Datastat LS10 User Thread - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Ganymed4
post #1 of 22 Old 07-09-2014, 09:33 PM - Thread Starter
Gideon's Avatar
Hopefully all Datasat LS10 users could join this thread to share your set up; observations; tips; challenges and suggestions to Datasat manufacturer on future improvements via software updates etc.
Gideon is offline
post #2 of 22 Old 07-09-2014, 09:48 PM - Thread Starter
Gideon's Avatar
First observation:
Datasat RS20i provides SPL levels for each channel whilst LS10 does not indicate it in the manual. Interestingly, RS20i recommends L/R/C at 85 dB; SW/LS/RS/RSL/RSR at 82 dB. The Volume control at -15dB and running the pink noise on each channel, one by one.
Unfortunately LS10 manual does not indicate any recommended SPL setting for each channel.
My setting:
L/R/C/SW1/SW2 at 75dB; LS/RS/RSL/RSR at 72 dB.
My guess for RS20i to suggest lowering the surrounds by 3dB is to compensate for the increase in 3dB when both side and rear surrounds are activated at the same time. Experience wise, indeed this suggested setting blend in very neatly without creating higher surround sound as compared to the front speakers. Other users may want to share your experience through experimenting.
For Datatsat Manufacturer:
Please provide update to the LS10 Manual and provide recommendation for the SPL setting for each channel. By the way, setting it at 85dB is well too loud. In most recommendation, 75 dB is more manageable.
Gideon is offline
post #3 of 22 Old 07-09-2014, 10:11 PM
noah katz's Avatar
Quoted: 880 Post(s)
Liked: 304
noah katz is offline
post #4 of 22 Old 07-10-2014, 06:30 AM
stephenbr's Avatar
Quoted: 161 Post(s)
Liked: 72
Great to know that we have an LS10 owner - really interested in your thoughts on the unit and how it compared to what you may have had previously.
stephenbr is offline
post #5 of 22 Old 07-11-2014, 04:21 AM - Thread Starter
Gideon's Avatar
Replaced my MC 8B which was connected to the HTPC with analogue inputs via HDAV Deluxe sound card.
Now with LS10, the HTPC is connected via HDMI and for movie wise, it offers much superior surround with much more detail dynamism.
Music wise by playing CD via the SACD player via 2 channel analogue as well as coaxial, the stereo channels sound better than MC 8B but not for the surround modes of LS10 as compared to Logic7 as presently LS10 is producing strange static noise in the front speakers. Believe there is a lingering bug somewhere.
So, movie LS10 better than MC 8B
Music MC 8B is better in Logic7 at the moment due to the static noise of LS10.
Gideon is offline
post #6 of 22 Old 07-15-2014, 03:24 PM
stephenbr's Avatar
Quoted: 161 Post(s)
Liked: 72
Any updates Gideon (eg have you resolved the static problem)?
post #7 of 22 Old 07-16-2014, 03:40 AM - Thread Starter
Gideon's Avatar
Datasat is working on it and still waiting for the upgrade software.
Gideon is offline
post #8 of 22 Old 07-16-2014, 03:48 AM - Thread Starter
Gideon's Avatar
Hope that LS10 users found this thread and share their experience.
Other observations:
1) How to calibrate the parametric EQ for each of the channel? The manual is too simplistic and even the dealer has yet to learn the skill to do it correctly.
2) Explain height gain in the Dolby PLIIz mode? What is the most suitable height gain to be used?
3) Dynamic Range Control
What does ‘On/TrueHD-Auto’ means? Does it meanthat whenever TrueHD is played, this ‘On/TrueHD-Auto’ will be automatically setto ‘ON’ and if the media does not contain TrueHD, then ‘On/TrueHD-Auto’ wouldbe automatically set to ‘OFF’?
4) High Pass/Low Pass Filter
a) When to set it to 12dB/octave as compared to 24dB/octave?
b) Does it need to be the same value as compared tothe subwoofers?
Anyone?
Gideon is offline
post #9 of 22 Old 07-16-2014, 04:01 AM
Billybobjimbob's Avatar
Quoted: 126 Post(s)
Liked: 39
Is your unit Auro 3D ready? Or did this aspect not interest you?
21inch hitachi
Billybobjimbob is offline
post #10 of 22 Old 07-16-2014, 04:18 AM
stephenbr's Avatar
Quoted: 161 Post(s)
Liked: 72
Good to hear Datasat are onto your problem - they are great at addressing such issues.
In respect to your questions I can assist on some:
1. No experience using PEQ so hopefully someone else can chime in
2. See above - still to set up heights myself so haven't played with any such parameters
3. DRC will be applied to DD soundtracks or otherwise if a TrueHD codec is detected - I personally don't need DRC so set it to off
4. Really up to you, your speakers etc as to which crossover slope to use. The higher the number the more 'severe' the slope. Just means you attenuate the frequencies at the crossover frequency more quicker if you use a 24db slope. I suggest you try both, listen to the results and use the one you like best. Values can be different for each speaker pair in the RS20i so assume it is the same for the LS10.
post #11 of 22 Old 07-16-2014, 09:19 PM - Thread Starter
Gideon's Avatar
It is optional and presently waiting for Datasat to solve the static noise challenge.
Gideon is offline
post #12 of 22 Old 07-16-2014, 09:27 PM - Thread Starter
Gideon's Avatar
I am using 3 front M&K S150; total 4 side and rear M&K SS150; 1 M&K 150 sub & another 1 M&K 350 sub. As for the subs, it is recommended to use 24 dB/octave slope pairing with non-THX sound processor but nothing mention for the rest of the M&K speakers. So, at the moment, just set to 24 dB/octave slope for all speakers for balance stage I supposed.
Gideon is offline
post #13 of 22 Old 07-17-2014, 07:34 AM
thebland's Avatar
Quoted: 1490 Post(s)
Liked: 841
Are there any theoretical advantages of Auro 3-D upmixing vs DTS NEO X?
It's back!! Wine of the Week! Clos Martinet Tinto, Priorat DOCa, Spain ~$60. If you've not had a good Priorat, you've not truly tried Spain's smallest, yet most unique terroir.
My Home Theater of the Month- Le Petit Trianon
thebland is offline
post #14 of 22 Old 07-17-2014, 09:45 AM
stephenbr's Avatar
Quoted: 161 Post(s)
Liked: 72
Whilst you lose the 'wides' speaker option with Auro you gain the option of a centre height, side heights and VoG speaker options. By the comments of those that have heard Auro it is a significantly improved and more enveloping experience to Neo X with these additional speakers.
post #15 of 22 Old 07-18-2014, 09:27 AM - Thread Starter
Gideon's Avatar
Weird Observation
Unstable VolumeSetting
On 18 July, at about10.30pm, while watching The Monument Men movie with the volume set at 28 dB,suddenly became much louder while the movie was 4/5 of the movie, and it wasfound that the volume indicated at the LS10 at 25 dB. The ethernet was notconnected and it seemed that the volume was somehow raised by itself.
Any LS10 or even RS20i have similar weird experience?
Gideon is offline
post #16 of 22 Old 07-18-2014, 04:12 PM
stephenbr's Avatar
Quoted: 161 Post(s)
Liked: 72
I have never had the RS20i change volume by itself.
post #17 of 22 Old 09-01-2014, 06:07 AM
stephenbr's Avatar
Quoted: 161 Post(s)
Liked: 72
Any update Gideon on how the LS10 is going?
post #18 of 22 Old 09-24-2014, 05:42 AM - Thread Starter
Gideon's Avatar
Datasat came out with the stable firmware upgrade and now there is no static noise when one is playing music. Hurray!
Gideon is offline
post #19 of 22 Old 09-24-2014, 05:52 AM - Thread Starter
Gideon's Avatar
Which mode would one use when playing music through CD?
1) DTS NeoX with music or
2) Dolby PLIIx with music with:-
a) Panorama On or Off
b) Center Width 0 (Off) to 7 (Phantom), which value would you select? Why?
c) Dimension +7 (Full Surround) to -7 (Full Front), which value would you select? Why?
I am using Dolby PLIIx with music with Panorama On; Center Width at 3 and Dimension at -7.
Kind of preference.
Gideon is offline
post #20 of 22 Old 04-01-2016, 05:34 PM
Ganymed4's Avatar
Quoted: 103 Post(s)
Liked: 80
Hi guys,
Is there really only one owner of an LS10 in this thread? I am seriously planning to switch from my Denon AVP A1 to the Datasat LS10 and there have been no new posts in this thread since 2014. It seems, most people go the Hi-Fi way with D&M stuff, or am I wrong?
Is the LS10 too expensive and are people too tired of 'upgrading'? I fully understand this. That's why I am looking into Datasat. They are expensive but they offer upgrades, because there machines are built different.
So what do you think? Thank you in advance.
audvid likes this.
Ganymed4 is offline
post #21 of 22 Old 07-04-2016, 12:41 PM
audvid's Avatar
Quoted: 347 Post(s)
Liked: 94
Originally Posted by Ganymed4 View Post
Hi guys,
Here is another thread for the datasat ls10
audvid is offline
post #22 of 22 Old 07-05-2016, 04:16 AM
Ganymed4's Avatar
Quoted: 103 Post(s)
Liked: 80
Thank you audvid, always helpful.
Ganymed4 is offline
