Pioneer VSX-1018AH no subwoofer - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-03-2014, 11:04 PM - Thread Starter
dazz87's Avatar
Quoted: 79 Post(s)
Liked: 40
Hello
Just moved into my new house and was setting up my system and noticed that the sub is not working anymore. I ran MCACC again and it came back saying there was NO SW present.... I made sure that the RCA cable was plugged into both my sub (BIC America F12) and my Pioneer receiver (VSX 1018AH) On the back of my 1018ah the rca cable is plugged into PRE OUT section. I have my fronts set to small and SW to yes at 80Hz. I have switch out the rca cable with another and got the same results.
I went ahead and tested the sub by touching the center conductor (RCA cable) with my finger and I was getting a thump from the sub. So does it mean that my pre out on my receiver is blown? I also have reset the receiver to factory and still no sound from the sub. Any other suggestions? Thanks
dazz87 is offline
post #2 of 3 Old 07-04-2014, 01:58 AM
kikkenit2's Avatar
Quoted: 822 Post(s)
Liked: 303
As long as you connected to the subwoofer out on right side middle and not sub in lower left.
Doesn't look good. Try to go into menu speaker setup and see if subwoofer has an on/off switch.
kikkenit2 is offline
post #3 of 3 Old 07-04-2014, 10:32 AM - Thread Starter
dazz87's Avatar
Quoted: 79 Post(s)
Liked: 40
Yeah doesnt look good..... There is no setting in the menu that has a subwoofer off and no switch. I did a factory reset of the Pio and still no go. I also went in and change the fronts to Large and set the SW to plus and still no sound. Just wondering is there any other way to config the sub without using the subwoofer input on the pre out select?
dazz87 is offline
