Issues with Yamaha RX-V577 - AVS | Home Theater Discussions And Reviews
post #1 of 7 Old 06-21-2014, 09:03 PM - Thread Starter
Liked: 0
Hey Everyone,
I just finished setting up my new Yamaha RX-V577, which up until today, I absolutely loved. Hooked into the RX-V577 are the following HDMI inputs:
- HD Cable Box
- Apple TV
- Sony BluRay
All three worked like a charm up until today.
This evening, as I was about to watch some Netflix on the Apple TV, I just got a pink screen, without any signal. I thought it may be the HDMI cable, so I changed it out - nope, still didn't work. I thought it could be the Apple TV, so I changed it out (we have two), nope - didn't work. I then decided to try the other HDMI inputs, and none worked.
Now, it is important to note that it's not the line to the TV, as I tested it directly on the Apple TV and other devices, and there weren't any issues - something is stopping it at the RX-V577. No audio or video is coming through.
I wondered if any other Yamaha owners have encountered a similar issue and if you had any fixes that you could share.
Appreciate the help.
BWG80 is offline
post #2 of 7 Old 06-21-2014, 09:21 PM
grasshoppers's Avatar
Quoted: 345 Post(s)
Liked: 211
I would try a reset of the micro-processor.
Your troubleshooting is solid.
If a reset of the AVR doesn't help
You may have a defective HDMI board.
grasshoppers is online now
post #3 of 7 Old 06-22-2014, 03:09 PM - Thread Starter
Liked: 0
grasshoppers, that did the trick. Thanks a lot!
For anyone who experiences this, you can use the instructions from a 575 to reset the factory. Her is a link:
http://faq.yamaha.com/us/en/article/...k_u/10656/7752
BWG80 is offline
post #4 of 7 Old 06-22-2014, 04:17 PM
Quoted: 345 Post(s)
Liked: 211
Glad to hear it worked!
post #5 of 7 Old 06-28-2014, 08:41 PM
dlnester's Avatar
Did that fix your issue still? Mine I reset the power, and it worked for a few days and back to the pink screen (saying Decoder Off on the display)
I pull the HDMI out, plug it back in and it works too. I might return this for a Sony or Harman/Kardan
dlnester is offline
post #6 of 7 Old 12-28-2014, 07:33 PM
benfromreu's Avatar
Liked: 0
It might be the HDMI handshake order. Depending on which order the inputs are connected/powered on it can mess with this. I had a similar issue with my laptop and my Chromecast.
benfromreu is offline
post #7 of 7 Old Today, 04:30 PM
hmfriedchicken's Avatar
I get the same issues and reset does the trick every time.
The instructions posted is for the RX-V575 and not RX-V77, i tried that it it didn't reset. I just hold the power button until the red light next to it disappears. Or when I'm lazy, I just toggle my power strip. I'll go with different brand next time.
hmfriedchicken is online now
Gear in this thread - RX-V577 by PriceGrabber.com
