What cabling do I need for my home theater? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-15-2014, 01:16 AM - Thread Starter
Mav99l's Avatar
Quoted: 14 Post(s)
Hi all,
I'm setting up my first home theater. I have Polk LSi15 fronts, LSiC center, LSiFX surrounds, a Definitive sub, Emotiva XPA-2 to power the fronts and an XPA-5 to power the rest. There will be a receiver, which I'm still deciding on (leaning towards Denon x-4000) a blue-ray player, and an HDTV. I'll probably get a DVR from my cable company too, and the cable box.
The components will all be housed near each other (probably housed in a BDI 8929--if anyone has one to sell, please let me know).
So what cabling do I need for it all and what do you recommend to get? I may even need to diagram it all out.
Thanks in advance!
Mav99l is offline
post #2 of 4 Old 07-15-2014, 02:57 AM
afrogt's Avatar
Quoted: 1058 Post(s)
Liked: 761
Monoprice.com for everything if you want quality cables for cheap.
You need:
HDMI cables to connect blu ray player, cable box to AVR, and AVR to TV
http://www.monoprice.com/Category?c_id=102&cp_id=10240
Speaker wire, 12ga or 14ga. Maybe in-wall rated wire depending how you run your speaker wire.
http://www.monoprice.com/Product?c_i...seq=1&format=2
Subwoofer cable
http://www.monoprice.com/Category?c_id=102&cp_id=10236
RCA cables to connect from AVR to Amps
http://www.monoprice.com/Category?c_...&cs_id=1021814
http://www.monoprice.com/Category?c_...&cs_id=1023501
Perhaps some banana plugs to make speaker wire connect cleanly to receiver/amps, and speakers.
http://sewelldirect.com/Sewell-Deadb...gs-12-Pair.asp
Looking at that BDI cabinet you might need some fans to suck out all the heat, audio equipment doesn't do well with poor ventilation
Afro GT
afrogt is online now
post #3 of 4 Old 07-29-2014, 12:26 AM - Thread Starter
Mav99l's Avatar
Quoted: 14 Post(s)
Hi, Thanks for the feedback
I'm thinking now of getting the Emotiva XMC-1 pre/pro which has balanced outputs. Since my Emotiva amps have balanced inputs, should I use that instead or the RCAs?
If so, would these be a good choice?
Also, if anyone has an Emotiva upgrade card they want to sell, please PM me.
Thanks in advance!
Mav99l is offline
post #4 of 4 Old 07-29-2014, 04:39 AM
Cal68's Avatar
Quoted: 198 Post(s)
Liked: 144
I would go with the XLR balanced connectors over RCA if you have that option. I have bought balanced connector cables from both Monoprice and Blue Jeans Cables and while both are nice, I liked the ones from BJC a tad bit better. But you cannot go wrong with Monoprice either.
Cal68
Cal68 is offline
