The official Dolby Atmos thread (home theater version) - Page 16 - AVS Forum | Home Theater Discussions And Reviews
 17825Likes
post #451 of 46732 Old 07-03-2014, 06:57 PM
chi_guy50's Avatar
Quoted: 1629 Post(s)
Liked: 1364
Originally Posted by ahmedreda View Post
Received my .4 speakers today. Going to wait for more details before installing them.
Nice choice. I'm using the 80F/X-RT's (from the same series) as surrounds and they are fabulous.
chi_guy50 is online now
post #452 of 46732 Old 07-03-2014, 09:50 PM
Orbitron's Avatar
Quoted: 503 Post(s)
Liked: 389
New Blu-ray titles will have the Dolby Atmos. Can the studios also remaster older titles to include Atmos?
Orbitron is offline
post #453 of 46732 Old 07-03-2014, 10:04 PM
DaJoJo's Avatar
Quoted: 355 Post(s)
Liked: 784
Originally Posted by Dan Hitchman View Post
Some of the literature for the newer Atmos "friendly" professional speakers talk about "wide dispersal" patterns. Models like the Klipsch surrounds use a kind of dual driver/bipolar configured tweeter assembly with a single woofer.
only the rs-42(II) use 1 woofer, the 52 and 62 use 2 woofers. wide dispersion patterns doesn't neccesarily mean wide radiating. besides that, the placement is in the corners and from bi-polar speakers you get sounds bouncing to the side-walls which to me doesn't benefit the soundfield for atmos and the positional soundfield they need to create.
Klipsch fronts 2xRF-82-II 150W 33Hz-24KHz , center RC-64-II 200W 59Hz-24KHz , sides 2xRS-62-II 150W 50Hz-24KHz , rears 2xRB-81-II 150W 44Hz-24KHz , heights 2x Salora T25i
Yamaha RX-A3040, SVS PB13-Ultra 1000W 14-200hz
4 mm el cheapo wire / Samsung UE-ES8000S TV+evo 2014 / Optoma DH-1015 Sony PS3
DaJoJo is offline
post #454 of 46732 Old 07-03-2014, 10:07 PM
Dan Hitchman's Avatar
Quoted: 3561 Post(s)
Liked: 1904
If the original audio stems and individual sound elements are still available, sure they can. It's just like a fancier remix. Dolby experimented with the original (and best) "Die Hard" using Atmos.
Listen up, studios! Just say "NO" to DNR and EE!!
Dan Hitchman is offline
post #455 of 46732 Old 07-03-2014, 10:12 PM
DaJoJo's Avatar
Quoted: 355 Post(s)
Liked: 784
they can but probably won't as it involves a redo of the audio tracks. i think movies that have been in a atmos theater and have a object based master allready will be re-issued in blu-ray format atmos though, ther is a soon to come huge market for them. you can also use the avr's surroundprocessors to create a atmos alike soundfield for older movies.
DaJoJo is offline
post #456 of 46732 Old 07-03-2014, 10:33 PM
Liked: 1904
From Klipsch's pro website, the VBAT surround models KPT-8-VB and KPT-12-VB have bipolar-like tweeters that fire in different directions (maybe not as wide a swath as a true bipole) with a single woofer. They say they're designed for the new audio formats like Atmos. There is, however, a much larger three-way KPT-4350-MS for really large auditoriums with dual woofers and dual tweeters.
post #457 of 46732 Old 07-04-2014, 07:33 AM
Ethan Ong's Avatar
I'm just wondering.
Currently my set-up is 9.2 (i.e. 7.2 + front height).
If I were to use 5.2.4, does it mean that in future when playing a blu ray movie encoded with 7.1, I'll lose the rear surround effect?
Ethan Ong is offline
post #458 of 46732 Old 07-04-2014, 08:24 AM - Thread Starter
markus767's Avatar
Quoted: 4238 Post(s)
Liked: 1647
Yes. It will be redirected to the side surrounds.
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is offline
post #459 of 46732 Old 07-04-2014, 08:44 AM
Mike Garrett's Avatar
Quoted: 7073 Post(s)
Liked: 4779
Originally Posted by Sevenfeet View Post
True, but Dolby also specifies what the "recommended" configuration is for commercial environments versus "minimum" So a theater might have a recommendation speaker number of 30 points while having a number of 19 speakers you could conceivably get away with. And I'm sure we'll see some residential processors before too long that go for the 19 number that will certainly be cheaper than a high end one that allows 32.
One other thing about Atmos I've been thinking about. The system will obviously be a boon to customer installers. But not everyone is going to have a setup that will allow Atmos. There's an assumption in every diagram I've seen that says that people all have flat ceilings in their theater rooms. Many of us have vaulted ceilings. That would pose problems for most in-ceiling speaker designs, even for ones that allow some manual direction of the drivers. And reflective speakers on the ground wouldn't work at all.
And I've seen theaters in a couple of friends' McMansions that are located at the top of the house, underneath the main roof gable. The problem here is that often the ceilings are designed to be a pointed gable system too, which is just like having a vaulted ceiling, except you have 2 or 4 vaults to deal with. A solution might be to add a flat ceiling to the design at some point....a barn style ceiling as it were. My bonus room where my theater is has such a ceiling which would make installing ceiling mounted speakers possible. It would be a larger construction job, but if you have the budget, it may make sense for some people.
Speakers mounted on drop tubes, so that the speakers are in the correct position.
mjgarrett100@gmail.com
Mike Garrett is offline
post #460 of 46732 Old 07-04-2014, 08:53 AM
Schwa's Avatar
Quoted: 1122 Post(s)
Liked: 1172
I'm just wondering.
That's the way I understand it. However, per Denon's speaker positioning documents, front height speakers (assuming you're using bookshelves or in-walls on or close to the front wall aimed at the listening position) aren't in the proper location or configuration for Atmos.
I also have a 7.2 setup with two traditional front height speakers. I'm going to install an additional two in-ceiling speakers directly above the MLP. I'll then essentially have two speaker configurations to choose from -- one that uses the traditional 7.2 + front height speakers for DPLIIz/DSX/Neo:X, and one that uses the traditional 7.2 + in-ceiling speakers for Atmos.
Schwa is offline
post #461 of 46732 Old 07-04-2014, 09:15 AM
sdurani's Avatar
Quoted: 5133 Post(s)
Liked: 3613
Denon's speaker positioning documents don't make sense when it comes to separating Height speakers (for Neo:X) from Top speakers (for Atmos).
For example: Height speakers can have anywhere from 30° elevation to 45° elevation while Top speakers can have anywhere from 30° elevation to 55° elevation. That's some overlap!
If the Denon document is to be believed, Atmos won't use a Height speaker mounted 45° up but will use a Top speaker mounted 45° up. Same speaker, same location.
Sanjay
sdurani is online now
post #462 of 46732 Old 07-04-2014, 09:31 AM
Schwa's Avatar
Liked: 1172
They make sense to me because I assume that height speakers and top speakers won't be used (maybe installed, but not used) at the same time. I think this is a reasonable assumption to make because Denon's document shows more than 11 speaker positions but we know that even the top-of-the-line Denon can't control more than 11 speakers at a time. Plus, Atmos "top" speakers are supposed to be in-ceiling, down-firing whereas height speakers are more traditional on-wall, in-wall, or bookshelf speakers. Nor could you since height speakers are typically mounted on-wall/in-wall whereas top speakers are in-ceiling.
IMO the overlap in the recommended speaker locations allows for more placement flexibility while preserving acceptable performance. Just because there's an overlap doesn't mean that their recommendations aren't valid. Some common sense has to be applied when installing speakers. If you want to use both heights and top speakers, clearly you can't install them both in the same location.
Schwa is offline
post #463 of 46732 Old 07-04-2014, 09:35 AM
Liked: 4779
Originally Posted by thebland View Post
So much so fast. I've been redoing my room over the last few monthsn and I'm now redesigning my baffle wall, and height speaker placement SINCE THE ATMOS news.
I had all planned and designed for front heights in the baffle wall behind the screen but now, in my readings and consulting with my designer, going to bring those front heights forward of my screen and point down to main listening area.
Fun times but a headache as things are still getting sorted out and few have any experience with these new surround codecs.
And I see no SSPs coming out soon with ATMOS.
I've committed to LCRS AND FRONT HEIGHT speakers doing at least 110 db at the main listening area as the front heights will get full, LCR like signals at times rather than 100% ambient sounds.
I have been building new LCR's and planning the rebuilding of my front baffle wall. I also was going to install front height speakers, but like you, will now use the speakers ceiling mounted for Atmos. I have a small room and have to decide if I want 5.1.4 or 7.1.2.
Scott Simonian likes this.
post #464 of 46732 Old 07-04-2014, 09:50 AM
Liked: 4779
Sept. 10-13th in Denver, Colorado.
Anyone know if someone outside the industry, like me, can sign up to attend? I would LOOOOVE to go this time.
Info here: Forum Members going to CEDIA Expo
post #465 of 46732 Old 07-04-2014, 10:21 AM
Liked: 1904
Originally Posted by AV Science Sales 5 View Post
Thanks! Happy 4th!
post #466 of 46732 Old 07-04-2014, 11:00 AM
sdurani's Avatar
Liked: 3613
Since Denon doesn't provide separate outputs for Heights and Tops, how would you switch between them?
It does mean that the distinction they're trying to make between Heights and Tops doesn't exist from 30° elevation to 45° elevation .
Sanjay
post #467 of 46732 Old 07-04-2014, 11:04 AM
Liked: 1904
Since Denon doesn't provide separate outputs for Heights and Tops, how would you switch between them? It does mean that the distinction they're trying to make between Heights and Tops doesn't exist from 30° elevation to 45° elevation .
Why not just have top speakers that comply with Atmos? There are upscaling modes coming out that work with Atmos' speaker layout. Whether or not they will be included in these first gen products, is up for debate I guess. I just don't see the need for doubling up on ceiling speaker locations for Atmos and a post-processing sound format that is probably now outdated.
post #468 of 46732 Old 07-04-2014, 11:49 AM
FilmMixer's Avatar
Quoted: 1963 Post(s)
Liked: 2421
Almost no studio wants to go in and remix with out the creatives being involved..
Home Atmos also adds up mixing (like PLIIx...)
From what I've heard of it, it's very impressive.
DaJoJo likes this.
FilmMixer is offline
post #469 of 46732 Old 07-04-2014, 12:06 PM
Liked: 1904
It's weird that they would think this about audio, but seem to have no problem doing unsupervised video transfers. In many instances the original intent is screwed up... especially with new color timings, contrast boosting, etc.
post #470 of 46732 Old 07-04-2014, 12:06 PM
Kris Deering's Avatar
Quoted: 2222 Post(s)
Liked: 3416
Are you planning on attending CEDIA this year?
My Home Theater
Kris Deering is online now
post #471 of 46732 Old 07-04-2014, 12:08 PM
FilmMixer's Avatar
Liked: 2421
Nope...
I'll be mixing away.
Kris Deering likes this.
post #472 of 46732 Old 07-04-2014, 12:40 PM
sdurani's Avatar
Liked: 3613
That's fine by me. A pair of speakers at 45° elevation would comply with placement for both Atmos and Neo:X (for those want to continue using DTS' surround processing).
Sanjay
post #473 of 46732 Old 07-04-2014, 01:09 PM
Schwa's Avatar
Liked: 1172
I asked JD about this since I want to run two different height/top speaker configurations: one 7.2 + middle tops for Atmos, and one 7.2 + front heights for DPLIIz/Neo:X/DSX. I'll be connecting a total of 11 speakers to my receiver but only using 9 at any given time. Here's what he told me:
The actual configuration selection will be handled by the AMP ASSIGN setting as is currently done.
What is unclear at this point is whether the X7200W will be able to remember two separate speaker configurations at the same time; otherwise, in order to switch between the two configurations I intend to use, I'd have to change the AMP ASSIGN setting every time I want to switch speaker configurations. I can connect all 11 speakers to the receiver at the same time, but there are only 9 amplifiers, hence the need to use AMP ASSIGN every time I switch active speaker configurations. If I have to change the AMP ASSIGN setting, then I assume I'd have to re-run Audyssey, and that's a huge pain. The other alternative would be to use an external amp and provide power to all 11 speakers at once....this way I'd only have to run Audyssey once and it could measure all 11 speakers in one pass. Presumably the receiver would then be smart enough to use the proper speakers depending on the sound mode that's engaged. I'm guessing this is the way this will work, but I won't know for sure until the manuals are published.
Schwa is offline
post #474 of 46732 Old 07-04-2014, 01:40 PM
joehonest's Avatar
Quoted: 101 Post(s)
Liked: 42
How well will Atmos work/sound with vaulted ceilings, the right side is about 10ft and the left is about 16ft ?
Would I need to in some way hang the needed speakers on the left side, do all speakers need to be the same height?
joehonest is offline
post #475 of 46732 Old 07-04-2014, 01:45 PM
sdurani's Avatar
Liked: 3613
Even if Amp Assign worked the way you wanted, how are you going to switch between Height speakers and Top speakers when the X7200W only has connections (speaker level or pre-out) for a single pair of heights up front and a single pair of heights behind? Or are you going to forego doing 4 heights?
Sanjay
post #476 of 46732 Old 07-04-2014, 01:48 PM
Liked: 1904
You need to use posts mounted to the ceiling to equalize the height of the speakers.
post #477 of 46732 Old 07-04-2014, 01:58 PM
Schwa's Avatar
Liked: 1172
I'm only going with two front heights and two in-ceiling (Atmos) tops. But I did ask JD how this would work, and this is what he said.
Schwa is offline
post #478 of 46732 Old 07-04-2014, 02:00 PM
joehonest's Avatar
Quoted: 101 Post(s)
Liked: 42
That's what i thought, and running the wiring and in this case the worse part , man thats a alot of work for me!
post #479 of 46732 Old 07-04-2014, 02:25 PM
Liked: 1904
But probably oh, so worth it!
post #480 of 46732 Old 07-04-2014, 03:06 PM
Tom Grooms's Avatar
Quoted: 133 Post(s)
Liked: 209
That would look ridiculous (imo). I'd try in-ceiling speakers and let the AVR adjust the distance.
Tom Grooms is offline
