Denon X-2000 setup w/no TV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-21-2014, 09:58 PM - Thread Starter
prestonrich's Avatar
Quoted: 43 Post(s)
How can I setup the subject AVR's MultiEQ-XT to balance the system in a room w/no TV to see the settings and setup readouts? I'll be using it for stereo music only. I have a laptop but w/no HDMI.
prestonrich is offline
post #2 of 5 Old 06-22-2014, 04:44 AM
jdsmoothie's Avatar
Quoted: 12087 Post(s)
Liked: 5502
I don't recall if you can see the information on the front panel display during the EQ process, although you could also simply pick up a small 12" HDMI monitor as well which is what some with PJ's have done with no separate TV when they don't want to power on the PJ.
jdsmoothie is offline
post #3 of 5 Old 06-22-2014, 06:50 AM
Tom Grooms's Avatar
Quoted: 123 Post(s)
Liked: 205
Plug in the mic, follow instructions on the front panel and use the arrow keys to navigate. You don't really need a monitor
Hear me now, Listen to me later....
Tom Grooms is offline
post #4 of 5 Old 06-22-2014, 09:11 AM - Thread Starter
Quoted: 43 Post(s)
Thanks to all!
post #5 of 5 Old 06-23-2014, 08:25 AM - Thread Starter
Quoted: 43 Post(s)
Without a monitor how do I disable the amps I don't need? I'm only using fronts. Does this free power for the fronts?
