New Receiver set-up question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-06-2014, 12:45 PM - Thread Starter
Quoted: 59 Post(s)
Liked: 6
Just purchased a Yamaha 3030. I am running 9.1 with the AVR and zone 2 and 3 with my 5 channel B&K AV 5000 series II amp. Should I use the B&K to run the front 2 or 3 as it is probably more robust (125w @8ohm...conservatively)? And if I do, will the 3030 power the other 2 zones with its on board amps? Also that little triangular little YPAO accessory that comes with the mike is a different size screw mount compared to the mike. Is it defective or amI missing something. I just used the mike on my tripod to calibrate until I find out.
Sorry, I know that part of these questions should be addressed on the Yamaha page, but it appears as though they are all on a 4th of July holiday
audio.hobby is offline
post #2 of 4 Old 07-06-2014, 04:56 PM - Thread Starter
Quoted: 59 Post(s)
Liked: 6
Your thoughts and advive would be greatly appreciated!
post #3 of 4 Old 07-06-2014, 05:30 PM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 148
I have seen the manuals, and they explain in detail how the amp assignments work. If you read that carefully it might answer some of your questions. I have also resorted to experimentation to understand how the assignments work.
I can't help you with the YPAO accessory. It does seem odd if it's not a standard tripod mount threading/screw
"But this one goes up to 11"
MichaelJHuman is offline
post #4 of 4 Old 07-06-2014, 05:38 PM - Thread Starter
Quoted: 59 Post(s)
Liked: 6
Would you use the B&K for powering the front 3 or 2 if you had a choice and let the Yamaha power the other zones?
