The Official Onkyo TX-NR535/636/737/838 Thread. - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 74Likes
post #61 of 1658 Old 08-06-2014, 05:40 AM
Ejs71's Avatar
Quoted: 38 Post(s)
Hi all. I have a 525 that I don't really like that much. I wouldn't mind staying with onkyo and am looking at a 6-7-8 series. One of my biggest issues with the 525 is the display. Whenever I have it on, I like the decoded sound format to be displayed. (Like it does on most receivers) I had a 601 that I LOVED!!! And it would display Dolby D or Stereo or Dolby PL II whenever I was playing something. The 525 only displays the HDMI channel. I realize you can hit a button to display the format, by there's no way to default the reciever to display the sound format. Does anyone know if the 636 737 or 838 does this? If so, I may need to shop elsewhere.
Ejs71 is offline
post #62 of 1658 Old 08-06-2014, 06:09 AM - Thread Starter
WhiskeyOmega's Avatar
Quoted: 127 Post(s)
Originally Posted by alainl View Post
I'm thinking of buying the 636 right away to replace my recently bricked Yamaha V-867 Is this the first report that we're seeing the same "hdmi issues" I've heard about that have plagued Onkyo receivers in the past?
Apart from a couple of bugs which can be easily fixed with a firmware it's a great receiver
Yea unfortunately it's the same with the 636 it only displays the input all the time and can show the details if you ask for it. I haven't looked to see if this can be changed.
LG 55LA970W - Oppo 103D - Onkyo TX-NR636 - Kef Q1,5,9C speakers and Rel 150 sub - Sennheiser HD650 Headphones
WhiskeyOmega is offline
post #63 of 1658 Old 08-06-2014, 09:53 AM
zeus33's Avatar
Quoted: 1508 Post(s)
Liked: 1323
I'm not sure if the 838 does, but my 818 does.
zeus33 is offline
post #64 of 1658 Old 08-07-2014, 10:30 AM
gimmepilotwings's Avatar
Does anyone have any ideas why I can't get my 838 to view my HTPC/TV correctly in its native resolution? When I set it to 1920x1080 32 bit 60hz, I only get a fullscreen size window.
I am using a Sony TV connected to a HTPC using Radeon 5450 and Vista Ultimate.
I was using Onkyo 805 and that was able to use the correct resolution.
I have tried adjusting the display settings on the PC, changing the HDMI inputs from PC to STB with no luck.
Edit: If I set my TV to say 'This is my main monitor, I get full resolution. When I set it back, I do not. Very weird. Any ideas?
gimmepilotwings is offline
post #65 of 1658 Old 08-07-2014, 11:58 AM
TweakerInWA's Avatar
Quoted: 442 Post(s)
Liked: 212
If you set the display properties to "Through" while you're on the PC input (I assume that's where you've connected it anyway), you shouldn't have any issues. You can set each input resolution individually. If that doesn't fix it, I'm going to say the issue is with the Sony, not the Onkyo.
Sent from my SM-N900T using Xparent BlueTapatalk 2
TweakerInWA is offline
post #66 of 1658 Old 08-11-2014, 08:58 AM
bargervais's Avatar
Quoted: 1636 Post(s)
Liked: 968
Hi all. I have a 525 that I don't really like that much. I wouldn't mind staying with onkyo and am looking at a 6-7-8 series. One of my biggest issues with the 525 is the display. Whenever I have it on, I like the decoded sound format to be displayed. (Like it does on most receivers) I had a 601 that I LOVED!!! And it would whenever I was playing something. The 525 only displays the HDMI channel. I realize you can hit a button to display the format, by there's no way to default the reciever to display the sound format. Does anyone know if the 636 737 or 838 does this? If so, I may need to shop elsewhere.
my 616 is the same way my 818 does display Dolby D or Stereo or Dolby PL II i will be getting my 737 tomorrow and i'll let you know. the only way i could see it on my 616 is I have to toggle through the red movie/tv button on my remote (but if you just hit the botton once it will display) hope that helps
DEN Atmos Samsung UN65KS8000 Roku Ultra Onkyo TX-RZ710 5.2.2 UHD audio. Polk Audio OWM3 Speakers / top middle on Ceiling / 300MGB Spectrum / Samsung UBD-K8500 Blu-Ray Player / 26 UHD Blu-Rays Living Room Atmos Samsung PN60E8000+SEK2000 / Onkyo TX-NR 1030 7.2.4 /Onkyo M-5010 Amplifier for top middle/ 300MGB Spectrum / Panasonic 3D blu-ray Bic Acoustech speakers, MICCA M-8S FH on wall /TM in ceiling speakers / 2 Bic F12 subs. BEDROOM Samsung 55JS8500 using tv speakers for now
bargervais is offline
post #67 of 1658 Old 08-11-2014, 02:20 PM
huy30's Avatar
Quoted: 16 Post(s)
Just ordered 838. I went with 838 over 636 just b/c more power watts of 838 over 636...Hope it will pay off for not buying separate amp. I will do bi-wiring for the front speakers. Will find out how everything is work out in few days.
huy30 is offline
post #68 of 1658 Old 08-11-2014, 03:53 PM
bargervais's Avatar
Liked: 968
Originally Posted by huy30 View Post
Just ordered 838. I went with 838 over 636 just b/c more power watts of 838 over 636...Hope it will pay off for not buying separate amp. I will do bi-amp for the front speakers. Will find out how everything is work out in few days.
Let us know how you like it I have the 818 and I love it I just ordered the 737 to replace my 616 in the den. I was going to get the 838 to replace my 616 but it's too big height wise to fit. I will replace the 818 most likely the end of next year to get an Atmos receiver that will at least do 5.2.4 hopefully 7.2.4 and that would take a TX-NR 1030 or TX-NR 3030. But I'll have to start saving now. Back to telling you I'm getting the TX-NR 737 to try out Atmos when the firmware is released in September.
post #69 of 1658 Old 08-11-2014, 06:45 PM
huy30's Avatar
Quoted: 16 Post(s)
Anyone know the wireless network spec for 838? I could not find it anywhere. Thanks.
Just learn enough info about Atmos. Sound cool but the most 838 can do is 5.2.2, right? You want at least 5.2.4.
Cant wait to have partial surround sound again...did not buy surround speakers..so just have 2 front and center for now.
huy30 is offline
post #70 of 1658 Old 08-11-2014, 07:10 PM
Ejs71's Avatar
Quoted: 38 Post(s)
I just heard from Onkyo.
From the 2014 Line, only the 1030 & 3030 show the decoded output
From the 2013 Line the 828 & Up.
Ejs71 is offline
post #71 of 1658 Old 08-11-2014, 08:22 PM
bargervais's Avatar
Liked: 968
Unfortunately the 838 can only do 5.2.2 that's why I chose the 737 it's the same way 5.2.2 and its a little less money. FOR MY den that will have plenty of power for that room, being it's such a small room and that should fill the room nicely. In order to get 5.2.4 you will need to upgrade to at least the TX-NR 1030
post #72 of 1658 Old 08-11-2014, 08:32 PM
bargervais's Avatar
Liked: 968
I should have my new TX-NR 737 sitting on my door step when I get off work tomorrow. I'll unbox it and set it up tomorrow night it should be quite simple as I have banana plugs on my 616 I'll pull it out clean any dust that's under it for a year and a half now. These electronic stuff are dust magnets I'm always seeing an accumulation of dust and you know what dust can do to electronics if too much dust gets inside the AVR it doesn't cool as it should.
So much about dust sorry I got a little side tracked...
post #73 of 1658 Old 08-12-2014, 09:02 PM
bargervais's Avatar
Liked: 968
I just got my new TX-NR 737 spent about an hour unboxing pulling out my 616 and swapping receivers. I cleaned the shelf of all the dust can't believe the amount of dust accumulates in just a year and a half. I'll mess around with it tonight and let you know what I think if you are replacing an onkyo things are very similar, not a big learning curve.
post #74 of 1658 Old 08-13-2014, 12:40 AM
jdsmoothie's Avatar
Quoted: 13726 Post(s)
Liked: 6396
A 5.2.2 setup with ceiling speakers directly above the main listening position should still provide a good experience, or likely not much less of one than 5.2.4.
jdsmoothie is online now
post #75 of 1658 Old 08-13-2014, 01:40 AM
pettern's Avatar
Quoted: 95 Post(s)
Liked: 38
The spec says the 636 has no optical inputs. Is this really the case? It's weird how Onkyo downgrades the receivers. i.e. the 616 has 8 HDMI inputs, and comparable models has been downgraded since then it seems.
pettern is offline
post #76 of 1658 Old 08-13-2014, 06:13 AM
jerryez's Avatar
Quoted: 28 Post(s)
The 636 has one optical input. I replaced a Yamaha 765(that got fried by a power surge from lightning). The 636 has much better sound than the 765 and is much easier to setup and the setup is much more user friendly. The 636 remote may not be the best but the 765 remote was way too crowded with too many small buttons. I am very happy with the TX-NR636 over the Yamaha 765. I HAVE A Samsung hdtv and a Samsung BR player with HDMI CEC and they work very well thru the 636. They did not work thru the Yamaha 765. The audio switching on the 636 is easier than on the 765 also.
Jerry
Samsung PN63B550 HDTV
Dish HOPPER with Sling
TiVo Roamio OTA
Onkyo TX-NR636 with Polk 7.1 speakers
Samsung pn1600 Blu Ray Player
jerryez is offline
post #77 of 1658 Old 08-13-2014, 07:28 AM
bargervais's Avatar
Liked: 968
i just got the TX-NR 737 the reason being it's a first generation of an atmos AVR when the firware is released. I got it instead of the 636 was because of THX for one and i didn't want to get the 838 because of the cost difference and still only be able to do 5.2.2. On the 838 my understanding is that you can't use an external amp to add 2 more channels like I'm doing with my 818 is that correct... love my 818.
Thanks for your imput right now i have my highs about 1/3 the distance toward my MLP from the front mains should i move them back to be above my surrounds firing down from the ceiling to my MLP.
post #78 of 1658 Old 08-14-2014, 04:04 PM
Quoted: 33 Post(s)
Reasonably positive review of TX-NR838 (4s & 5s rating) - say they didn't notice a big AccuEq effect. It looks like it puts out a decent amount of power for a mid-range AVR.
http://www.soundandvision.com/conten...38-av-receiver
TweakerInWA likes this.
DoDaLeCa is offline
post #79 of 1658 Old 08-14-2014, 04:26 PM
Quoted: 442 Post(s)
Liked: 212
Love my 838 thus far....
post #80 of 1658 Old 08-14-2014, 07:19 PM
BostonHxC's Avatar
Had mine for 2 weeks now and loving it. Came from a Pioneer Elite VSX-23TXH which I had and enjoyed for years.
I have an Emotiva XPA-3 powering the front 3. I cannot wait to hear Armos at home. Anyone know when the update is expected?
BostonHxC is offline
post #81 of 1658 Old 08-15-2014, 05:45 AM
jerryez's Avatar
Quoted: 28 Post(s)
Sometime in September, which probably means the 30th.
Jerry
TiVo Roamio OTA
jerryez is offline
post #82 of 1658 Old 08-15-2014, 10:49 AM
BostonHxC's Avatar
Thanks Jerryez
post #83 of 1658 Old 08-15-2014, 02:57 PM
bargervais's Avatar
Liked: 968
I guess I'll have to wait
I'm looking forward to atmos in my den.
post #84 of 1658 Old 08-16-2014, 11:47 AM
Quoted: 442 Post(s)
Liked: 212
You don't have to wait...It will be available via firmware upgrade. Hardware is already in the box :thumbup:
post #85 of 1658 Old 08-16-2014, 03:02 PM
Ejs71's Avatar
Quoted: 38 Post(s)
Isn't there a way to change the name of an Input. For example: GAME. I want to call it Apple TV. I thought there was a way to do this.
Ejs71 is offline
post #86 of 1658 Old 08-16-2014, 04:21 PM
JChin's Avatar
Quoted: 350 Post(s)
Liked: 204
Hi Ejs71, look under Source Setup menu.
JChin is offline
post #87 of 1658 Old 08-16-2014, 05:05 PM
bargervais's Avatar
Liked: 968
Go to set up then to 4. Source Setup 3. Name Edit and then you can name it what ever you want or like up to I think 9 characters. you can change that name and name it what ever you like..
post #88 of 1658 Old 08-16-2014, 05:15 PM
frocco's Avatar
Quoted: 12 Post(s)
Has anyone A/B the tx-nr636 and strdn1050?
frocco is offline
post #89 of 1658 Old 08-16-2014, 05:32 PM
bargervais's Avatar
Liked: 968
What I meant to say I'll have to wait for the firmware update I already have the TX-NR 737 all hooked up and been playing with it. I should have said I'll have to wait for the firmware.
post #90 of 1658 Old 08-16-2014, 05:44 PM
bargervais's Avatar
Liked: 968
I just got a TX-NR 737 it has Great sound and I've been playing with it maybe a week now, I'm replacing a TX-NR 616 that I've had for a year and a half. I replaced it because I wanted to be ready for atmos and didn't want to spend a lot on a first generation atmos AVR. I was a little concerned that audyssey is being replaced with Accu-EQ. But I read that onkyo and Dolby worked together to develop it.
THE Set up was very easy and after room calibration sound is great, one thing I did use was a db meter to get to subs at 75db which helped a lot. The reason I used a meter, when you first set up with Accu-EQ you get a test tone for the sub but no indication what the db is, got them to 75 and proceeded with the rest of the set up very easy. One thing I did was place the hockey puck Mic on my tripod and placed it in my main listening position I know that it only getting reading from only one position, I'm so use to audyssey XT932 . when I first ran the Accu-EQ I didn't use a db meter which was a mistake on my part because I was just guessing at what volume to set the subs when it was all done I didn't like it was too bombastic. But then I redid it a couple days later using a meter and now it sounds absolutely great IMO.
The only issue I have right now is, which is odd when the receiver is in stand by, the picture passes to the TV from my directv genie box, but no sound tried everything but can't get it to work with my TV. I have directv genie > receiver > Samsung PN 51F 5500
Which is odd is it works fine when I watch a blu-Ray through the receiver from my Panasonic blu-ray player when it's in stand by. It must be some kind of handshake between directv genie box and the receiver, I think it maybe that the genie is not cec ??? don't know just a guess. I'll keep digging to see if I can figure it out I don't think it's the receiver.
This receiver has a great sound and I can't wait till atmos
