated me to pose the question.
chi_guy50 is offline
post #3175 of 42773 Old 08-06-2014, 10:46 AM
SoundChex's Avatar
Quoted: 345 Post(s)
Liked: 291
Congratulations! You have pretty much reinvented the downmix capability strategy employed with Hamasaki 22.2 audio as it is currently being implemented by NHK Japanese TV as the audio component of their forthcoming SHV broadcast technology. (Nonetheless, it seems they may still intend to implement a hybrid channel|object-based audio delivery mechanism in the form of (possibly only static) user-interactive objects.)
_
post #3176 of 42773 Old 08-06-2014, 10:52 AM
J_Palmer_Cass's Avatar
Quoted: 393 Post(s)
Liked: 118
Originally Posted by JohnAV View Post
Doing a Atmos mix for a theater release makes sense, but practicality aside, whats in it for the studios to produce BD's that support Atmos nevermind if it is easy or cheap?
How many consumers at this point in time will to run out and buy a minor re-release or a new release that offers a Atmos coded track over a 5.1/7.1 release? Probably not enough to make the studio even consider it yet.
I just don't see any tidal wave happening with this. Hell the industry kinda blundered 3D, has over promised with 4K, and now Dolby thinks 3D sound is a cakewalk, I don't so.
I am not sure if Atmos will gain traction in a home setting in the near future. However, if Atmos becomes a standard no cost option in every AVR then a lot of people will play around with it. Then again, will all Atmos decoders be "the same" or will their be Atmos decoder "tiers"?
A lot of people do not even use a dedicated 5.1 sound system with their large screen TV sets.
As a side note I have a 3D capable bluray player and 3D capable TV, but I have never watched a 3D encoded movie at home. Not sure if I ever will either.
J_Palmer_Cass is offline
post #3177 of 42773 Old 08-06-2014, 10:57 AM
sdurani's Avatar
Liked: 2717
Yup, one of the local Atmos installs (Buena Park) is not in a premium auditorium, so the ticket price is the same as the rest of the multiplex, irrespective of whether they are showing an Atmos movie or not. Can't beat an Atmos matinee for just $7.50 (if you can handle the re-cycled Styrofoam they sell as "popcorn").
Scott Simonian likes this.
Sanjay
sdurani is offline
post #3178 of 42773 Old 08-06-2014, 10:58 AM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5073 Post(s)
Liked: 4000
Nachos, my good friend.
*whispers* Nachos...
ambesolman likes this.
Scott Simonian is offline
post #3179 of 42773 Old 08-06-2014, 11:02 AM
sdurani's Avatar
Liked: 2717
^^^ Mmmm, nachos. Can drink the cheese sauce as a beverage.
Sanjay
sdurani is offline
post #3180 of 42773 Old 08-06-2014, 11:05 AM
Quoted: 393 Post(s)
Liked: 118
It doesn't matter if I have Gone with the Wind in 7.1 even though it wasn't originally. As it exists on disk it is a true 8ch signal.
It may be a true 8 channel signal, but that does not make it a true 8 channel mix.
