AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   Receivers, Amps, and Processors (http://www.avsforum.com/forum/90-receivers-amps-processors/)
-   -   Need AV amp with equlizer (http://www.avsforum.com/forum/90-receivers-amps-processors/1591530-need-av-amp-equlizer.html)
larrylwill 07-04-2014 08:20 PM
I have high frequency loss. Starting around 1k dropping like a rock. Everything below 1-2k is above normal. I can hear normal conversation very good, I just miss the highs, tinkles bells etc. In the old days all amps had a breakout between the pre and power amp where one could put an equalizer. Today I do not see any, or an amp with a decent equalizer built in. I currently use Turtle beach wireless earphones which I can set the equlizer to my likes, but there heavy and hot and.
Does anyone know of an amp that would meet my needs or another solution. (I do not need hearing aids).
MichaelJHuman 07-04-2014 09:49 PM
Some Yamaha AVRs had adjustable parametric EQs. That's about all I can suggest for AVRs.
Pre/main loops and tape loops are mostly a thing of the past. Maybe some stereos still have them
larrylwill 07-04-2014 10:33 PM
Yes I have found that out. I also see almost everyone in any of these forums deplores equalizers. What do people do that have hearing loss?
Many of us in the Army during Vietnam (before ear plugs) have high freq hearing loss, do even people with high freq loss still think the only way an amp should work is flat and pure? I can't even find any sections on any audio forum for people without perfect hearing. There are plenty of speaker forums but a speaker is subjective to ones hearing curve, since its your ears that process any sound, they are more important to any speakers. I used to find on a blind test I chose speakers that to the demonstrator were tinny. They fit my hearing better.
FMW 07-05-2014 05:14 AM
Most AVR's have what you need. I would just recommend staying away from those that use Audyssey. Yamaha, Pioneer and others allow you to make unlimited manual adjustments after the auto calibration. That will allow you to boost the treble to your heart's (or ear's) content. Even the Audyssey equipped units have some manual trim but they are really best for auto calibration.
larrylwill 07-05-2014 12:25 PM
I have a Pioneer VSX 521 but only have 6 steps of treble up/down and the same for base. No real equalizer. Can you suggest something that has one?
afrogt 07-05-2014 12:39 PM
If you're willing to go with a stereo receiver you can still buy an external EQ to connect to it.
http://www.amazon.com/Stereo-Dual-Ch...4588951&sr=1-2
http://www.amazon.com/AudioSource-10...4588951&sr=1-3
Doubt you're going to find a AVR with the tape loop or main-in/pre-out for an outboard EQ.
Or, like the others said try one of the AV receivers with YPAO or MCACC and tweak to your hearts desire.
petew 07-05-2014 12:50 PM
Emotive UMC-200 has an 11 band parametric eq that can be set individually for each speaker pair. It's a preamp only, so you'll need power amps too.
larrylwill 07-05-2014 01:44 PM
My receiver has MCACC, maybe I just don't know how to use it.
I have thought about going that rout. Buying a new pre amp and a new power amp.
67 - 427 07-05-2014 05:23 PM
I think you would need a model with "Advanced MCACC" to access the manual MCACC menus to play with the equalizer, which for your generation of receiver was the vsx 1021 and up
larrylwill 07-05-2014 05:26 PM
Thanks I will look for one, Problem is I do not see in the specs that any have advanced MCACC. I hear Yahama is one with a graphic equlizer but I cant find it listed in their data. Maybe Ill call them Monday.
67 - 427 07-05-2014 05:29 PM
Of the 2014 models vsx 1124 and up have Advanced MCACC
67 - 427 07-05-2014 05:31 PM
Actually I don't think the Elite vsx 44 has it but all others do
larrylwill 07-05-2014 05:33 PM
Yes I seee those 2 listed with advanced MCACC. However the 1124 can be had for under $150 used and shipped, Vrs almost $600 for the vsx 1124, Is there anyplace where I can find the freq bands available to be adjusted?
67 - 427 07-05-2014 05:38 PM
63, 125 ,250, 500, 1khz, 2khz, 4khz, 8khz,16khz
larrylwill 07-05-2014 07:56 PM
Great, Thank you I assume that's for both.
67 - 427 07-05-2014 08:49 PM
Those are for pioneers with 9 band eq, I don't know about yamaha
larrylwill 07-05-2014 09:08 PM
I am reading about the vsx-1021 and it has the 9 band and can be bought used excellent condition for under $150 but I read the video processing is not so great. Although I use my 521 to just pass through video on hdmi so I do not think that will be a problem. I also could care less with the AirPlay, I do not have any Apple devices only android. Do you know of any other candidates.
67 - 427 07-05-2014 10:30 PM
The vsx 1021 has a lower level anchor bay video processor, if possible try to look for a vsx 1121 it has the Marvell processor and is an all around better receiver of that generation, they probably are not that much more expensive on the used market
larrylwill 07-05-2014 10:32 PM
What about the 1022-K seems to get a better rating
larrylwill 07-05-2014 10:41 PM
Looks like Best Buy is full of it, says no
Bluetooth
Digital Coax
Digital Optical
Ethernet
Headphone Jack
Infrared
iPod Connection
But Pioneer says it has it all.
67 - 427 07-05-2014 10:42 PM
Of those 3(1021, 1022, 1121 or even the 1122 for that matter) I would pick the 1121 because of its superior amp section, but you have to pick what fits your needs and budget best
larrylwill 07-05-2014 10:47 PM
Well I bought a used 1121-K
thanks for the help.
67 - 427 07-05-2014 10:57 PM
No problem
larrylwill 07-09-2014 10:08 PM
How does this receiver compare with the -sony str dn840 as far as equalization?
I know the sony is newer and has wifi and Bluetooth built in. Can you control it with an android device or only Apple? Does it brodcast bluetooth to other devices?
67 - 427 07-10-2014 10:59 AM
Not sure about the Sony, the Pioneer can be controlled by android with their iControlAV2 app, optional wireless and Bluetooth adapters are available.
AS BT200 is the Bluetooth Adapter
AS WL300 wireless adapter
I think some netgear wireless adapters might work also
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
