The official Dolby Atmos thread (home theater version) - Page 83 - AVS Forum | Home Theater Discussions And Reviews
 16089Likes
post #2461 of 43963 Old 07-29-2014, 02:15 PM - Thread Starter
markus767's Avatar
Quoted: 3631 Post(s)
Liked: 1294
Originally Posted by sdurani View Post
Just as vanilla is objectively the best tasting ice cream.
That's nonsense. Flush mounting does NOT cause a destructive interference from the back wall. Mounting a speaker in front of it does. This is not a matter of preference but physics.
Sure it does. You're willing to give up the toe-in flexibility I want in order to not have a SBIR notch. I'm willing to accept a SBIR notch (and address it with absorption) in order to have toe-in flexibility that in-ceiling speakers do not have.
I've shown an in-wall speaker that can be toed-in ±30° while still preventing destructive interference. So why would I go for an inferior mounting method if I don't need a larger toe-in? If the amount of toe-in isn't enough in your or anyone's individual case then you have to bite the bullet and go for on-wall with absorption. Nevertheless the objectively better solution would be flush-mounted in-wall, it's just not possible in your case.
By the way, just to show how deep the notch can be:
http://www.diyaudio.com/forums/multi...ml#post4006542
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is offline
post #2462 of 43963 Old 07-29-2014, 02:18 PM
kbarnes701's Avatar
Quoted: 6740 Post(s)
Liked: 5071
Originally Posted by hogues View Post
Thinking of going 5.1.4 but I my ceiling is only 7'2' and I see that the recommended height for the atmos add-on speakers is 8 feet. If I go with in ceiling speakers would just over 7 feet be ok or just a waste of time? I would sit about 9 feet from the screen and have the first pair of atmos speakers a few feet in front of the screen and the second pair a couple of feet behind me. Thanks for any advice!
Andrew Jones addressed this specifically in one of the HTG podcasts IIRC. He said that it wouldn't matter all that much if the Atmos speakers didn't see a clear 8 feet. So I wouldn’t worry personally if you want to use Atmos speakers. He also said that many people prefer the Atmos speakers to ceiling speakers (in or on) because the reflected nature of the sound can give an apparent increase in ceiling height over fixed speakers.
I would concentrate more on the published angles than on the distances - the distances (delays) will be taken care of to a large extent by your room EQ.
hogues likes this.
kbarnes701 is offline
post #2463 of 43963 Old 07-29-2014, 02:20 PM
kbarnes701's Avatar
Liked: 5071
The two Atmos theatres closest to me are both Krikorian and both showing 'Lucy' in Atmos (probably a less bombastic soundtrack than 'Hercules'). Thankfully, ticket prices for the first show of the day are $7.75 and $10 (one of the two theatres has a premium auditorium, with better seats and a bigger screen, hence the higher price). Still, can't beat that for hearing a movie in Atmos.
Way cheaper than the $18 I had to pay on Monday. Oddly, even though the 11am Monday showing is almost always played to about half a dozen people (which is why it is my favorite time to go), they haven't cottoned on to the idea of charging much less for that showing in order to try to fill more seats. Long may that be the case IMO!
post #2464 of 43963 Old 07-29-2014, 02:21 PM
jkasanic's Avatar
Quoted: 329 Post(s)
Liked: 123
Originally Posted by kbarnes701 View Post
Are they in the right position for Atmos is the first question that springs to mind? IOW, do they meet the angle requirements in the oft-posted diagram? If so, then I see no reason why they wouldn't work well for Atmos if they currently work well for 7.1.
Mu understanding of it is that either in-ceiling or on-ceiling designs will work well for Atmos, so it becomes a matter of individual choice. In-ceilings may have some inherent benefits, but they also have some inherent drawbacks. Same for on-ceilings. Only an individual can balance these.
I've already decided I can't accommodate any in-ceiling designs that I would want. And/or they would be too difficult to work with from a practical POV.
One other benefit of my decision to go with on-ceiling designs is that I can fairly easily move them about and experiment with different positions, whereas this will be impossible with in-ceiling designs. Once the hole is cut, it is cut. I intend to experiment because of the Atmos overlap of possible angles. For example, I can specify a Front Height + Top Middle scenario, and with only a smallish move of the Top Middles I can make them Top Rears and this will then allow me a Top Front and Top Rear scenario. I can then compare FH+TM with TF+TR and see which is better, if any. And all I have to do is make sure I have enough speaker wire to allow me to move the speakers. Once I have experimented, I just have some very small holes to repair, where the speakers were fixed to the ceiling. Nice and easy, nice and flexible and it allows me to listen before I commit. In-ceiling designs are a once-and-for-all thing because moving them and filling the holes might not be very easy at all. Especially if the joists go the 'wrong' way, which IME is always.
Well, using the image oft-cited for "ideal" speaker placement, I would opt for the top front and top rear setup in either a 5.1.4 or 7.1.4 depending on what I decide to do about in-room surrounds. This means the top front pair (with an ideal range of 30-55 degrees) fall at approx. 43 degrees while the top rear pair (with an ideal range of 125-150 degrees) fall at approx. 110 degrees. So it seems with my current MLP that one set fits within the range and the other not. Having said that, relocating the MLP approx. 12" forward would put both sets in range and probably not impact my viewing experience.
I do agree that add-ons give one more flexibility (especially for those with measuring equipment) but if we're to take the diagram published at face value then one presumes the average of each range is the optimal, correct? I guess it's still too early to know for sure but I was curious about the pros/cons of add-ons vs. in-ceiling for the height speakers. I think everyone makes valid points for their particular setups so I was just wondering if either worked, which would be preferred?
jkasanic is offline
post #2465 of 43963 Old 07-29-2014, 02:26 PM
batpig's Avatar
Quoted: 3574 Post(s)
Liked: 3420
Home theater is all about compromise, few peeople can have "perfection" in their setups. Considering the speakers won't be directly over your head I think you will be fine. It would probably be more of an issue with a x.x.2 setup with Top Middle speakers directly overhead.
hogues, kbarnes701 and PoshFrosh like this.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #2466 of 43963 Old 07-29-2014, 02:31 PM
noah katz's Avatar
Quoted: 882 Post(s)
Liked: 304
An optimist says his glass is half full. A pessimist says his glass is half empty. An engineer says you have the wrong size glass.
Yeah, that's another good one; the version I heard is "the engineer sees a glass that's twice as big as it needs to be."
kbarnes701 likes this.
Noah
noah katz is offline
post #2467 of 43963 Old 07-29-2014, 02:57 PM
sdurani's Avatar
Quoted: 4484 Post(s)
Liked: 2904
Flush mounting does NOT allow me the toe-in flexibility I want. Mounting the speaker below the ceiling does.
So why would you project your needs onto everyone else?
Sanjay
sdurani is offline
post #2468 of 43963 Old 07-29-2014, 03:03 PM - Thread Starter
markus767's Avatar
Liked: 1294
Yes, after describing your specific situation this is a compromise you have to make.
I don't. I just describe what would be objectively the best solution (in terms of sound quality).
I can't possibly make general statements about what would be best in ANY room like you did. What I can describe though is what would be the best mounting method, the second best, etc. pp. That is not the same as projecting my needs onto everyone else.
Markus
post #2469 of 43963 Old 07-29-2014, 03:09 PM
sdurani's Avatar
Liked: 2904
Less of a compromise than your alternative, where there is no boundary notch but also no chance of having the toe-in flexibility I want. At least with my approach, I get the flexibility I want and have the chance to address the boundary notch (unless you're now going to claim that flush mounting is the only way to deal with it).
asarose247 likes this.
Sanjay
sdurani is offline
post #2470 of 43963 Old 07-29-2014, 03:15 PM - Thread Starter
markus767's Avatar
Liked: 1294
Less of a compromise than your alternative, where there is no boundary notch but also no chance of having the toe-in flexibility I want. At least with my approach, I get the flexibility I want and can address the boundary notch (unless you're now going to claim that flush mounting is the only way to deal with it).
Good luck dealing with it
Markus
post #2471 of 43963 Old 07-29-2014, 03:18 PM
NorthSky's Avatar
Quoted: 7012 Post(s)
Liked: 3546
Lightbulb Just for Fun ...
Originally Posted by bargervais View Post
Hercules 3D is playing in dolby atmos they want $15.50 for an adult and $13.00 for Senior and $12.50 for child at our local Regal theatre might have to check it out
$17.50 + tax (12%) here for IMAX 3D (without Dolby Atmos)!
...And no Dolby Atmos theaters @ all on my Island.
I want it, real bad, @ home!
* Just think about it for a sec: You go to the IMAX theater with your wife and five kids.
...Then everyone with popcorn and soda pops and licorice and toffee caramel and M&M mini-chocolates.
How much do you think a roughly two-hour flick will cost all together after gas going there and back?
{You live 70 miles from that Theater and you drive a Cadillac Deluxe Edition 2014 model, and with the price of gas here in Canada on Vancouver Island.}
Or, the kids want to go to the nearest Dolby Atmos theater, which is on the main land, and three hours drive from the Ferry terminal!
- Don't even bother to think about it; I'll tell you how much, about thousand bucks!
So, four small coaxial overhead speakers and a new receiver (or SSP) is a great alternative. ...Would you say, after watching ten or so movies recorded on Blu-ray and encoded with Dolby Atmos audio surround sound?
The future looks better/brighter @ home in the countryside than in the big city. ...To me it sure does.
NorthSky is offline
post #2472 of 43963 Old 07-29-2014, 03:46 PM
bargervais's Avatar
Quoted: 1555 Post(s)
Liked: 924
At home is always more beneficial the money you invest in your own system instead of eating out going to a theater eek is right on. But it's always nice to go out as well.
DEN Atmos Samsung UN65KS8000 Roku Ultra Onkyo TX-NR 747 5.2.2 UHD audio. Polk Audio OWM3 Speakers / top middle on Ceiling / 300MGB Spectrum / Samsung UBD-K8500 Blu-Ray Player / 26 UHD Blu-Rays Living Room Atmos Samsung PN60E8000+SEK2000 / Onkyo TX-NR 1030 7.2.4 /Onkyo M-5010 Amplifier for top middle/ 300MGB Spectrum / Panasonic 3D blu-ray Bic Acoustech speakers, MICCA M-8S FH on wall /TM in ceiling speakers / 2 Bic F12 subs. BEDROOM Samsung 55JS8500 using tv speakers for now
bargervais is online now
post #2473 of 43963 Old 07-29-2014, 03:52 PM
bargervais's Avatar
Liked: 924
When I get my new avr I'm looking at maybe the TX-NR 1030 then I'll experiment with speaker placement. I already have high fronts and in ceiling backs I'll hook it up as is and see what happens I'll move them if need be later.
post #2474 of 43963 Old 07-29-2014, 03:54 PM
NorthSky's Avatar
Liked: 3546
Originally Posted by asarose247 View Post
... that Marantz 8802 sounds like the real deal
Can you do 9.1.4 and 11.1.2 with that baby? ...No 11.1.4 though right? ...11.1.6 feasible?
* It's a great looking unit, with lots of copper and gold, and a very cute ass.
NorthSky is offline
post #2475 of 43963 Old 07-29-2014, 03:59 PM
sdurani's Avatar
Liked: 2904
Already did with my L/C/R speakers (wasn't going to baffle mount them nor move them 4 feet into the room to drive SBIR below the crossover point, so went with absorption). Considering Roger and Keith are both mounting speakers below the ceiling, we might soon find out just how much of a problem it really is.
Sanjay
sdurani is offline
post #2476 of 43963 Old 07-29-2014, 04:16 PM
hogues's Avatar
Quoted: 73 Post(s)
Liked: 51
Thanks Keith and batpig for the responses. I am finishing my basement right now, so I am running the wires and have a couple of weeks before drywall goes up so I have to make a decision soon. Frankly I'm torn.
hogues is offline
post #2477 of 43963 Old 07-29-2014, 04:38 PM
sdurani's Avatar
Liked: 2904
If the Atmos speakers are 4 feet below a 7 foot ceiling, then the reflections of those speakers are 4 feet on the other side of the ceiling. Situations like this could explain why Jones ended up preferring virtual heights to real heights at the CEDIA demo he attended.
Sanjay
sdurani is offline
post #2478 of 43963 Old 07-29-2014, 04:39 PM
NorthSky's Avatar
Liked: 3546
The Onkyo TX-NR1030, with Dolby Atmos, THX Select2 Plus, AccuEQ, ...how many DSP chips inside that machine, two? ...Yes, two powerful/fast 32-Bit DSP chips. ...With BB DACs.
And, AccuEQ it don't EQ the two front main speakers? ...Does it EQ the subwoofer .1 LFE channel? ...One sub or two?
Is it true that AccuEQ requires less DSP power than Audyssey MultEQ in combination with Dolby Atmos?
Is it true that some newer Denon/Marantz units will use four DSP chips for the required computational crunching numbers for XT32 with Dolby Atmos (THX-less)?
Is it true that Onkyo/Integra is saving money with AccuEQ, Dolby Atmos, THX Ultra2 Plus equipped receivers and SSPs because it doesn't need four DSP chips, but three (and two on lower models)?
Is it true that Onkyo makes it more affordable to include Dolby Atmos in their lower receiver lineup?
Is it true that Denon/Marantz is now the one with Audyssey MultEQ XT32 in more receivers and SSPs than everyone else?
2007 was a great beginning year for Onkyo/Integra, and seven years later (2014) it seems to me that Denon/Marantz is finally back to where they once used to be.
But Denon/Marantz still don't have manual Parametric Equalization (Graphic only). ...True, neither Onkyo/Integra, for that we'll cross the bridge over to Pioneer and Yamaha.
Dolby Atmos is a totally new game in town, and it changes the course of the manufacturer's philosophy on their financial perspective.
Dolby Atmos speakers also need to be EQ, but differently. ...Still it requires more processing power, DSP.
Ultra high-end SSPs can use up to eight DSP chips (high/fast processing silicon chips), and those cost money; them SSPs retail for $5,000 up to $30,000 USD.
Some multichannel pre/pros used only two DSP chips, but two very fast and capable chips, of high storage capability.
Chips, good ones, Cirrus Logic, Shark, Texas Instruments, AKM, ...they cost few bucks. ...And the more of them the more it cost, and the better their implementation the more efficient and performing they are.
At the end of the funnel it's the sound in our rooms, sound well balanced all over, acoustically integrated by the speakers sound dispersion in direct relation to that particular room's acoustics, that counts to our ears in a well surrounding envelopment.
And, the most important part; the software, the music and movie audio soundtrack recordings.
I hope all goes well for everyone, poor and rich. ...It will.
NorthSky is offline
post #2479 of 43963 Old 07-29-2014, 04:46 PM
erwinfrombelgium's Avatar
Quoted: 414 Post(s)
Liked: 216
I have indeed pretty much decided to go with Tannoy Di5 DC speakers for my four top speakers. I like their size, for my room, and the fact that they use a dual concentric driver design, which I think will work well with Atmos and which I always enjoyed very much with Kef when I used their speakers (UniQ), and the Tannoys have a 90 degree cone of dispersion which I also think will work well. Also, they are the baby brothers to the Di6 DCs that Roger Dressler is using in his (larger) room and I admit to being influenced by Roger's thinking.
IMO the the downside of the 5" model is that 80Hz is -10 dB, hence you need to cross at something like 100 Hz. The 6" model would be more acceptable (-10 dB is 55 Hz)...
Building a 9.3.4 HT: DIYSG Titan LX [LCR] • Cinema 10 Max [6 Surrounds] • Beta 10CX custom [TF+TR] • LLT Mal-x 18" subs [2] • XPR-5 • MM8003 [8ch] • XMC-1 [RMC-1 wanted] • PT AT6000E • 130" Seymour Center XD • Oppo 103EU • WTB: 1 extra Mal-x 18" SW
erwinfrombelgium is offline
post #2480 of 43963 Old 07-29-2014, 05:22 PM
bargervais's Avatar
Liked: 924
The reason I'm leaning to the TX-NR 1030 Balanced front XLR and 11.4-multichannel pre-outs and 135 Watts per channel effortlessly handle the most dynamic of audio tracks. 8-in/3-out 4K/60 Hz HDMI® 2.0 terminals support HDCP 2.2-copy-protected 4K internet video and provide the ultimate connectivity for your future- ready home theater.
first it's the cost It will not break the bank and a first generation atmos. if this was 7 to 10 years into receivers that have had a great history with atmos then I would go with a higher end model..... so for me baby steps. I'll start with a less expensive one..... I've learned my lesson especially when they say it's future proof....
post #2481 of 43963 Old 07-29-2014, 05:24 PM
kbarnes701's Avatar
Liked: 5071
Dolby's London demo suite ("the best Atmos experience in Europe") had speakers mounted below the ceiling. So did the Atmos cinema I went to on Monday. Am I missing something?
I have no choice but to mount mine that way - but you can be sure I will report back on how they work.
post #2482 of 43963 Old 07-29-2014, 05:25 PM
3ll3d00d's Avatar
Quoted: 1566 Post(s)
Liked: 544
(a bit of selective quoting there...) in the grand scheme of things, those chips are neither powerful nor fast. On the other hand, they are low power, require little (no?) cooling and seem to be cheap as chips.
It's a mystery to me as to why we don't see greater processing power in a prepro & it would be interesting to hear from someone on the manufacturing/design side to explain this. Processing power is *everywhere* these days and it is overwhelmingly processing power that is passively cooled & sips electricity. The current prepro approach seems stuck in 2005 as far as I can see.
Dan Hitchman and ambesolman like this.
3ll3d00d is online now
post #2483 of 43963 Old 07-29-2014, 05:25 PM
brwsaw's Avatar
Quoted: 176 Post(s)
Liked: 107
I'm not sure I can post this here but Axiom just announced a new concentric in ceiling based off their M3 driver dimensions.
http://axiomaudio.com/m3-in-ceiling-...n=July2014#t-0
Proud owner of an Axiom Audio home theatre, powered by Axiom Audio.
brwsaw is offline
post #2484 of 43963 Old 07-29-2014, 05:27 PM
kbarnes701's Avatar
Liked: 5071
Yep. Unfortunately, at my demo I didn't get long enough to compare physical and Atmos speakers from that perspective. I did report how incredibly spacious and 'huge sounding' the cave scene was though and that was played via Atmos speakers. If you get the chance to do a more thorough comparison when you attend your HT demo, I am sure everyone would love to hear your findings.
post #2485 of 43963 Old 07-29-2014, 05:29 PM
kbarnes701's Avatar
Liked: 5071
True but I can't accommodate the 6 inch version. I don't see crossing to my Submersives at 100Hz as a downside though, and in fact cross all my speakers at 100Hz anyway already. I'm comfortable with crossing the Tannoys at 120Hz if my measurements and listening tests show it to be advantageous.
post #2486 of 43963 Old 07-29-2014, 05:50 PM
noah katz's Avatar
Quoted: 882 Post(s)
Liked: 304
When you're all done with personal derogative comments and backslapping, could we please get back on topic? There's a difference between attacking a post and attacking a poster. Some of you crossed the line.
If you're upset that I called you an engineer, I apologize.
Unless you are one.
Noah
post #2487 of 43963 Old 07-29-2014, 06:00 PM
SoundChex's Avatar
Quoted: 350 Post(s)
Liked: 295
For the last 20+ years my height("presence") speakers have been mounted high on the front and rear walls of rooms used for my home theater systems . . . close to where the "intelligent designers" at Yamaha had suggested I install them. If any of those speakers wish to relocate to the ceiling, they will need to evolve an independent means of locomotion and reattachment sufficient to do so under their own power (and remember to reattach their earthquake tethers after the move!)
Notwithstanding the 'persuasive eloquence' of this forum somewhat to the contrary, I suspect that the vast majority of AVR owners with existing DPLIIz, DSX, Neo:X, or CinemaDSP height speakers already in place, will chose to leave them exactly where they are already installed until the 'unfitness' of any such existing location for Dolby Atmos playback is clearly demonstrated in their own home!
All of which means that I look forward with some interest to finding out just what DTS is "promising" with the stated DTS-UHD "benefit", viz: "Customized rendering designed for arbitrary speaker layouts enables consumers to adapt their AV system to their own home environment rather than pre-determined speaker layouts"...?!
_
chi_guy50 likes this.
[Home Office system schematic]
"My AV systems were created by man. They evolved. They rebelled. There are many speakers. And they have . . . A PLAN."
SoundChex is online now
post #2488 of 43963 Old 07-29-2014, 06:09 PM
batpig's Avatar
Liked: 3420
That seems like a very nice option -- and they specifically mention Atmos in the description (coincidence?!?!). Axiom makes very neutral speakers so they should be easy to calibrate and "match" the rest of the setup without being obstrusive. $350/pair pre-order price is pretty nice too, especially for an in-ceiling speaker with an integrated enclosure.
kbarnes701 and ambesolman like this.
Setup Guide and FAQ
batpig is offline
post #2489 of 43963 Old 07-29-2014, 06:16 PM
Quoted: 414 Post(s)
Liked: 216
Originally Posted by ss9001 View Post
And, as he himself pointed out, the internal Dolby crossover for the overheads is about 180 Hz, so I'm not sure how relevant the issue even is. probably not much.
I was under the impression that only in the case of the "Atmos enabled" speakers on top of the mains this 180 Hz crossover applied. Not when using ceiling mounted speakers.
BTW, maybe it's not a bad idea to repeat here that one of the reasons most of us prefer to use a coaxial design for the Top speakers is that these need no distance to merge the sounds of tweeter and mid-woofer (since they are already merged to start with), unlike "normal" speakers. So it's no problem if the speaker-listener distance is only 4 or 5 feet.
The DIY-group designs Volt 10" or 8" cost no more than the 5" Tannoy, so that's where my money (and effort) is going. Size is not an issue. I will make the baffle angled so it points right at the furthest listener.
post #2490 of 43963 Old 07-29-2014, 06:17 PM
kbarnes701's Avatar
Liked: 5071
The good news is that, based on the oft-posted diagram, it seems that the Front/Rear Height speakers currently installed will, in most cases, also work well with Atmos.
I have decided to relocate mine to the ceiling but I was considering doing that anyway, even before Atmos was on the horizon. I know it is contrary to all instruction but my feeling was that getting them out of the plane of the mains would give a greater height effect rather than a taller front soundstage. And as there was at that time no height content in the media, I couldn't see a really strong argument against doing so.
However, after waiting months for them to relocate themselves, along the lines you suggest, and observing their stubborn and unwarranted refusal to do so, Atmos came along and solved the problem for me. Now there is actual height content in the media, I am relocating them myself to the ceiling. As the Atmos spec for the Front Height speakers overlaps, angle-wise, with that of the Top Fronts, this will enable me to experiment with FH+TM and FH+TR settings in the AVR, giving me a bit more flexibility in my otherwise fairly inflexible, small HT room.
And as PLIIz has gone with the advent of Atmos (which was the only 'height mode' I used) there is no downside for me.
PoshFrosh likes this.
