Denon x-2000 no tv for setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 06-24-2014, 09:21 PM - Thread Starter
prestonrich's Avatar
Quoted: 43 Post(s)
I just bought a new open box Denon X-2000 at Best Buy for $320 to be used for 2.2 ch music listening only. I have no manual but did get the Odyssey mike and remote.
I have no hdmi equipped portable tv that I can carry into the listening room to setup that receiver. Using only the readouts on the AVR's screen I was able to setup Odyssey ok, but there are some things I can't seem to do:
1. How do I turn off all amps? The two front mains and subout are the only outputs I use. Would that give me more power to the mains?
2. How do I turn Odyssey off and go either flat or manually change treble/base balance. Is there a continuous loudness control like on the Outlaw's?
3. With no video hookups are there any other adjustments I need to make?
4. Some seem to prefer setting up Odyssey without the external mike. How would I do that w/no tv readout?
prestonrich is offline
post #2 of 7 Old 06-24-2014, 10:47 PM
afrogt's Avatar
Quoted: 1058 Post(s)
Liked: 761
You can't setup Audyssey w/o the microphone. It's called Audyssey, not Odyssey.
if you don't use the mic then you're not calibrating Audyssey.
If you don't have a TV or PC with HDMI input then you're not gonna be able to setup the system properly.
you don't have a computer monitor to connect to the receiver?
Afro GT
afrogt is online now
post #3 of 7 Old 06-24-2014, 11:13 PM - Thread Starter
Quoted: 43 Post(s)
My Laptop has hdmi output only. Sorry about the spelling. I do have the mic and the readout on the AVR said the Audyssey setup was completed.
post #4 of 7 Old 06-25-2014, 05:27 AM
jdsmoothie's Avatar
Quoted: 12208 Post(s)
Liked: 5559
1. The amps cannot be turned off. There's only one power supply, so the two speakers have access to all available power.
2. You can download the Owner's manual on Denon's website ....
http://usa.denon.com/us/downloads/pa...ionmanual.aspx
3. Refer to posts #3-6 in the Owner's thread.
The 'Official' 2013 Denon "E Series" / "X Series" AVR Model Owner's Thread & FAQ
4. You simply play the test tones and use an SPL meter with Audyssey set to Manual mode which turns off Audyssey and allows you to adjust the graphic EQ.
jdsmoothie is online now
post #5 of 7 Old 06-25-2014, 08:52 AM - Thread Starter
Quoted: 43 Post(s)
How much power would be available with only two of the channels driven on this receiver (no speakers hooked into the available jacks)? X-2000 specs show 95 wpc all channels driven.
post #6 of 7 Old 06-25-2014, 08:55 AM
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 519
95w.
95W x 7 is false
fatbottom is offline
post #7 of 7 Old 06-27-2014, 01:41 AM
jdsmoothie's Avatar
Liked: 5559
Most AVR specs are into either 2CH or 1CH ... Denon's are the former.
