The official Dolby Atmos thread (home theater version) - Page 181 - AVS Forum | Home Theater Discussions And Reviews
 16521Likes
Old 08-24-2014, 07:19 PM
Quoted: 940 Post(s)
Liked: 497
Originally Posted by bargervais View Post
I was always under the impression that the front three are the most crucial and do most of the work is that correct
While I cannot speak to height channels one way or another in the context of Atmos or anything else (never heard, let alone used, heights) for 2 to 7 channel systems I think that's right. Ideally, the front three speakers should be identical speakers oriented identically and at the same height. When that is not practicable then one should try to get as close to the ideal situation as possible. The rest of 'em...basically, make sure they're placed right and aren't terrible performers.
Originally Posted by NorthSky View Post
Best surround sound experience comes from identical loudspeakers ALL AROUND. ...Front Left, Center, FR, SR, and SL.
I don't think that's particularly or at all important, actually. LCR, yes. The rest of 'em, not so much. At least on material for which fidelity is an actual issue, such as orchestral concerts recorded in multichannel. For movies, whatever. Don't know, don't care.
Originally Posted by David Susilo View Post
Once you've experienced surround with 100% identical speakers, you will then realize how important having identical speakers all around.
Except when you've done it, and realized that after spending an awful lot of money on four speakers to your sides or rear you're not even positive you could tell the new 20x more expensive surrounds from the old ones in a blind test, even though when you compare them as main speakers the spectral balance, image rendition, and dynamic reproduction of the new ones are all beyond question superior...
Furthermore, there's a strong case to be made that ambience speakers have different requirements from front-stage speakers, especially in a small room.* Dr. Toole touches on this idea in Sound Reproduction. Note that his discussion of surrounds never once refers to mains. Instead, he refers to problems unique to the surround channels in small rooms, such as localization at one surround speaker for listeners outside the main listening position, and makes some proposals that seem to have intuitive merit but are not widely adopted, such as use of line or CBT arrays for ambience channels.
I don't see how Atmos would change the equation there, though I'm very open to changing my mind if presented with a good argument.
*"Small room" used here as a term of art to refer to the kinds of spaces found in personal homes, as distinct from "large rooms" such as auditoria or concert halls that seat hundreds or thousands of people.
kbarnes701, Nightlord and pletwals like this.
"In many cases there aren’t two sides unless one side is 'reality' and the other is 'nonsense.'" - Phil Plait
Serious Audio Blog
DS-21 is offline
Old 08-24-2014, 07:27 PM
Orbitron's Avatar
Quoted: 497 Post(s)
Liked: 369
Having set up 5.1 SACD with identical tweeters and woofers for fronts, center and rears, it's really smooth and balanced.
Dan Hitchman and David Susilo like this.
Orbitron is offline
Old 08-24-2014, 07:29 PM
David Susilo's Avatar
Quoted: 619 Post(s)
Liked: 586
OIC, yet another "blind test" guy.
My home theatre have 2 sets of speakers to make a point to my clients. One set 100% identical, another only the LCR are identical with slightly different model but from the same series of the same brand manufacturers. Funny enough that 100% of about 500 listeners (so far) always prefer the 100% identical speakers vs similarly sounding speakers. None of them knew which set I was playing and I only asked whether they choose set A or set B.
follow my A/V tweets @davidsusilo
ISF, THX, CEDIA, Control4 & HAA certified
Reviewer for TED & WifiHifi Magazines
my (yet to be completed) BD list
my home theatre
David Susilo is offline
Old 08-24-2014, 08:19 PM
batpig's Avatar
Quoted: 3623 Post(s)
Liked: 3469
Thanks Sanjay and Marc for the reports. So it sounds like some of our earlier inferences (mostly based on the now infamous pg 287 chart) were correct:
- the Atmos elevation speakers cannot be used with Neo:X or DSX, only DSU
- wides don't make sound with DSU
- if you want to "share" a pair of height speakers between Atmos/DSU and legacy upmix like Neo:X, the first pair of elevated speakers must be designated Front Height
Definitely a bummer that you can't utilize the HTRF processing for the visual heights in other height modes, but then again I'm not surprised. Why would Dolby allow their proprietary design, a result of a lot of time and research, be used to enhance competitor products from DTS and Audyssey?
tjenkins95 likes this.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
Old 08-24-2014, 08:54 PM
sdurani's Avatar
Quoted: 4666 Post(s)
Liked: 3068
For the same reason PLIIz works with all codecs (from Dolby and its competitors). Otherwise, it leaves an opening for someone else to offer a truly agnostic version of the technology. If that happens, they don't just run the risk of someone offering an alternative, they run the risk of someone offering something better.
Imagine if Dolby had limited PLIIz to only extract height information from Dolby codecs (DD, DD+, TrueHD) and not work with competitor's codecs. Most BDs use a DTS codec, which would have left an opening for another company to offer a truly universal upmixer. But what if that other company offered one that could extract heights AND wides? Would Dolby want to leave themselves open to that?
IF it is Dolby that has limited their Elevation processing to only work with their upmixer, rather than it being a limitation in 1st gen products due to chipmakers/manufacturers, then I hope they seriously reconsider this restriction. What's the worst that will happen? More of their licensed speakers will be sold?
Sanjay
sdurani is online now
Old 08-24-2014, 09:10 PM
blastermaster's Avatar
Quoted: 456 Post(s)
Liked: 581
I would love to have all of my speakers the same. However, my LCR's are about fifty pounds each and take up a fair chunk of real estate. How in the hell am I supposed to mount those to the ceiling for atmos? I think I may have to settle for bookshelf speakers that are in the same brand/family. If I were to have them all the same, in my space, the fronts would have to be much smaller and would probably sound much more anemic than the ones I am currently using. I agree that having them all the same would be ideal, I just don't see how I can do it with my setup and room.
blastermaster is offline
Old 08-24-2014, 09:16 PM
Dan Hitchman's Avatar
Quoted: 3419 Post(s)
Liked: 1779
Yes, of course you would want to use the smaller family of speakers from the same brand for the surrounds as the fronts to maintain timbre matching. The low end can be sent to the subs.
One thing I would like to have in receivers and pre-amps would be surround subwoofer outputs like in Atmos theaters. That is an add-on function of the processor's bass management software.
Listen up, studios! Just say "NO" to DNR and EE!!
Dan Hitchman is offline
Old 08-24-2014, 10:08 PM
westmd's Avatar
Quoted: 791 Post(s)
Liked: 266
David, over at the Yamaha aventage thread you wrote:
Timbre Matching, even as a THX Certified Professional, I find it to be totally unnecessary as the matching is already done by YPAO EQ
Could explain that statement?
westmd is offline
Old 08-24-2014, 10:10 PM
NorthSky's Avatar
Quoted: 7012 Post(s)
Liked: 3553
Right on!
NorthSky is offline
Old 08-24-2014, 10:12 PM
NorthSky's Avatar
Liked: 3553
That is also what I experienced and many of my friends. ...And for both multichannel music and movies.
* Dr. Toole is good, very good.
NorthSky is offline
Old 08-24-2014, 10:15 PM
Roger Dressler's Avatar
Quoted: 1538 Post(s)
Liked: 727
Originally Posted by DS-21 View Post
You don't want to point the Tannoys, or any concentric driver or speaker with a round waveguide, directly at the listening position. Simple geometry: there's a cancellation notch in the treble that fills in completely a little off axis.
I'd like to know more about the geometry that causes this notch. There's no mention of that here.
Deadwood Atmos theater [HTOM]
AV7702 Atmos 7.4.4, SSP-800 PLIIx 7.4
Aerial Acoustics 7B/CC3B fronts, B&W CWM8180 surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
Roger Dressler is offline
Old 08-24-2014, 10:20 PM
NorthSky's Avatar
Liked: 3553
I guess it would be the same with Marantz? ...Of course it is.
* You think Yamaha, Pioneer Elite, Onkyo/Integra, have a different topology (implementation) about Dolby Atmos working with their own proprietary Auto Room Calibration and EQ systems?
Like for Dolby Surround working with dts Neo:X and the presence channels (Yamaha).
NorthSky is offline
Old 08-24-2014, 10:27 PM
Liked: 727
Originally Posted by kbarnes701 View Post
I’d love to take you up on that. Texas is one state I have never visited. Bjorn's really does sound like the real deal!
When I moved to San Antonio in 1980, Bjorn was already "at it" doing demos of high fidelity sound with projection video, playing surrounds through a time delay device. This was at least 2 years before Dolby Surround was born.
kbarnes701 and UKTexan like this.
Old 08-24-2014, 10:28 PM
NorthSky's Avatar
Liked: 3553
It says right there; YPAO EQ. ...Doesn't mean it's perfect; because it is not.
NorthSky is offline
Old 08-24-2014, 10:33 PM
NorthSky's Avatar
Liked: 3553
Nothing is essentially important, but when you hear the difference between what is and what's not,
then it becomes obvious that what counts is what you prefer. ...And no matter what other prefer,
even Dr. Toole, or/and Dr. Olive.
NorthSky is offline
Old 08-24-2014, 11:52 PM
westmd's Avatar
Quoted: 791 Post(s)
Liked: 266
I would love nothing more then to get timbre matched speakers to my existing ones but AFAIK they don't exist. I have been in contact both with the US and German representatives of Jamo.
What I have been told is that KEF's are rather neutral so difference wouldn't be too great between mine and the KEF's.
One other company I found was Preference (http://preference-audio.com). They have in ceiling speakers with a silk tweeter (my Jamos have a polyester one) in comparison to KEFs aluminium. I have been told that comparing tweeter material is the most important when it comes to timbre matching. Unfortunately so far I was not able to find any reviews or experience reports on the Preference units?
westmd is offline
Old 08-25-2014, 12:57 AM
jacovn's Avatar
Quoted: 127 Post(s)
Liked: 24
We really need a white paper from Dolby for the specifications on the ceiling speakers.
I sort of assume it will be close to the cinema requirements on most part.
From http://www.dolby.com/us/en/technolog...ifications.pdf there are some clear guidelines.
Loudspeakers over Central Listening Area (CLA) should be aimed down
Loudspeakers front and behind CLA should be aimed at the edge of the CLA.
When CLA is 1 seat, or row, it should perhaps not be aimed directly at the ear position, but slightly before and behind ?
The same seems true for the angle they need from side towards the middle of the room. That is halfway between the middle of the room and the axis front rear they are installed on.
Same logic, not directly at the ears of the person in the optimal position, but just next to it.
Come on Dolby, share this information.
jacovn is offline
Old 08-25-2014, 03:05 AM - Thread Starter
markus767's Avatar
Quoted: 3798 Post(s)
Liked: 1354
In the bigger picture diaphragm material is meaningless if distortion of drivers is similarly low. Timbre is dictated by driver dispersion characteristics and room interaction.
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is offline
Old 08-25-2014, 03:27 AM
westmd's Avatar
Quoted: 791 Post(s)
Liked: 266
Loudspeakers front and behind CLA should be aimed at the edge of the CLA. .
Esoecially with in ceiling f that will be hard to achieve as they are flat with the ceiling and it will be hard to aim! There are some models with pointaboe tweeters but these don't follow Dolby's "Wide Dispersion" requirement. I understood that if you have a wide dispersion speaker (like KEF uni-q) within the correct angle no aiming should be done!
westmd is offline
Old 08-25-2014, 04:48 AM
kbarnes701's Avatar
Quoted: 6740 Post(s)
Liked: 5083
Originally Posted by chi_guy50 View Post
No, Keith, as I understand it--and JD can correct me if I have misunderstood--he is instructing us that the AVR will not engage Dolby Atmos processing if you have configured your height speakers as FH/RH, which was the two-pair configuration I had envisioned for my living room. As I now understand it, you can use FH or RH for one of the two pairs but not both and not individually, only in combination with one of the Atmos-specific speakers.
That is why I stated that this was news to me.
JD will no doubt step in, but I don't think you have got it right. Batpig's chart showed clearly that the FH+RH combination was an Atmos combination. I should have saved the post but search should find it for you.
@batpig: would you post the chart from the manual again please (or PM it to me). It's the one where you had highlighted in yellow various combinations IIRC. Thanks buddy.
kbarnes701 is offline
Old 08-25-2014, 04:51 AM
kbarnes701's Avatar
Liked: 5083
Originally Posted by UKTexan View Post
westmd, I contacted David Kroll who is the Global product manager for KEF in ceiling speakers as I too am considering the THX speaker. David gave me three options which would all match well with the KEF R300's I am looking at:
Depending on the room size / and what main speakers, the Ci160QR, Ci200QR, or the Ci200RR-THX.
The Ci200QR offer the best output/LF response for reasonable cost. The Ci200RR-THX are an exceptional speaker, and can even be used as LCR in a high performance system.
Does not answer your timbre match question but thought I would share the information received.
If you are using XT32, timbre matching isn’t really an issue.
Old 08-25-2014, 04:53 AM
jdsmoothie's Avatar
Quoted: 12928 Post(s)
Liked: 5969
Currently the only available X5200W manual is the one on the Denon UK website in which you can easily download yourself.
http://www.denon.co.uk/uk/downloads/...ionmanual.aspx
kbarnes701 likes this.
jdsmoothie is offline
Old 08-25-2014, 04:57 AM
kbarnes701's Avatar
Liked: 5083
Originally Posted by erwinfrombelgium View Post
I actually took my family across the border to experience Atmos @ the movies, but it was only a 2h drive into Holland... Well worth it.
Which movie did you see?
BTW, there aren't any real borders in the EU anymore... except for the UK, as you know! You Brits always have to be special!
It's not that - we just like to make life difficult for the French LOL.
(Amitiés, Hugo!)
Old 08-25-2014, 05:01 AM
kbarnes701's Avatar
Liked: 5083
Sorry for the confusion, although not ideal, FH+RH can indeed be used as the Atmos "height" speakers.
Thanks JD. Some confusion seems to arise from the nomenclature for the overhead speakers. Some call them 'overhead', others 'height', others 'top', others 'ceiling' and so on. So when referring to 'heights' some people mean the legacy heights like those for PLIIz and others mean 'tops' like the new Top Front etc. I guess it will settle into some sort of convention eventually. Maybe we should call traditional front and rear heights 'legacy heights' and all the others 'ceiling'?
Old 08-25-2014, 05:14 AM
kbarnes701's Avatar
Liked: 5083
Originally Posted by ellisr63 View Post
When you turn on the 4520... If there is no load would it be running much cooler to since the amps are idle? I am asking this to see if a dedicated AVP would be more efficient AC wise and temperature wise than a AVR.
Probably not. It's the HDMI board that seems to generate most of the heat.
ellisr63 likes this.
Old 08-25-2014, 05:26 AM
ss9001's Avatar
Quoted: 346 Post(s)
Liked: 406
Owner's manuals are up on Pioneer US site for the AJ Dolby speakers:
http://www.pioneerelectronics.com/PU...rs/SP-EBS73-LR
Steve
ss9001 is online now
Old 08-25-2014, 05:39 AM
kbarnes701's Avatar
Liked: 5083
Originally Posted by Dan Hitchman View Post
Thanks for the updates!
I agree that Denon is not the best at making intuitive menu structures... or manuals for that matter.
Which is why we have batpig of course
Old 08-25-2014, 05:42 AM
kbarnes701's Avatar
Liked: 5083
Originally Posted by sdurani View Post
Being 17 miles away, figured I'd take advantage of Marc's kind hospitality rather than wait for his report. The below text is copied from the Denon 4100/5200/7200 thread.
Great post, Sanjay. Thanks. I do envy you guys who all live so close to each other that you can have these GTGs.
Old 08-25-2014, 05:46 AM
Nightlord's Avatar
Quoted: 722 Post(s)
Liked: 246
Really no one in your area?
Codename - the Larch theater
Nightlord is online now
Old 08-25-2014, 05:48 AM
tjenkins95's Avatar
Quoted: 408 Post(s)
Liked: 332
I was just about to type the same thing and you beat me to it!
www.raysdvds.org
Denon AVR-X6200W; JVC RS500; Panasonic DMP-UB900; Oppo UDP-203;
Klipsch Speakers: RF-82, RC-62, RS-52, RB-61, RT-10d sub, Klipsch CDT-3650-C (4) ceiling.
Pioneer Dolby Atmos enabled Elite Concentric Speakers: SP-EFS73, SP-EBS73, and SP-EC73 in the guest room.
tjenkins95 is offline
