The official Dolby Atmos thread (home theater version) - Page 82 - AVS Forum | Home Theater Discussions And Reviews
 16187Likes
post #2431 of 44164 Old 07-29-2014, 11:33 AM
Cam Man's Avatar
Location: Tucson, AZ, Telluride, CO, & Los Angeles,CA, USA
Quoted: 380 Post(s)
Liked: 385
Originally Posted by ss9001 View Post
I'd say your right on both counts - $1000 ea and 9.5" clearance? Not including needing near the whole 16' width to install. I wonder what idiot came up with these dimensions.
With typical ceiling joists between 2X6 and 2X10's that disqualifies a whole lot of applications & potential sales. They must think everyone is going to have an attic above the ceiling
Looks to me like a Stupid Design decision! They should have kept the money they spent on THX cert and hired an engineer with a practical sense of home construction instead
Even if I was a Klipsch fan (which I'm not), I'd pass on this.
May be a great sounding speaker but not a lot of thought put into practicality for installing in a typical house.
Next...
Room volume and listening distance drive speaker decisions for me. The Klipsch THX U2 line is a good one for that, and very flexible. You are so right on the installation trouble for the in-ceiling. I'm doing an upgrade for a big living room remodel where I used LCRs from the line a while back, but had to wait for the remodel to do surrounds. Despite the ceiling being 14', there is only 8" or so of ceiling clearance due to various framing. No go. Would have been nice in that room.
I have used them, though, a number of times, and they do very well. There's just not a lot of in-ceiling speakers that are good for big rooms with significant distance/throws. Keith's suggestion with the Tannoys could be a good one, though.
Cam Man is online now
post #2432 of 44164 Old 07-29-2014, 11:34 AM
FilmMixer's Avatar
Quoted: 1726 Post(s)
Liked: 2085
Originally Posted by BillFree View Post
With all the discussion on Dolby Atmos speaker placement, Atmos receivers, content coming what about Dolby Atmos supported headphones? I have Sony DP-RF6000 headphones that support DTS, Dolby Digital Prologic, Mpeg-2 aac. I really enjoy surround sound effect. Dolby Atmos ceiling speakers placement on headphones? Is that possible?
http://www.cnet.com/news/dolby-to-put-atmos-surround-sound-on-tablets-smartphones/
FilmMixer is offline
post #2433 of 44164 Old 07-29-2014, 11:43 AM
ss9001's Avatar
Quoted: 338 Post(s)
Liked: 398
Originally Posted by kbarnes701 View Post
Not to mention the significant extra cost of comparable quality in-ceiling designs (compared to on-ceiling) plus the possible greater difficulty of fitting them.
that's what I mean.
just one look at Can Man's Klipsch example and several other examples I just mentioned show that installation considerations of depth, location right between studs, cut-out sizes & needed mounting hardware add up to potential difficulties while finding a single stud to screw in an omnimount style or C bracket is a whole lot easier. plus, depending on which direction the studs go, more flexibility in placement one dimension or the other.
Steve
ss9001 is offline
post #2434 of 44164 Old 07-29-2014, 11:48 AM - Thread Starter
markus767's Avatar
Quoted: 3658 Post(s)
Liked: 1309
Originally Posted by sdurani View Post
I know, it never ends. It's like he cannot believe other people have different priorities than he has.
I'm just trying to understand what considerations make you dismiss a superior solution. Has nothing to do with me not being able to accept that other priorities exist. I'm just trying to understand what those priorities are.
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is offline
post #2435 of 44164 Old 07-29-2014, 11:51 AM
bkeeler10's Avatar
Quoted: 296 Post(s)
Liked: 175
Originally Posted by markus767 View Post
In my opinion the lack of detrimental boundary effects outweighs this. There are also in-wall/ceiling designs that allow aiming:
http://www.psbspeakers.com/products/square-in-wall
You're assuming that boundary effects disappear when the speaker is flush-mounted . . .
bkeeler10 is offline
post #2436 of 44164 Old 07-29-2014, 11:51 AM
sdurani's Avatar
Quoted: 4527 Post(s)
Liked: 2928
How many seats in each row and how many rows? How large is your room?
It's a wide couch that can seat 3-4 in a living room that is about 14 feet wide in the front half (right side wall disappears half way back, opening up to the dining area). Back wall is about 17 feet from the front wall, but there are archways (not doors) on the back wall and left wall. Seating is 3/5ths of room length back. If you want, I can whip up a quick diagram.
Because of the irregular space, all my speaker placement has been a result of trial and error. Hence why I said that I wouldn't know where my heights would go until I try them. Which is why I prioritize toe-in flexibility higher than you might.
Sanjay
sdurani is online now
post #2437 of 44164 Old 07-29-2014, 11:52 AM
kbarnes701's Avatar
Quoted: 6740 Post(s)
Liked: 5071
that's what I mean.
Couldn’t agree more. I spent some time figuring this out and came to the conclusion that there was just NFW I was going to use in-ceiling designs. Others may have YMMV of course, which is fine. But it ain't for me and I am happy with the likely choice of the Tannoys. If I had a bigger room I’d go with the Di6 DCs and if I had a huge room, maybe the Di8s! Oh yes!
kbarnes701 is offline
post #2438 of 44164 Old 07-29-2014, 11:55 AM - Thread Starter
markus767's Avatar
Liked: 1309
The worst detrimental boundary effect does indeed disappear, namely the back wall bounce.
http://www.genelec.com/tech-tips/tec...llation-tip-1/
Markus
post #2439 of 44164 Old 07-29-2014, 11:55 AM
UHD Addict
aaronwt's Avatar
Quoted: 5234 Post(s)
Liked: 3132
Originally Posted by bargervais View Post
Hercules 3D is playing in dolby atmos they want $15.50 for an adult and $13.00 for Senior and $12.50 for child at our local Regal theatre might have to check it out
That is $2 less than the Regal Atmos theater in my area. Those prices seem to be inline with the AMC Atmos theater in my area. I have no idea why the Regal in my area is $2 more. I'm hoping to check out the movie Lucy tonight or tomorrow night there. Since I saw it this past weekend at an AMC theater it is still fresh in my mind.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is online now
post #2440 of 44164 Old 07-29-2014, 11:59 AM
sdurani's Avatar
Liked: 2928
I'm trying to understand why you believe that solutions to your priorities are "superior" for everyone else. Also, I didn't dismiss the problem (said I would address it with absorption).
ss9001 likes this.
Sanjay
post #2441 of 44164 Old 07-29-2014, 12:05 PM
bkeeler10's Avatar
Quoted: 296 Post(s)
Liked: 175
Yes, that boundary effect disappears. I realized after reading further which one you were referring to. Although there are other effects caused by boundaries, which flush-mounting does not remove (and in fact it may reinforce some of them).
Anyway, sorry to jump on it out of context.
Edit: Keeping up with this thread is nearly a full-time job
post #2442 of 44164 Old 07-29-2014, 12:26 PM
kbarnes701's Avatar
Liked: 5071
Markus seems to miss the point that while in-ceiling speakers may offer some potential superiority in one area, that they may also offer other parameters which are decidedly not superior in other areas. A very obvious example is fitting the in-ceiling speakers into the ceiling. If they won't fit into the available space, then it matters not one jot how 'superior' they are wrt to the one specific parameter he has repeatedly mentioned. And, equally, if you value the ability to toe the speakers in, and they do not offer that ability to your satisfaction and requirements, again, the benefit Markus sees becomes moot. Why this is so hard to grasp that it needs a whole page of posts to communicate is difficult for me to understand.
ss9001 and tjenkins95 like this.
post #2443 of 44164 Old 07-29-2014, 12:49 PM
ss9001's Avatar
Quoted: 338 Post(s)
Liked: 398
you hit it square on the button.
one can argue boundary effects all day long but in the real world, for how many potential owners, even enthusiasts, is this going to be the #1 consideration?
for the vast majority, any potential theoretical advantage of the one are going to be far outweighed by practical issues of cost, installation problems/concerns & room layout/decor as well as sound quality.
besides, while the cancellation effect of near boundaries effects all frequencies, its greatest impact on room modes is bass. and unless one is willing to spend the money for a closed back design plus stuff a whole lot of insulation in the space or build a containment box (if that's even possible), there will be resonances & sound transference issues with in-ceiling speakers. advantage offset by disadvantage.
And, as he himself pointed out, the internal Dolby crossover for the overheads is about 180 Hz, so I'm not sure how relevant the issue even is. probably not much.
his ongoing speaker debates are very similar to the one he raged over home Atmos to begin with. I'm also at a loss to understand it...in every Atmos thread it's the same poster with the same outcome.
Steve
ss9001 is offline
post #2444 of 44164 Old 07-29-2014, 12:52 PM
noah katz's Avatar
Quoted: 887 Post(s)
Liked: 305
What’s the difference between the Atmos surround speakers in a commercial theater and the Wides in a HT? First, the Atmos speakers aren’t 'Wides' in any sense of the word used in a domestic context* - they are there simply to fill in a gap between the edge of the screen and the rest of the surrounds to enable seamless panning. And second, the angles stipulated for domestic Wides are nothing at all like the angles of those in-theater speakers.
As this was already explained, Noah, I have a feeling I have misunderstood your question.
*EG, Wides at home are for the extraction or creation or generation or derivation (pick your own noun) of reflections.
I guess I missed where the angular positions of cinema wides was specified.
And you can't have known this, but in my thinking domestic wides as implemented by DTS Neo X, and when Atmos allows the user to specify speaker locations, has the same purpose.
Seems like Markus just cannot stand to concede on any point.
Apropos, just heard this recently:
"Arguing with an engineer is like mud wrestling with a pig; after a couple of hours you realize he likes it."
There were some good retorts too; "I'm not arguing, I'm just explaining why I'm right."
Noah
noah katz is online now
post #2445 of 44164 Old 07-29-2014, 01:14 PM
KidHorn's Avatar
Quoted: 1380 Post(s)
Liked: 889
I've never heard of 2x6 floor joists. I've only seen 2x10 or 2x12. Maybe really short spans have those. If I had 2x6 floor joists, I would be scared to drill wire holes through them. Even so, a 9.5" tall speaker along a 2x10 is cutting it really close.
KidHorn is online now
post #2446 of 44164 Old 07-29-2014, 01:19 PM
asarose247's Avatar
Quoted: 702 Post(s)
Liked: 464
a comment wrt to the "nearness" of surface mounted Tops and the feeling that 8 ft ceilings would be constrictive wrt to allowing a speaker friendly D for dispersion etc,
got me to thinking
brief geometry lesson
from Sanjays visit last month wrt to my ceiling trestle system, we initially concluded that
on the 8 ft ceiling the vertical D to ears was 50" (depending on couch slouch)
We projected a FT's D of 42" directly ahead of MLP. same for RT's AND
a 42" spread to left and right, essentially a 7 foot square to be cross fired at the MLP bubble
50 x50 +42 x42 yadda yadda yadda. D to speaker face is 65+ inches, speakers angled down from plane of ceiling at 40 degrees. directly in front of MLP, with in parameter range
now move that speaker face42" to the side
42 x 42 + 42 x 42 , square root yields about 59.4", the distance from a spot directly overhead the mlp to that spot ahead and to the left (or right)
so the triangle for the D to the speaker face at the corner of the 7 ft square is 59,4 x 59.4 + 50 x 50 etc. =about 77" to the spot on the ceiling, so if the speaker hangs down about 4-6 inches, it's still about 6 feet away.
same for the RT's.
since my Surrounds are only about 8 feet from me, this "feels like" maybe the right EQ and ATMOS can marry it all into a well unified sound field.
and my ugly wart design got an upgrade last night
a work in progress
that Marantz 8802 sounds like the real deal
kbarnes701 likes this.
DIY FAN Denon X5200 , ATI A 2000 for 7.4.6 SCATMOS/DSU/SHARP 80" LED/LCD
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: F4Q4LP , RL/RR: F-3, TF/TR: Volt 6's TM: SLX
SUBMAXIMUS, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x Inuke6000DSP
www.avsforum.com/forum/155-diy-speakers-subs/1485120-submaximus-large-front-loaded-horn
http://www.avsforum.com/forum/155-di...orn-build.html
asarose247 is online now
post #2447 of 44164 Old 07-29-2014, 01:22 PM
ss9001's Avatar
Quoted: 338 Post(s)
Liked: 398
you're right. my own house is 2X10 between the floors but I did find a reference to 2X6. I just searched on "typical ceiling joist dimensions" and couple sites included 2X6.
I also find that pretty skimpy & not realistic for most normal size rooms but even so, like you said, a 9.5" deep speaker is not going to fit even a 2X10 (9-1/4").
bottom line - it's not a practical in-ceiling speaker.
Steve
ss9001 is offline
post #2448 of 44164 Old 07-29-2014, 01:23 PM
Schwa's Avatar
Quoted: 1002 Post(s)
Liked: 1064
Drop it already. Sheesh.
Schwa is offline
post #2449 of 44164 Old 07-29-2014, 01:27 PM - Thread Starter
markus767's Avatar
Liked: 1309
Well, my priorities are pretty simple: describe what is the best solution in terms of high quality sound reproduction. And flush mounting is objectively the best solution. See Toole, see the Genelec page I've liked, see any text about studio acoustics. This has nothing to do with my personal priorities and tradeoffs required in my specific room or any other room.
It is not me being unable to see that there are tradeoffs and differing priorities, it's others imposing their personal requirements or priorities onto the discussion. Just like you did when saying "mini-bookshelves mounted to the ceiling with brackets" would be "More effective" than "actual in-ceiling speakers". Maybe in your specific room but generally it's not true.
Markus
post #2450 of 44164 Old 07-29-2014, 01:32 PM
kbarnes701's Avatar
Liked: 5071
Yep. It all seems pretty clear to me. A benefit is only a benefit if you can realise it. I can't physically accommodate any in-ceiling speaker I’d want to use; Sanjay wants to toe-in the ceiling speaker more than in-ceiling designs allow. That's pretty much the end of in-ceiling designs as a potential choice. Constantly banging on about the benefits wrt to boundary effects doesn’t somehow suddenly make in-ceiling designs fit into my ceiling nor make then toe-in enough for Sanjay. Tell me I would benefit more if I had a 130 inch screen.... sure... I know I would. Now let me tell you I can't physically fit one into my HT. Isn't that the end of it? No need to tell me another 15 times why a 130 inch screen is better. Where's the roll-eyes thing... ah, here it is...
post #2451 of 44164 Old 07-29-2014, 01:35 PM
kbarnes701's Avatar
Liked: 5071
LOL. Wonderful!
An optimist says his glass is half full. A pessimist says his glass is half empty. An engineer says you have the wrong size glass.
markrubin, ss9001 and smurraybhm like this.
post #2452 of 44164 Old 07-29-2014, 01:40 PM
kbarnes701's Avatar
Liked: 5071
They're all 2x6 in the UK, for modern(ish) houses AFAIK. But our spans are generally shorter than for US homes, as the rooms are smaller. It can restrict the choice of in-ceiling designs quite a lot, and can rule out those which require some sort of back box altogether. I'm sure they have their benefits and their role, but they are clearly not for everyone. And they always seem to cost an arm and a leg for any that are likely to sound good.
post #2453 of 44164 Old 07-29-2014, 01:41 PM - Thread Starter
markus767's Avatar
Liked: 1309
When you're all done with personal derogative comments and backslapping, could we please get back on topic? There's a difference between attacking a post and attacking a poster. Some of you crossed the line.
Markus
post #2454 of 44164 Old 07-29-2014, 01:41 PM
sdurani's Avatar
Liked: 2928
Originally Posted by asarose247 View Post
from Sanjays visit last month wrt to my ceiling trestle system, we initially concluded that on the 8 ft ceiling the vertical D to ears was 50" (depending on couch slouch)
60" from ears to ceiling when slouching. Mounting the top speakers 42" forward & rearward of the main listening position was based on using the angles (35° forward & rearward of the MLP) in the Denon diagram. The 84" spread came from wanting the top speakers behind the listener at least 60° apart to avoid reversals. For consistency, same spread for the tops in front of the listener. Thus the 7'x7' square.
Sanjay
post #2455 of 44164 Old 07-29-2014, 01:46 PM
jkasanic's Avatar
Quoted: 329 Post(s)
Liked: 123
Let me ask the question this way (since I'm currently using in-ceiling speakers in a 7.1 setup), if I have enough toe-in adjustment for the extremes of my setup, is there any reason I would replace my in-ceiling speakers with add-on speakers? In this case, do we all agree that a "quality" in-ceiling speaker would be preferable to an add-on speaker for the reasons already mentioned? I'm not trying to prolong this painful discussion but until I read this, I was relieved that I might get some benefit from my in-ceiling speakers (inherited during the purchase of my house) but now I'm wondering if I need to consider replacing them?
jkasanic is offline
post #2456 of 44164 Old 07-29-2014, 01:55 PM
sdurani's Avatar
Liked: 2928
Just as vanilla is objectively the best tasting ice cream.
Sure it does. You're willing to give up the toe-in flexibility I want in order to not have a SBIR notch. I'm willing to accept a SBIR notch (and address it with absorption) in order to have toe-in flexibility that in-ceiling speakers do not have.
Sanjay
post #2457 of 44164 Old 07-29-2014, 01:57 PM
kbarnes701's Avatar
Liked: 5071
Are they in the right position for Atmos is the first question that springs to mind? IOW, do they meet the angle requirements in the oft-posted diagram? If so, then I see no reason why they wouldn't work well for Atmos if they currently work well for 7.1.
Mu understanding of it is that either in-ceiling or on-ceiling designs will work well for Atmos, so it becomes a matter of individual choice. In-ceilings may have some inherent benefits, but they also have some inherent drawbacks. Same for on-ceilings. Only an individual can balance these.
I've already decided I can't accommodate any in-ceiling designs that I would want. And/or they would be too difficult to work with from a practical POV.
One other benefit of my decision to go with on-ceiling designs is that I can fairly easily move them about and experiment with different positions, whereas this will be impossible with in-ceiling designs. Once the hole is cut, it is cut. I intend to experiment because of the Atmos overlap of possible angles. For example, I can specify a Front Height + Top Middle scenario, and with only a smallish move of the Top Middles I can make them Top Rears and this will then allow me a Top Front and Top Rear scenario. I can then compare FH+TM with TF+TR and see which is better, if any. And all I have to do is make sure I have enough speaker wire to allow me to move the speakers. Once I have experimented, I just have some very small holes to repair, where the speakers were fixed to the ceiling. Nice and easy, nice and flexible and it allows me to listen before I commit. In-ceiling designs are a once-and-for-all thing because moving them and filling the holes might not be very easy at all. Especially if the joists go the 'wrong' way, which IME is always.
asarose247 likes this.
post #2458 of 44164 Old 07-29-2014, 02:09 PM
ss9001's Avatar
Quoted: 338 Post(s)
Liked: 398
Let me ask the question this way (since I'm currently using in-ceiling speakers in a 7.1 setup), if I have enough toe-in adjustment for the extremes of my setup, is there any reason I would replace my in-ceiling speakers with add-on speakers? now I'm wondering if I need to consider replacing them?
I agree with Keith. If they are in the right locations, I'd use them and not look back. You're fortunate you have good ones already installed unlike those of us who are having to decide which is the best way to go based on all these issues.
Now, if you wanted to upgrade the speakers themselves that's obviously different but I'd personally not replace them with add-on Dolby speakers as long as they are in the proper placement for the configuration you are thinking of (Top, Middle or Rear). If they aren't in good Atmos spots, then you could weigh the feasibility of moving them vs add-ons.
I'd at least try what you have first before doing anything differently
Steve
ss9001 is offline
post #2459 of 44164 Old 07-29-2014, 02:10 PM
hogues's Avatar
Quoted: 73 Post(s)
Liked: 51
Thinking of going 5.1.4 but I my ceiling is only 7'2' and I see that the recommended height for the atmos add-on speakers is 8 feet. If I go with in ceiling speakers would just over 7 feet be ok or just a waste of time? I would sit about 9 feet from the screen and have the first pair of atmos speakers a few feet in front of the screen and the second pair a couple of feet behind me. Thanks for any advice!
hogues is offline
post #2460 of 44164 Old 07-29-2014, 02:12 PM
sdurani's Avatar
Liked: 2928
The two Atmos theatres closest to me are both Krikorian and both showing 'Lucy' in Atmos (probably a less bombastic soundtrack than 'Hercules'). Thankfully, ticket prices for the first show of the day are $7.75 and $10 (one of the two theatres has a premium auditorium, with better seats and a bigger screen, hence the higher price). Still, can't beat that for hearing a movie in Atmos.
Sanjay
