Will the Denon X1000 meet my needs? - AVS Forum | Home Theater Discussions And Reviews
Old 07-02-2014, 04:12 PM - Thread Starter
wfsaxton's Avatar
I really don't need much. I would like WIFI control & Pandora. I have 3 HDMI devices to connect. 5.1 speakers.
I do have a separate room with 2 speakers in it though (I just bought this house). I'm guessing they used it to listen to music. Can this receiver handle a "separate" set of speakers?
Here it is for reference: Denon X1000
I may get a 4k TV in the future too...I'm guessing I'll need, at least, the X2000 then instead?
wfsaxton is offline
Old 07-03-2014, 12:45 AM
kikkenit2's Avatar
Quoted: 822 Post(s)
Liked: 303
The X2000 is a 7 channel amp so it will give you 5.1 + zone 2 stereo. The X1000 would need an additional amp.
This pioneer will do the same for $50 less. http://www.amazon.com/Pioneer-VSX-11.../dp/B00BKXCKRC
Both good picks.
kikkenit2 is offline
Old 07-03-2014, 01:17 AM - Thread Starter
wfsaxton's Avatar
Both good picks.
Thanks for the info. I'll have to stick with the X2000 because its 1.5" shallower than the Pioneer and I have really shallow built-in cabinets.
Amazon says that this item is discontinued. Should I be worried about support for it? The newer version supports 4k passthrough, but its also $700 so I don't think I necessarily need that...
wfsaxton is offline
Old 07-03-2014, 01:28 AM
jdsmoothie's Avatar
Quoted: 12138 Post(s)
Liked: 5527
The models are discontinued every year that new models are released. You'll want at least 3-4" clearance above the unit as well as open front and back otherwise consider adding fans.
The 'Official' 2013 Denon "E Series" / "X Series" AVR Model Owner's Thread & FAQ
jdsmoothie is offline
Old 07-03-2014, 07:39 AM - Thread Starter
wfsaxton's Avatar
Yeah, we have an exhaust fan @ the top of the cabinet.
wfsaxton is offline
Old 07-07-2014, 09:44 PM - Thread Starter
wfsaxton's Avatar
Okay, well this sucks. I went ahead and ordered this...The AVR-X2000 does NOT have WIFI control. Only hard-wired ethernet...ugh.
The reason I wanted WIFI was so I could control my receiver/tv etc with an iPad. Without WIFI I either need to buy a wireless bridge for the receiver or an infrared adapter for the iPad.
Anyone have any experience with this?
wfsaxton is offline
Old 07-08-2014, 12:28 AM
afrogt's Avatar
Quoted: 1055 Post(s)
Liked: 757
you dont need a wireless bridge, just get this which is much simpler. I use it with my denon 1613 and can control the receiver with my Android phone from anywhere in the house.
hooks up in less than 2 minutes.
http://www.amazon.com/TP-LINK-TL-PA4...pr_product_top
comes with two ethernet cables also. one adapter connects to your router and the other to your Denon receiver.
Frys has it on sale for $29 until Thursday.
Afro GT
afrogt is online now
Old 07-08-2014, 07:46 AM - Thread Starter
wfsaxton's Avatar
I'm currently already using one of these for my home networking setup so I can't, unfortunately, use another.
wfsaxton is offline
Old 07-08-2014, 08:15 AM
huggybear102's Avatar
It is possible to use more than one powerline device on a network. I used two separate setups, one for a hard wired computer and the other for a satellite receiver.
huggybear102 is offline
Old 07-08-2014, 10:43 AM
batpig's Avatar
Quoted: 3575 Post(s)
Liked: 3420
Can you return it? The new models coming out have added both WiFi and Bluetooth. And the replacement for the X1000, the S1100W, and its non-X series counterpart (S700W) have been upgraded to 7 channels so you don't even need an external amp for Zone 2. If you call up JD at AVScience sales I'm sure he can get you a good deal on the S1100W which looks like it has everything you need including WiFi.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is online now
Old 07-08-2014, 12:21 PM - Thread Starter
wfsaxton's Avatar
JD (offline) suggested I just go with the wireless bridge solution. The X2000 already has 2 zones, so I'm good with that...plus I actually have a wireless router laying around the house so, if I can turn that into a bridge, I might be good to go!
wfsaxton is offline
Old 07-08-2014, 05:46 PM
afrogt's Avatar
Liked: 757
I think you can use 6 - 8 powerline devices. I know adding a second one is not a issue.
Afro GT
