YPAO question - AVS Forum | Home Theater Discussions And Reviews
Old 07-08-2014, 01:18 PM - Thread Starter
Iron_Marshal's Avatar
YPAO question
When preparing to run YPAO should I set the receiver to 0.0db before running, or does it not matter as the adjustments will be made of off whatever volume setting is run at the moment, and that setting becomes the reference level?
Iron_Marshal is offline
Old 07-08-2014, 01:25 PM
Goatse's Avatar
Quoted: 68 Post(s)
Liked: 51
it does it for you, all you need to do is run it
Goatse is offline
Old 07-08-2014, 01:32 PM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 148
You don't need a specific volume setting. I always change all the speakers to small. Never owned a speaker that sounded better when large, even floorstander speakers I have owned benefitted from being crossover over at the subwoofer
"But this one goes up to 11"
MichaelJHuman is offline
Old 07-08-2014, 02:10 PM
crn3371's Avatar
Quoted: 239 Post(s)
Liked: 192
YPAO doesn't care what the volume setting is. It does have the tendency to set your speakers to large, which in most cases is incorrect (assuming you have a sub). Let it do it's thing, then go back into settings and change your speaker size to small.
crn3371 is offline
Old 07-08-2014, 03:37 PM
M Code's Avatar
Quoted: 717 Post(s)
Liked: 419
Before running YPAO...
Be sure to set the level control on your Subwoofer to about 50% rotation....
Just my $0.05...
M Code is offline
Old 07-09-2014, 08:44 AM - Thread Starter
Thanks. The reason I ask is I've done what was recommended.....let it do its thing, set sub volume to 50% and turn crossover all the way up as instructed. It does set my rear surrounds in my 7.1 system to large, which I then fix in the menu. After having done all of that, my surround sound effect is nothing to write home about. I put in the scene from Master & Commander where the two ships are fighting and the volume on the surrounds is so low as to be barely noticable. I've watched several movies and not once have I had that sense of immersion. I'm trying to figure out why.
Old 07-09-2014, 09:03 AM
Quoted: 266 Post(s)
Liked: 148
Use the test tone feature. All speakers should sound at roughly the same volume
Old 07-10-2014, 07:09 PM - Thread Starter
I used the test tone feature and calibrated with an spl, but when I watched either Master and Commander or Mr and Mrs Smith, the surround effect was hardly noticeable. Doesn't seem to be a huge improvement over 3.1 to be honest.
Old 07-11-2014, 12:27 PM
Quoted: 266 Post(s)
Liked: 148
Odd
I have no problems hearing surround info on that movie, I just tested it. The scene where Mr. Smith has the rocket launcher and uses it has surround sound for sure. I don't know if your expectations are wrong or if something else is wrong.
