no sound in ARC mode - AVS Forum | Home Theater Discussions And Reviews
Old 06-24-2014, 07:44 PM - Thread Starter
Josh Stratton's Avatar
I have a Samsung TV (plasma F8500) and an Onkyo receiver (HT-R390). I have a PS3 going into the game port of the receiver and the out going into the TV. The PS3 audio works fine.
I recently tried enabling ARC mode (to auto) on my receiver and turned the mode on on my television. When I start a program like netflix on the TV I can see the volume go up/down on the TV and receiver when I adjust the volume on the TV remote. When I turn off the TV with the TV remote the receiver also turns off. That all seems to make sense, but the only issue is I get no sound. I'm told my TV needs to be sending a PCM signal, which is the only option in the menu (the other two are disabled--possibly because of the ARC?) and I can see PCM on the display of the receiver.
Are there any steps I can take to debug the missing audio? I purchased an optical cable since my TV has an optical out and my receiver has an optical in, but I don't know how to use that either and my manuals say practically nothing about using one.
Josh Stratton is offline
Old 06-24-2014, 09:39 PM - Thread Starter
Solved! After a few days of mucking with it, I finally got an Samsung's technical support. So I actually had to go into "Digital Audio" in the receiver setup (separate from the ARC configuration) and tell the receiver to use the second optical input when in "TV" mode.
Old 06-24-2014, 09:46 PM
DaJoJo's Avatar
Quoted: 354 Post(s)
Liked: 783
if you want multi-channel sound from the built-in mediaplayer just play a dts movie on the tv and then go into the menu and set sound to dts. for tv sound in multi-channel you need to set it in menu broadcast as well. weird thing is this cannot be chosen while it is not playing anything with dts or dolby digital sound in it. you can only set dts2:5 when it is on external speakermode also. hope this helps you.
Klipsch fronts 2xRF-82-II 150W 33Hz-24KHz , center RC-64-II 200W 59Hz-24KHz , sides 2xRS-62-II 150W 50Hz-24KHz , rears 2xRB-81-II 150W 44Hz-24KHz , heights 2x Salora T25i
Yamaha RX-A3040, SVS PB13-Ultra 1000W 14-200hz
4 mm el cheapo wire / Samsung UE-ES8000S TV+evo 2014 / Optoma DH-1015 Sony PS3
DaJoJo is offline
arc , f8500 , ht-r390 , Samsung
