The official Dolby Atmos thread (home theater version) - Page 145 - AVS Forum | Home Theater Discussions And Reviews
 16692Likes
post #4321 of 44994 Old 08-16-2014, 02:56 AM
kbarnes701's Avatar
Quoted: 6761 Post(s)
Liked: 5112
Originally Posted by Zen Traveler View Post
If you are talking about having Front Height speakers in the same location I've been using them for PLIIz that is great news for me as well...also if Top Middle means right above our MLP we could be good to go.
If your existing Front Heights fall within the angle range of 30-45 degrees, then you can leave them where they are, and add another pair of top speakers and you are good to go. That other pair could be Top Middle, and the range for TM is 65-100 degrees, so do a quick diagram of your room and see where they fall in relation to your seating position.
Thanks Keith for all of your effort and excitement.
Kind of you to say so - thanks.
kbarnes701 is online now
post #4322 of 44994 Old 08-16-2014, 02:56 AM
Quoted: 55 Post(s)
Anybody care to speculate if these upcoming Atmos soundtracks will retain the original volume level when played on a non-Atmos 7 ch AVR or will there be attenuation, like when 7.1 tracks get lowered by 3dB on 5 ch AVRs?
luca_frontino is offline
post #4323 of 44994 Old 08-16-2014, 03:02 AM
kbarnes701's Avatar
Liked: 5112
Originally Posted by Roger Dressler View Post
Could you tell how the in-ceiling speakers were oriented? Were they straight down as in previous demos, or aimed toward the MLP? If the former, thus far we have not heard of a demo where the ceiling speakers were aimed toward the MLP. Would that not factor in at all?
They were pointing directly down, Roger. They also looked, as far as I could tell from a quick glance when the AT cover was briefly pulled back, as if they were conventional designs and not dual concentrics. I am expecting, as you are, that DC designs, with a wide, 90 degree all-round dispersion, oriented towards the MLP, will make a good difference and perhaps close the gap between the spaciousness of the Atmos speakers and the in-ceiling speakers I heard at both my demos. Then we will have the best of both worlds - the terrific spaciousness which the Atmos speakers create, plus the extra precision which the ceiling speakers create.
post #4324 of 44994 Old 08-16-2014, 03:06 AM
kbarnes701's Avatar
Liked: 5112
Originally Posted by chi_guy50 View Post
Well, not really. I believe FilmMixer said that he remains skeptical regarding the use of heights in any configuration for Atmos rendering. I'd still like to hear more on this subject from him unless it's moot pending an actual demo.
I believe he was referring to Heights mounted in the conventional 'height position' (ie top of the front or rear wall). You can of course mount a speaker on the ceiling and designate it as Front Height or Top Front thanks to the angle overlap: 30-45 vs 30-55 respectively.
Denon and Dolby say that their posted combinations will work well, even when FH speakers are used in the regular FH position, which is closer to the 30 degrees than anything else. Personally, I feel that the speakers should all be on the ceiling for the best result, even if one pair is designated in the AVR as Front Height, and I suspect that is what Marc meant. No doubt he will confirm or otherwise in due course.
post #4325 of 44994 Old 08-16-2014, 03:08 AM
kbarnes701's Avatar
Liked: 5112
Originally Posted by Hugo S View Post
Bonjour Keith,
BRAVO + merci².
Amts,
Hugo
Merci bien, Hugo. Rien du tout!
And thanks for the nice mention on the French AV site too!
post #4326 of 44994 Old 08-16-2014, 03:32 AM
kbarnes701's Avatar
Liked: 5112
Originally Posted by westmd View Post
What I find quite odd about the Denon diagram is the height level of the side surrounds. From my knowledge they should be quite high in the room. (I have a Jamo THX setup and they suggest min. 2 meters). Question is now if Denon always suggested to bring side surrounds at ear level or if this an "Atmos effect" as airspace now belongs to the ceiling/Atmos speakers?
At both demos I have attended the surrounds were all at ear height. The reason, I believe, is to create the maximum separation between the surrounds and the ceiling speakers (or just the ceiling in the case of Atmos speakers). The requisite phantom imagine between 'sets' of speakers won’t work well if some of the speakers are very close to some of the others - eg if the surrounds and the Top Rears are only separated by a couple of feet.
I am lowering my own surrounds for this reason. Incidentally, if more than one listener has to be considered it may be worth lowering the surrounds but still ensuring that they fire over the heads of the listeners, to prevent a listener on the left from having the surround speaker 'blocked' by the listener to the right, and vice-versa.
post #4327 of 44994 Old 08-16-2014, 04:03 AM
Kwikas's Avatar
Quoted: 52 Post(s)
Liked: 27
I think this might have been covered earlier in the thread but I can't locate it.
Can someone tell me.....what happens if you put 5 screen speakers up front? I believe atmos does/can allow for this.
Kwikas is online now
post #4328 of 44994 Old 08-16-2014, 04:16 AM
kbarnes701's Avatar
Liked: 5112
In the cinema but not, AFAIK, at home. At home, typical screen widths would make it less useful than in a cinema where the screens are so much wider.
Dolby may have allowed for it in the home Atmos spec, but the real question is whether any AVR manufacturers will enable it as an option. So far, none of the mainstream manufacturers has.
post #4329 of 44994 Old 08-16-2014, 04:18 AM
ss9001's Avatar
Quoted: 347 Post(s)
Liked: 415
since the Atmos objects are metadata and contained in the existing TrueHD /DD+ track, I would expect no change. non-Atmos AVR's will ignore the metadata & just process the TrueHD track as they normally would. that's my interpretation.
remember, part of Atmo is still the 7.1 conventional channels anyway.
kbarnes701 likes this.
Steve
ss9001 is offline
post #4330 of 44994 Old 08-16-2014, 05:56 AM
erwinfrombelgium's Avatar
Quoted: 438 Post(s)
Liked: 236
The reason for the recommended 6' height was that this height allowed for a more immersive soundfield within the limitation of only one available surround height. Now there are two heights, this no longer holds value.
As Keith wrote, the effect will be less if the side Surounds and Overheads are very close to each other.
Think of it as a hemisphere where you try to spread out the speakers as even as possible, but within the guidelines of Atmos and the way it's implemented into the hardware at this point. Meaning you cannot put speakers anywhere it suits you, since the positions are preset into the hardware. It may come, though, if the processor can figure out where you have put the speakers via triangulation from multiple microphone points in the room.
Building a 9.3.4 HT: DIYSG Titan LX [LCR] • Cinema 10 Max [6 Surrounds] • Beta 10CX custom [TF+TR] • LLT Mal-x 18" subs [2] • XPR-5 • MM8003 [8ch] • XMC-1 [RMC-1 wanted] • PT AT6000E • 130" Seymour Center XD • Oppo 103EU • WTB: 1 extra Mal-x 18" SW
erwinfrombelgium is offline
post #4331 of 44994 Old 08-16-2014, 06:18 AM
tjenkins95's Avatar
Quoted: 410 Post(s)
Liked: 335
Originally Posted by bargervais View Post
Totally agree look at gravity incredible sound and video but the movie was horrible
It received a 97% rating among viewers and all of those awards so you must have been in the 3% that didn't like it.
www.raysdvds.org
Denon AVR-X6200W; JVC RS500; Panasonic DMP-UB900; Oppo UDP-203;
Klipsch Speakers: RF-82, RC-62, RS-52, RB-61, RT-10d sub, Klipsch CDT-3650-C (4) ceiling.
Pioneer Dolby Atmos enabled Elite Concentric Speakers: SP-EFS73, SP-EBS73, and SP-EC73 in the guest room.
tjenkins95 is offline
post #4332 of 44994 Old 08-16-2014, 06:30 AM
J_Palmer_Cass's Avatar
Quoted: 393 Post(s)
Liked: 118
http://www.huffingtonpost.com/2014/0...ef=mostpopular
Dan Hitchman likes this.
J_Palmer_Cass is offline
post #4333 of 44994 Old 08-16-2014, 06:35 AM
Nightlord's Avatar
Quoted: 733 Post(s)
Liked: 253
Well, I doubt avs constitutes as much as 3% of the population, so there you have it.
Haven't seen it yet, but since that guy also dislikes matrix and avatar, I would not grant him a second more of attention for the remainder of my life..
tjenkins95 likes this.
Codename - the Larch theater
Nightlord is online now
post #4334 of 44994 Old 08-16-2014, 06:35 AM
tjenkins95's Avatar
Quoted: 410 Post(s)
Liked: 335
Originally Posted by J_Palmer_Cass View Post
That's only one person's opinion and obviously another member of the 3%.
www.raysdvds.org
post #4335 of 44994 Old 08-16-2014, 07:19 AM
kriktsemaj99's Avatar
Quoted: 648 Post(s)
Liked: 367
Originally Posted by kbarnes701 View Post
With regard to hardware, I asked Stephen and JJ some questions about the way Atmos is being implemented in current AVRs from the mainstream manufacturers such as Denon, Onkyo, Yamaha and Pioneer.
JJ went into some detail to answer my question concerning the angles that the rendering engine will render to and how current units handle this. JJ confirmed that Dolby are giving full capability to the AVR manufacturers to be able to use full speaker positional information. It is entirely up to the manufacturer to implement this or not, either by allowing the user to enter details manually or allowing the AVR to handle it through the measuring process which is part of the setup routine. Currently, as we know, none of the mainstream manufacturers is giving us this capability in their first generation Atmos units.
I'm beginning to think Yamaha might surpise us with the RX-A3040, because why else would they have just modified their angle meaasuring device? They've measured angles for years but only using 3 mic positions, and now they added a 4 position out of the plane so they can measure everything needed by Atmos. So for sure they will be measuring actual speaker angles, and if the rendering engine can use this information it's trivial for them to make use of it.
Also adding Atmos support in a later FW update means they can keep their powder dry and spring this as a surprise after everyone else is committed to fixed angles.
kriktsemaj99 is offline
post #4336 of 44994 Old 08-16-2014, 07:22 AM
Nightlord's Avatar
Quoted: 733 Post(s)
Liked: 253
Originally Posted by kriktsemaj99 View Post
I'm beginning to think Yamaha might surprise us with the RX-A3040, because why else would they have just modified their angle meaasuring device? They've measured angles for years but only using 3 mic positions, and now they added a 4 position out of the plane so they can measure everything needed by Atmos. So for sure they will be measuring actual speaker angles, and if the rendering engine can use this information it's trivial for them to make use of it.
Very interesting. Yamaha has never been in the game for me before, but perhaps they just got into it.
post #4337 of 44994 Old 08-16-2014, 07:28 AM
westmd's Avatar
Quoted: 803 Post(s)
Liked: 272
So how do I use this Denon sheet exactly? I calculated that if I would go for installing front heights at between 45 and 30 degrees to the main listening position I would have a distance between 170 and 207 cm as distance between main listening position and ceiling is around 120 cm. Now my main speakers are at about 400 cm distance to the listening position. That means I would have to install the front heights somewhere in the middle between main listening position and main speakers. Are these tboughts correct?
BTW I found a really nice tool to calculate distances from the angles. It is in german but I think self explanatory:
http://www.arndt-bruenner.de/mathe/s...rechnungrw.htm
westmd is offline
post #4338 of 44994 Old 08-16-2014, 07:33 AM
kbarnes701's Avatar
Liked: 5112
I loved everything about it. I found it to be one of the most involving, immersive movie experiences of the year. I was on the edge of my seat half of the running time. The incredible sound and visuals perfectly complemented the story IMO. And to hear it in Atmos... well....
nucky likes this.
post #4339 of 44994 Old 08-16-2014, 07:35 AM
kbarnes701's Avatar
Liked: 5112
I do hope you are right. It would be great to see at least one of the mainstream manufacturers using the features Dolby have provided.
post #4340 of 44994 Old 08-16-2014, 07:40 AM
kbarnes701's Avatar
Liked: 5112
I've been a longtime fan of Yamaha going back decades. My very first 'proper' stereo amplifier was a Yamaha, decades ago. I sold it to a friend in the late '70s and, amazingly, he still uses it to this very day. How's that for build quality?
I only moved away from Yamaha with the advent of AV units because I attach so much importance to Audyssey's XT32 in my system. I am sure that if Yamaha had XT32, it would be my go-to brand. I am not all that familiar with the latest version of YPAO but I understand that it is much improved over earlier incarnations. Add that to the ability to measure speaker locations (if this comes off) and Yamaha might just be coming back on to the radar of a lot of people.
post #4341 of 44994 Old 08-16-2014, 07:42 AM
westmd's Avatar
Quoted: 803 Post(s)
Liked: 272
Thanks. Yes, so long as you are within the required angle specification (30-45 degrees for Front Height) then you can use them in any combination allowed by your AVR. The permitted combinations which Denon are offering are:
Front Height + Top Middle
Front Height + Top Rear
Front Height + Rear Height
Top Front + Top Rear (default)
Top Front + Rear Height
Top Middle + Rear Height
Dolby have now confirmed, and even praised Denon for the fact, that those combinations will all work well.
So that means Dolby Atmos would be possible with neither ceiling speakers nor Dolby Atmos enabled speakers just by using front and rear heights at an angle firing about straight into your direction. This could solve my "low ceiling dilemma" as ceiling height should not matter that much! I wonder how this will sound!
And if the next gen of processor come out and support more channels I buy 4 Dolby Atmos enabled speakers additionally!
westmd is offline
post #4342 of 44994 Old 08-16-2014, 07:44 AM
bargervais's Avatar
Quoted: 1598 Post(s)
Liked: 962
For me too Hollywood Sandra Bullock almost dies, I don't know how many times to miraculously make it then get to that Chinese space station and reenter the atmosphere..
Remember she was tumbling in space out of control screaming and flailing she should have died then.
The sound and video were amazing and that's what got me through it but the content was just too unbelievable..
DEN Atmos Samsung UN65KS8000 Roku Ultra Onkyo TX-RZ710 5.2.2 UHD audio. Polk Audio OWM3 Speakers / top middle on Ceiling / 300MGB Spectrum / Samsung UBD-K8500 Blu-Ray Player / 26 UHD Blu-Rays Living Room Atmos Samsung PN60E8000+SEK2000 / Onkyo TX-NR 1030 7.2.4 /Onkyo M-5010 Amplifier for top middle/ 300MGB Spectrum / Panasonic 3D blu-ray Bic Acoustech speakers, MICCA M-8S FH on wall /TM in ceiling speakers / 2 Bic F12 subs. BEDROOM Samsung 55JS8500 using tv speakers for now
bargervais is offline
post #4343 of 44994 Old 08-16-2014, 07:48 AM
kbarnes701's Avatar
Liked: 5112
Yes, you are correct. In my room, using a 42 degree angle from the MLP, the Top Front or Front Height speakers on the ceiling fall in between the MLP and the front wall, which is perfect.
I just drew a scale rectangle on a piece of paper, using the scale 1mm = 2cm, to represent the room, measured where my ears are in the room and marked them on the diagram and then used my schoolboy protractor to draw a line at the relevant angle until it intersected the ceiling. Easy then to measure the distance from that point to the front wall - and bingo - you have your speaker position. If it isn't quite where you want it, then repeat using any angle in the permitted range for the speaker pair you are concerned with and you are good to go. Then repeat the whole process for the Top rear or Top Middle etc...
post #4344 of 44994 Old 08-16-2014, 07:49 AM
westmd's Avatar
Quoted: 803 Post(s)
Liked: 272
My first Dolby surround unit was also from Yamaha in the early nineties. Then I moved to Lexicon but they have just become too slow so I am looking into Yamaha again. I am going to the IFA in Berlin in three weeks where Yamaha apperently will announce /demonstrate a CX A5000 sucessor which will have Dolby Atmos!
westmd is offline
post #4345 of 44994 Old 08-16-2014, 07:55 AM
kbarnes701's Avatar
Liked: 5112
In Denons at least, and supported by Dolby for Atmos, you can use Front Height and Rear Height speakers so long as they comply with the angles to the listening ears which are laid down in the specs (see the oft-posted diagram).
Both FilmMixer and myself have recently commented that this configuration might not be as effective as overhead speakers, but neither of us has currently heard such a configuration so we could be surprised. And Dolby specifically support that configuration so it must be, at the very least, a reasonable way to go or, presumably, it would not be a supported configuration. In my reply to this specific question (see my report) Stephen from Dolby said that while they (Dolby) are recommending a 'standard' configuration (using Top Front, Top Middle and Top Rear in 5/7.1.2 or 5/7.1.4 configurations) they also allow for the full Atmos experience with other configurations and indeed he commended Denon for making these other configurations available.
In your case, with your room, the configuration you are considering might be less than ideal, but still much better than no Atmos at all. I wish you well with it and would love to read a report of how it sounds if you do go that way.
post #4346 of 44994 Old 08-16-2014, 08:00 AM
Nightlord's Avatar
Quoted: 733 Post(s)
Liked: 253
Me too - for synthesizers....
I guess they have had too many syntheics hall/concert modes for meto pay attention
post #4347 of 44994 Old 08-16-2014, 08:06 AM
sdurani's Avatar
Quoted: 4728 Post(s)
Liked: 3141
Just don't be surprised when speakers in front of you and behind you don't sound like they're above you.
Sanjay
sdurani is offline
post #4348 of 44994 Old 08-16-2014, 08:07 AM
kbarnes701's Avatar
Liked: 5112
'Believability' isn't a requirement for my enjoyment of a movie. How else would I enjoy Marvel Comic Universe movies, for example, or The Hobbit and thousands of others where a suspension of disbelief is not just desired but mandated? Suspension of disbelief requires that you accept that she did NOT die (in the movie) when hurtling through space, just as you accept in Superman that a man can fly. It is absolutely 'unbelievable' that a man can fly but we suspend that disbelief to allow ourselves to be entertained. Similarly, in, for example, Skyfall, it is 'unbelievable' that an MI6 agent and a foreign agent can engage in hand to hand combat on a moving train in the way they do, but we can still enjoy that part of the movie immensely thanks to this ability to suspend disbelief when watching a play or a movie.
post #4349 of 44994 Old 08-16-2014, 08:09 AM
bargervais's Avatar
Liked: 962
I have had yamaha and denon for years then I tried onkyo I love my TX-NR 818 has been a workhorse I have it hooked up to 11 speakers and two subs the 818 can only do 9.2 I use a amp to drive my wides I rarely use my back speakers mostly use just the 9 speakers from the front highs to the surrounds.
I just replaced my TX-NR 616 in the den with a TX-NR 737 and once the atmos firmware update comes out hopefully next month. I'll have it run 5.2.2 with ceiling speakers top middle. I got the 737 at a good price and I was very curious about Accu-EQ I just don't believe how it's that horrible it's made out to be, I've always loved Audyssey XT32. But I wanted just too see what Accu-EQ was all about I won't bad mouth it till I have first hand use of it.
post #4350 of 44994 Old 08-16-2014, 08:09 AM
kbarnes701's Avatar
Liked: 5112
But you don't have to use them. I'd say more than half the features on my Onkyo 5509 have never been used (by me).
