AVR shutdown and went into protect mode - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-12-2014, 07:42 PM - Thread Starter
imaginos777's Avatar
Question AVR shutdown and went into protect mode
Well, my Aventage RX-A820 broke.
I was listening to it in 2 channel pure direct mode, with no speakers connected to the AVR, only 2 lines out to a power amp which was connected to my FL and FR speakers.
Admittedly I was cranking it, but the power amp was not being worked hard and there was no sonic distortion to speak of. Mid song the AVR switched off and would not come back on again.
Heat at the time was negligible.
Unplugging, waiting and trying again did nothing. So it is now at the repair center. But I don't want to do this again, so I am wondering if I could have caused the fault.
any guesses as to what went wrong?
could I have had a setting mistake? If I am simply using the the AVR as a processor with the preouts, is there any special thing I have to do in the menus?
imaginos777 is offline
post #2 of 4 Old 07-12-2014, 07:51 PM
stormwind13's Avatar
Quoted: 62 Post(s)
Liked: 96
Sometimes it just happens. Not much you could have done it sounds like.
stormwind13 is offline
post #3 of 4 Old 07-12-2014, 08:25 PM
BassThatHz's Avatar
Quoted: 2296 Post(s)
Liked: 2038
Make sure it isn't your AMP.
Maybe your amp sent a surge up the RCA cable to the RX and fried it? Unlikely, but it's a possibility.
If you fix the RX and plug it back in, what's to say it won't happen again?
Hopefully your repair technician will be able to tell you the EXACT cause of the failure, and how to prevent it again (if applicable).
Maybe it failed because the amp drew so much power it caused a long-term brownout?
Could be a million things, we can only guess.
BassThatHz is offline
post #4 of 4 Old 07-13-2014, 04:58 PM - Thread Starter
is this even possible? how could current go backwards thru the preout line?
Does anyone have any other guesses or insights as to the cause of failure?
