Active sub won't switch from stand-by to active - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 07-09-2014, 04:29 PM - Thread Starter
Liked: 0
Hi,
I have a Pioneer s-21w at the moment, been using it in combination with a Sony STR-DH540 for a while now without any issues.
However, today the sub wouldn't go from stand-by to active when there was a signal (wii U for example).
What could be the issue? Is there something wrong with the sub or could it be the receiver?
If it's the sub: I had my eye on the Pioneer s-51w, would it be an upgrade?
Freditor is offline
post #2 of 12 Old 07-09-2014, 04:36 PM
jdsmoothie's Avatar
Quoted: 15052 Post(s)
Liked: 7262
Lower the gain knob on the sub to about 9 o'clock and then run the Sony speaker setup again if it's got one.
jdsmoothie is offline
post #3 of 12 Old 07-09-2014, 04:39 PM - Thread Starter
Liked: 0
Lower the gain knob on the sub to about 9 o'clock and then run MCACC again.
Should have mentioned I'm a bit of a noob :-)
Gain knob? Is this the volume knob?
Also, isn't MCACC exclusive to Pioneer receivers? I have a Sony.
Freditor is offline
post #4 of 12 Old 07-09-2014, 04:42 PM
hotrod351's Avatar
Quoted: 14 Post(s)
no, the other knob. HZ
hotrod351 is offline
post #5 of 12 Old 07-09-2014, 04:44 PM - Thread Starter
Liked: 0
It doesn't have a knob other than the volume knob
Freditor is offline
post #6 of 12 Old 07-09-2014, 04:53 PM
jdsmoothie's Avatar
Liked: 7262
Yes, the volume knob on the sub. And yes, confused your AVR with the Pioneer sub, so if the Sony has some kind of speaker setup program, then run it again after lowering the volume on the sub.
post #7 of 12 Old 07-09-2014, 05:02 PM
hotrod351's Avatar
Quoted: 14 Post(s)
sorry about that figured it had a high cut control like my yamaha. i know that most receivers also have that control in the receiver itself. but i think thats what the other person is talking about. turn the gain down, therefore turning the high cut down to a lower HZ. but if your doesnt have this then i guess you would have to do this in your receiver. better yet call pioneer.
post #8 of 12 Old 07-10-2014, 01:21 AM - Thread Starter
Liked: 0
Thanks for all the replies!
Did all of the aforementioned but alas... with no success.
Could the sub be busted? As for the other question: would the s-51w be an upgrade?
Here's a comparison:
http://www.pioneer.eu/nl/products/42...05&__P31=48335
Freditor is offline
post #9 of 12 Old 07-10-2014, 02:52 AM
jdsmoothie's Avatar
Liked: 7262
Also make sure that the main FL/FR speakers are set to at least SMALL/80Hz. If the sub isn't powering on at all (even for DD/DTS 5.1 audio), then there may be a problem with it.
post #10 of 12 Old 07-10-2014, 03:57 AM - Thread Starter
Liked: 0
It woudl seem weird that it had something to do with the settings, since I've been using it for about half a year now and I haven't changed anything.
It might only be for linear PCM that it's not powering on, have to check it.
Freditor is offline
post #11 of 12 Old 07-10-2014, 05:50 AM - Thread Starter
Liked: 0
Odd... did the auto-calibration again and now it seems to work! Oh well... all the better ;-)
Anyone know what could have caused this?
Not really necessary anymore but interesting for later: would the Pioneer s-51w be a good upgrade?
Thanks for the help everyone!
Freditor is offline
post #12 of 12 Old 07-10-2014, 09:12 AM
jdsmoothie's Avatar
Liked: 7262
Not really. You'd want to go to a 300W-400W 10" or 12" sub for an upgrade.
