Are Separates Worth It? - Page 12 - AVS Forum | Home Theater Discussions And Reviews
 137Likes
Old 07-21-2014, 06:02 PM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 148
Originally Posted by JHAz View Post
Theoretically because clipping generates higher harmonics there is some chance that a heavily clipping amp into a nearly overwrought tweeter can kill the tweeter. People talk about square waves from clipping but that's horsecrap. Square waves have about forty percent distortion. I doubt you could bear to listen to a system producing forty percent distortion.
If the clipped signal itself could kill speakers there would be no rock concerts or rock records, because the guitars are heavily clipped all the time. An acdc concert would last about 90 seconds before all the pa and guitar speakers blew
There's another theory that it has nothing to do with harmonics. The fact that it's clipping results in a higher average signal level. This makes sense, because rather than being a nice sine wave looking thing, it looks like a plateau, which obviously influences the average signal level. Now you have tweeters "seeing" a lot more watts than they were designed to handle.
At the end of the day though, it's the same problem. If you keep trying to reach rock concert levels with small living room equipment, you are asking for trouble. Alcohol also seems to effect people's better judgement and there's a theory drinking parties kill speakers. I had first hand experience with that once
http://sound.westhost.com/tweeters.htm
"But this one goes up to 11"
MichaelJHuman is offline
Old 07-21-2014, 06:51 PM
JHAz's Avatar
Quoted: 305 Post(s)
Liked: 271
Alcohol literally, through that science crap, has been shown to make things sound quieter. Not a complex thing to put together.
Power is indeed what hurts speakers but you are not talking sbout anything close to 10 percent more power in heavily distorted sound. And literally, again via that science crap, what happens is higher harmonics are generated. Ten percent more power focused above the crossover could come close to doubling power to the tweeter (onaccounta tweeter range usually carries not much more than ten percent of total power. ) that could cause a problem.
To get those plateau thingies requires higher frequency harmonics. That's how it works. Not knowing that's how it works doesn't make it not so. You can watch harmonics flatten out a sine wave on you tube.
Similarly, not knowing the earth is not the center of the solar system does not change the sun's position at the center of the solar system.
JHAz is offline
Old 07-21-2014, 07:03 PM
JHAz's Avatar
Quoted: 305 Post(s)
Liked: 271
Originally Posted by M Code View Post
Lets kleer the air...
Clipping happens when a circuit is overdriven...
The circuit may be an input type like from a source component output level too high or an amplifier output stage. When an output stage is overdriven the amplifier sends out square waves which are very destructive to a loudspeaker, as they cause the motor structure of the loudspeaker (voice coil, magnet and gap) to heat up, twist and turn often destroying itself. Many users think that high output power is what destroys a loudspeaker...
But just the reverse is true, when a lowered power amplifier is pushed beyond its design limits it is more likely to generate the destructive square wave distortion. The square wave distortion destroys the loudspeaker, also note that many users are confused about a loudspeaker load to an amplifier, thinking it is just resistive..
To get a square wave you need odd harmonics adding up to forty percent distortion. Google it. Not a giant secret.
We say an amp is clipping at one percent distortion. A clipping amp just simply does not put out anything resembling a square wave. By a factor of roughly forty.
I have not seen thd for heavily clipping guitar amps, but if they are anywhere close to 40 percent distortion they just do not destroy the speakers in the guitar amp or the speakers in your stereo or the PA speakers at a concert that are reproducing that distorted signal.
The distortion does not kill speakers. Power kills speakers.
JHAz is offline
Old 07-21-2014, 07:40 PM
M Code's Avatar
Quoted: 717 Post(s)
Liked: 419
U are very wrong...
One cannot set a 1% THD level as clipping..
Checkout the THD vs watts of any amplifier test report, in a solid state Class AB amplifier when it clips the THD goes straight up.. Regarding tube amplifiers it has far more gentle THD vs power output graph...
Note we are talking about home theater amplifiers not guitar amplifiers, as guitar amplifiers are actually designed for certain effects with distortion..
U better do more research....
Underpowered amplifier
A common and unfortunately dangerous situation...
As a precautionary measure or unfamiliarity with reality, many users choose an amplifier which is too low in power output...
At high volume levels it will clip and distort, it may supply direct current to the loudspeaker, which will destroy it. During clipping, a 40 Watt amplifier can reach > 100 Watts @ high THD in 1 millisecond....
As a sine wave is clipped, it starts to resemble (and sound like!) a square wave. A square wave is by definition the (infinite) sum of a fundamental frequency and its (EDIT: odd!) harmonics in definite proportion; thus it has a rich harmonic content. This harmonic content, which was not present in the input waveform, is harmonic distortion by definition. When an amplifier starts to clips the wave form gets distorted and squared off..
The attached chart will better explain this for U..
Next question..
Just my $0.03...
M Code is offline
Old 07-21-2014, 07:59 PM
JHAz's Avatar
Quoted: 305 Post(s)
Liked: 271
U are very wrong...
Next question..
Just my $0.03...
Ummm no. Some folks around here define clipping as the point at which the thd vs output curve hits the knee for increasing distortion. That is ususlly around .01 percent distortion. Any moron can go look at third party testing of amps by stereophile or whoever. One percent distortion is a common definition of clipping.
Any moron can google thd of a square wave. It is what it is. About forty percent thd.
Sorry. Reality is what it is.
And odd harmonics are not inherently more problematic than even harmonics. aND, shockingly, if the phase relationships aren't right you don't get a square wave even if the harmonics are in the right proportion. Omg! That squarewave horsecrap is horsecrap!
You need not believe this. The sun will remain at the center of the solar system despite your incomprehension.
Out.
JHAz is offline
Old 07-21-2014, 08:00 PM
Quoted: 266 Post(s)
Liked: 148
I presume he means that 1% is considered, by convention only, the point at which THD might be audible and/or clipping is happening. It's just a convention, and I have read stuff before where people use that exact point.
As for the rest, I also don't consider square waves to be the issue, nor harmonics based on some well written articles, but I won't debate the point.
At the end of the day, power is what kills speakers. Clipping means more average power means more heat means possibly dead speaker drivers. Or you reached the mechanical limits, but that also means average power is too high.
I don't think anyone is debating the point that an amp with insufficient power increases chances of clipping which increases average power in ways speakers are not designed to handle but again the details are not too important - reduce power as needed and you should not be blowing speakers.
Personally I don't care for the logic of saying too little power kills speakers, because, taken at face value, the speakers insta-blow when the power to the amp is off But I know what people mean when they say it.
Old 07-21-2014, 08:19 PM
M Code's Avatar
Quoted: 717 Post(s)
Liked: 419
Out.
Before U sign off for the outer limits..
Check closely the attached graph, it will better confirm your flawed definition that clipping @ 1% THD is bogus...
Check out the power output @ 1%THD, next check it out @ 10%THD, next check it out @ 20%THD...
In a solid state Class AB amplifier as the amplifier is pushed to its max output, power does not increase only the THD%..
Lights out..
Just my $0.03...
M Code is offline
Old 07-21-2014, 08:29 PM
smurraybhm's Avatar
Quoted: 1469 Post(s)
Liked: 1760
When members start referring to others as morons it's time to shut it down, no 2 cents required.
smurraybhm is offline
Old 07-22-2014, 07:43 AM
FMW
FMW's Avatar
Quoted: 1652 Post(s)
Liked: 1681
Lights out..
Just my $0.03...
Here are a few thoughts for you. What destroys speaker voice coils is heat and heat is generated by power. The voice coil is not destroyed by the content of the signal but by the power it must dissipate in order to reproduce it. You can reproduce a square wave without any difficutly and it won't damage your speakers unless and until your speakers must dissipate more power and heat up to the point that wires in the voice coil break. You can download square waves on the internet and play then though your system and they won't hurt a thing. They won't sound pretty but they will play along just like anything else. The problems would only occur when too much power is dissipated and that would occur regardless of what the system is trying to reproduce.
Let me give you an example. I have a solid state guitar amplifier than can play a number of sound samples of distorted guitar. I can pick one that is horribly distorted and play it softly or loudly. It can't possibly be an issue until it is played loudly enough to overheat the voice coil of the speaker. In the case of that unit, it can play any of the samples at full volume without an issue. Why? Because it has an amplifier that is not capable of playing loud enough to break anything. The amp is not OVERpowered for the speaker.
An underpowered amplifier is never an issue because it can't supply enough current to destroy a voice coil. It is an over powered amplifier that has that capability. The underpowered amplifier could possible destroy its own output stage but it would require an overpowered amplifier to destroy a speaker voice coil.
Distortion doesn't hurt speakers. Power does that.
FMW is offline
Old 07-22-2014, 09:01 AM
M Code's Avatar
Quoted: 717 Post(s)
Liked: 419
Go back and read my posts..
We already covered the point about voice coils, heat....
When the loudspeaker's voice coil is overheated many things can happen...
Voice coil/form glue debonds
Voice coil deforms rubbing inside the gap
Voice coil excursion travels outside the gap
Regarding what destroys a loudspeaker power or distortion..
Also as posted previously (see the graph) when a solid state Class A-B amplifier is clipping @ high power output it generating high peaks of distortion plus milliseconds of high power.
About what destroys loudspeakers, power rather distortion..
Here again we disagree..
Kleen high power without distortion is far easier on a loudspeaker than low power with high distortion..
We can easily demonstrate this on virtually any loudspeaker, the crucial point depends upon the load the loudspeaker presents to the amplifier. If highly reactive (4 Ohms, 60 degrees) an amplifier rated @ 100W into an 8 Ohm resistor can decrease to 25W...
When an amplifier is being pushed hard to its limits, the chance of it clipping are very real..
Primary reasons is that the output devices within the amplifier are rated @ 65 degrees for its power output, but as heated up its efficiency drops big time...
As power output decreases, the user then increases its volume level driving the amplifier closer to its limits and going into clipping..
Just my $0.03...
M Code is offline
Old 07-22-2014, 11:47 AM
matcartier's Avatar
I can't talk to sound quality because I've never tested them side by side but I can say that being able to replace just the pre/ pro in you system when it becomes obsolete is cheaper than having to by a whole new AVR. I've had my Marantz MM9000 for 12 years now as the primary amp in my system. It drives the hell out of my cambridge soundworks tower 2's. Ive gone through 3 perfectly working avr's in the same time period because the technology has advanced. Replacing just the pre/pro (I think) has saved me money. FWIW.
Mat
matcartier is offline
Old 07-22-2014, 12:11 PM
FMW
FMW's Avatar
Liked: 1681
Just my $0.03...
I'm just trying to provide information. You don't have to accept it.
FMW is offline
Old 07-22-2014, 12:18 PM
M Code's Avatar
Quoted: 717 Post(s)
Liked: 419
No biggee..
Since we product development & sourcing for (2) of the more popular loudspeaker brands we have some insight and direct experience for this subject...
Just my $0.05..
M Code is offline
Old 07-22-2014, 02:31 PM
Quoted: 266 Post(s)
Liked: 148
Richard Clark wrote an article on it. I had posted the Rod Elliott article, but this is interesting as well -
http://www.monsterproducts.com/mpc/s...Some_Facts.pdf
Some of the key points. Music signals, even clipped are not going to become square waves. The exception might by synthesizers with square wave outputs, but those are imperfect square waves. I don't think any circuit can make true square waves as there's a limit to rise time.
Harmonics are explained as much lower in power, so not a major concern. Other articles I have read have made the same point.
This is the crux - "The real problem for our speaker is that any amplifier can produce more than its rated power if it is
allowed to distort and clipping is a sign that you have probably reached the point where you should turn
things down. To get a real picture of what the speaker sees compare Figures 12 and 13."
That's the bottom line, semantics aside. Clipping results in more power which kills speakers. Which is obviously why the horribly confusing phrase "too little power kills speakers" comes from. It would be clearer to say "Too little amplifier power can kill speakers due to too MUCH AVERAGE power to the speakers, which results from a higher chance of clipping" ( but that would be awkward to say, so I don't know how best to put it)
SimpleTheater likes this.
Old 07-22-2014, 08:07 PM
JHAz's Avatar
Quoted: 305 Post(s)
Liked: 271
Lights out..
Just my $0.03...
I did not tell stereophile to use one percent as clipping. I got it from the hundred or so tests of theirs I have looked at. My understanding is it is used because its a sort of reasonable lowest level at which distortion is likely to be audible with at least one content. S'phile relaxes their standard to 3 percent for some tube amps. Nowhere nesr a square wave.
I simply don't see straight up after the knee in thd vs power charts. But I read How to Lie With Stastics 35 years ago when it was a 10 or 15 year old book and I could easily manipulate the x and y axes to make it look straight up if I wanted to. Doesnt change the fact that I have never seen such a chart that gets anywhere near square waves. Most of the more power is, uh, more power with a relatively slight addition from the clipping.
Eventualy more power will kill a speaker. But it is never distortion per se that does it. I could likely drive a preamp well past square waves if I hit it hard enough. Driving a 100 watt speaker with the maybe 5 watts the 12ax7s or line level opamps might max out at will never ever kill the speaker regardless of distortion level. Otoh hitting them with a couple hundred watts for a while likely would cook them whether the signal is distorted or not. Power kills.
The notion that an amp cannot make more power than its rating at .05 or .1 or even 1 percent distortion misapprehends how the things work. At ten percent distortion, though, the added power inherent in the distortion of the waveform is, I forget, but like 30 dB or so below the clean part of the signal. You can gogle thd percent distortion and identify my egregious errer for yourself but the bottom line will be the same. If -30 dB is correct, the distortion is one one thousandth of the total power. It just seems likely the other, non distortion related 99.999 percent of the power is the killer, not the distortion.
But hey that's just me being rational and crap.
JHAz is offline
Old 07-22-2014, 08:38 PM
M Code's Avatar
Quoted: 717 Post(s)
Liked: 419
U continue to debate reality even though it is displayed to U with graphs and substantiation by credible sources..
The last time U challenged my explanations about output power in another thread U were going to research and present some examples of test reports that backed up your claims..
Onkyo all channel driven?
To date, nothing has been received..
So we are moving on as this thread has run its course... Lights out..
Just my $0.03...
M Code is offline
Old 07-22-2014, 09:12 PM
JHAz's Avatar
Quoted: 305 Post(s)
Liked: 271
Just my $0.03...
Sh. So you cannot comprehend the charts you read. Cannot see what the questiondcare.
Thd has like an actual scientific meaning, dude. I misrenenbered. Ten percent thd means the distortion products are 20 dB below the main signal. Every ten dB is, by definition , a power factor of 10. So a 100 watt output at ten percent distortion includes distortion products by definition at one watt. If the distortion was more than one watt thd would be higher. I tend to believe its the 99 watts, not the one watt, that are the issue.
Perhaps you want to imagine these defined terms nean something different, like in the novek 1984, I just don't know.
Simply is what it is. I lack the mindreading capabilities to see where these simple facts get past you but obviously they do. In the end it is grade school math math I can't fix an inability to add and subtract.
And ftr your arcam results show ten percent distortion just barely ubder 200 watts which is consistent with what I have been saying. so 2 watts of that is distortion and the rest is not distortion. By definition of the terms used.
JHAz is offline
Old 07-23-2014, 05:40 AM
SimpleTheater's Avatar
Quoted: 202 Post(s)
Liked: 94
Just my $0.03..
Just my $0.05..
HOLD down <ALT> then press 0 1 6 2
Just my 2¢
charmerci likes this.
Why is there NO perfect equipment, only compromises?
SimpleTheater is offline
Old 07-23-2014, 09:01 AM
JHAz's Avatar
Quoted: 305 Post(s)
Liked: 271
Part of the difficulty, for a long time for me, and clearly for others, in assessing distortion is the coplete (to me) counterintuitive (not to say utter incompatibility with comon sense) of the fact that complex waves are made up of a whole bunch of sine waves in specific relationships to each other. SO, despite the fact it makes no immediate sense to me, truth is that a square wave consists of a fundamental plus odd harmonics. If the voltage of the fundamental is V, then the third harmonic (H#) is 1/3 of V, the fifth harmonic is 1/5 of V, the seventh harmonic is 1/7 of V, etc. (Note that because of ohm's law, one third voltage connotes less than one third power).
Note that since, AFAIK, no amp in the world produces only odd harmonics when distorting, the even harmonics will make it impossible for the amp to ever actually produce a square wave, because a square wave contains no even harmonics.
The notion that complex waves are made up of sine waves is not new stuff. People ascribe it to J Fourier, a French ella who lived rom 1768 – 1830. So it ain't new stuff. A pretty good tutorial, with oscilloscope demonstrations etc of this with respect to a square wave is at
As a practical matter, those power-versus-THD plots we've seen above and in hundreds of amp tests come from application of a technology called FFT, which stands for Fast Fourier Transform. IOW, the test results depend, in an absolute way, on the accuracy of the Fourier concept that complex waves are made up of sine waves. If the underlying theory that the wave is made up of many sine waves is wrong, then whatever an FFT spits has to be wrong, too. So it would be pointless to continue discussing those meaningless results.
Moreover, AIUI, digital sound relies on FFT to recreate audio from the digital representation. So if the complex waves on CDs, or in the sound of things we get off the internet, are not composed of a series of sine waves, then the entire world has been laboring under a massive delusion that we actually get sound from CDs or off the internet. Not possible, if the underlying theory is wrong. Yet, I seem to hear sound when I play a CD, or when I watch things on youtube. Tends to make it likely that the theory is correct.
For me, seeing with my own eyes a sine wave transform toward a square wave on a scope as the higher harmonics are added made the concept, if not intuitive, at least concrete. I'm no longer uncomfortable with it . . .
JHAz is offline
Old 07-27-2014, 05:28 PM
IntelliVolume's Avatar
Quoted: 1487 Post(s)
Liked: 694
Originally Posted by DrDon View Post
Then don't take the bait.
But -- with respect -- the members starting the subsequent harassment don't have any blame in this, whatsoever? It is our responsibility to not take the bait...but they are permitted to create the bait?
IntelliVolume is offline
Old 07-27-2014, 05:34 PM
Liked: 694
I am saying i learned ohm's law in school when i was 12 ot 13 years old, and so did everybody in the class. It does not require high levels of technical competence to grasp. A decision not to try to grasp it seems like an intentional refusal to understand the basics so reality doesn't interfere with hanging onto beliefs that cannot be true.
And ftr i thought for longer than i would care to admit that somehow the greater power would make a difference even in low power situations. I was silly and perhaps viewing speakers anthropomorphically, like they could see or feel or smell or taste the added power in the amp. I wuz full o ****e.
Big power is only needed when it is needed. Big rooms, long distances to speakers, inefficient speakers, high peak levels may require high power. Peaks are a bitch even if they only last a twentieth of a second. A 20 dB peak requires 100 times the power of the average. Whether the speaker can reproduce the peak without distortion or compression also enters into what you hear. I believe but could not prove my little paradigms plus sub could cleanly hit peaks at 95dB or so (consistent with my real listening levels) but I would not even bet five bucks they can do 105 dB, as required for reference level.
Old 07-27-2014, 05:43 PM
Liked: 694
Hello Rico, and thank you for your continued assistance/input...
Originally Posted by Ricoflashback View Post
I think I understand what you are trying to accomplish. But I believe you said that your Onkyo 605 does not have preouts? (Is it this model - TX-SR605S - 7.1 90 wpc?) If you try to use a line level converter - - you might be limited to 60 watts per channel (or some number like that) I am unfamiliar on how well this will work - - especially if you add different amplifier sources to the mix.
Yes -- the model is the TX-SR605(B) and it does NOT have preamp outputs...I was thinking of adding on a "line converter" device which would transform my speaker-level outputs to preamp outputs (as these devices do with factory car stereos) so I COULD add an amp to this receiver, but I don't know what effect that would have on sound quality. I'm not sure what you mean by "you might be limited to 60 watts-per-channel" when you replied about the line converter; wouldn't the converter be a mere "sendoff" device to feed an external muscle amp?
Now - - here comes the real question and the crux of this whole thread - - separates versus an integrated AVR. Most integrated, multichannel AVRs will go up to 120 wpc. I'm sure some higher end models might go higher but they are expensive. I do not see much of a difference between 90 wpc and 120 wpc. Hence the argument for separates IF you believe more power will benefit your situation.
Yes -- I understand that, thus why I was considering using a new AVR just to power the "less demanding" surround channels of the system while letting an external power amp power either the main two Polk RTi12s or the front three channels altogether in a three-channel model...my question was do you think a new AVR's amp section would be powerful enough for JUST powering surround channels? I don't see why they wouldn't be, especially since I have small-ish in-ceiling SpeakerCraft models...
Many folks in this thread will tell you that you don't need to do anything - - 90 wpc per channel is more than adequate.
It seems so, based on what I'm experiencing now -- but I wanted to experiment with extra power to see what my RTi12s can "really do" if you know what I mean, or to have the reserve wallops of wattage available if/when they're ever called upon...
Lastly - - if two channel stereo is important to you, many multichannel AVR's skimp on the analog outputs. They just do not sound very good. Hence, my purchase of the Parasound 2100 stereo preamplifier to round out my HT. I was listening to Steve Winwood last night (Arc of a Diver - Spanish Dancer and Night Train.) With the Parasound 2100 (via my OPPO 103 Bluray Player - analog outputs) - - and listening in two channel mode - - it sounded like my subwoofer was engaged! It wasn't. Great soundstage and nice, tight thump to the bass.
To me - - that's where the extra power comes in to play.
In closing - - my setup is complete. The only replacement in the future will be a "Preamp." For 4K video and possible Dolby Atmos. But that is four to five years a way.
I hope this helps.
I have a separate two-channel dedicated system in another room from my 5.1 surround rig, also powered by an Onkyo (stereo receiver) so two-channel isn't a priority in the system in question (the one with the Onkyo 605/Polk RTi12 setup).
With regard to your comment about Dolby Atmos -- can you give me some more specifics about this algorithm? Info and specs have been spotty in my neck of the woods; is this something that needs to be implemented with 4K media? I know Onkyo has this in their new AVRs, but how exactly does Atmos work...is it a "matrix spreading" system like Pro Logic II or is it an actual format that we're going to see on 4K discs if/when they ever arrive?
Old 07-31-2014, 04:58 AM
Ricoflashback's Avatar
Quoted: 649 Post(s)
Liked: 349
Sorry I didn't get back earlier as I've been traveling for my work.
RE: Yes -- the model is the TX-SR605(B) and it does NOT have preamp outputs...I was thinking of adding on a "line converter" device which would transform my speaker-level outputs to preamp outputs (as these devices do with factory car stereos) so I COULD add an amp to this receiver, but I don't know what effect that would have on sound quality. I'm not sure what you mean by "you might be limited to 60 watts-per-channel" when you replied about the line converter; wouldn't the converter be a mere "sendoff" device to feed an external muscle amp?
I have read that there are some limitations on line converters - - so my suggestion is to research what you would be buying and see if this is true.
RE: With regard to your comment about Dolby Atmos -- can you give me some more specifics about this algorithm? Info and specs have been spotty in my neck of the woods; is this something that needs to be implemented with 4K media? I know Onkyo has this in their new AVRs, but how exactly does Atmos work...is it a "matrix spreading" system like Pro Logic II or is it an actual format that we're going to see on 4K discs if/when they ever arrive?
There is a whole thread on Dolby Atmos. You'll obviously need to have additional speakers and the AVR will need to process the channels. I do not believe this is "matrix spreading" as it should be discrete channels. Very new technology and not a lot of experience in a home theater environment yet. Hope this helps.
Home Theater Setup
Samsung UN65ES8000 LCD/LED & BenQ W1080ST & Vizio M43C1
Pioneer SC65 (Pre-Amp) & Emotive XPA-3, 200 WPC
OPPO 103, Comcast Infinity X1, Darbee Darblet
ALL Paradigm - 7.1 - Studio 60's, V.2 (FL/FR) CC-690, V.5 (C)
ADP 590 V.5 (SS), MilleniaOne 2.0 (BS) - Velodyne 810 Sub
Ricoflashback is offline
Old 07-31-2014, 05:29 AM
turnne1's Avatar
Quoted: 1754 Post(s)
Liked: 410
things down.
that being said
you are making the case for a better amp section/power supply
ie...higher levels of output with extremely low distortion
right?
the only way to receive that is when a higher end unit...be it a better AVR or a high end separate amp
Warren
Rm 1 Samsung 64F8500 Marantz 8801 prepro Sherbourn 5/1500A amp B&W CM10s..CM2 center...CM5's.rears
Rm 2 Hisense H50C Yamaha A2050 Celestion 305 speaker system
Rm 3 Panasonic 50ST50 Denon4520 Kef 2005.2 speaker system
Rm 4 Samsung 51E8000 Sony DA5400ES Mirage Omni sat speaker system
turnne1 is offline
Old 07-31-2014, 09:50 AM
Quoted: 266 Post(s)
Liked: 148
That was not my point, but of course buying an amp/receiver with more power will let you hit higher SPL without clipping. But as mentioned frequently, you do have to double the power for appreciably more SPL.
The finances of buying double the power is a bit discouraging for people because you need double the power. If I needed double the power of a 100 watt receiver, I would need 200 watts. It's possible the 100 watt receiver can't hit that peak with real world signals, I don't know the answer, but I suspect mid range receivers can, as a general rule. So if I spend $700 for a receiver with pre outs I have to spend $1000 for a 200x5 watt amp. Over twice as much for 3 dB SPL gain.
Of course there's other factors like low impedance capability to consider. It's reasonable to think better than a 3 dB gain will be had with the external amp due to it's better performance into lower impedance loads and the fact 8 ohm speakers are not purely 8 ohm.
Old 08-01-2014, 04:32 AM
BassThatHz's Avatar
Quoted: 2032 Post(s)
Liked: 1550
$700 buys:
8 x 1600watts @ 2 ohms = 12,800watts
8 x 860watts @ 4 ohms = 6,880watts
8 x 440watts @ 8 ohms = 3,520watts
https://www.parts-express.com/behrin...fier--248-6800
Shipped to the lower 48 for free
12db louder on each channel (if you have speakers that demanded power dipping down to 2ohms), otherwise 6.1db on each channel... and you save $300
It's cousin, the nu6000 independently tested at 1800watts continous x 2 @ 4ohms, you can read about that here:
http://forum.speakerplans.com/behrin...opic69202.html
All you need is 8 of these RCA cables to go from your 7.1 pre-outs
http://www.parts-express.com/peavey-...able--241-5576
I heard two nu6000's at Joe's place. He has just over 13,000watts of power in his room, with traditional Hi-Fi amp for treble.
Sounded legit to me...
I use entirely pro-amps for my system.
It should be noted that I have over 35,000watts of treble and bass, and more than 15 subs in my room, so pardon me if I overload my camera's mic, even at low SPL like this
I run an Oppo 105 DAC and Emotiva XSP-1 pre-amp and then a bunch of pro-amps (so separates I guess...)
Sounds good to me!
My mains are a triple 2-ohm load (more or less) and require 2000watts (each) to reach full SPL, so I can't use AVR's, as they would explode (and/or be vastly underpowered).
I'm probably a rare-exception to the general rule of thumb though...
Here are three older videos / versions of my system with the volume knob turned up to ~80% of full-power (subs turned on too). No Holes Barred style
B&W Nautilus 8 series on 8400watts Hi-Fi music: Emotiva UMC-1 (DAC/Pre)
(and Oppo 105/XSP-1 at a much lower volume just for comparison)
My rear speakers 8400watts playing metal: Oppo 105/XSP-1
B&W Nautilus 8 series on 8400watts playing bass heavy rap: Oppo 105 directly
BassThatHz is online now
Old 08-01-2014, 09:37 AM
Quoted: 266 Post(s)
Liked: 148
Not a bad deal for the Behringer.
I had a better experience with Emotiva than I have had with Crown due to noise issues in one case and ground loops in the other. The noise was not audible at the listening position but I never reduced the hum on one amp as much as I hoped. There is an advantage to the Emo with their two wire plug and with amps which give you a one box solution.
Old 08-01-2014, 11:41 AM
AidenL's Avatar
Quoted: 471 Post(s)
Liked: 218
I'm puzzled and I need to make a decision soon, mainly because if I do buy an Amp, I'll probably go for the Emotiva 20% off sale which finishes Sunday.
So, in my case, I sit 14ft from some 89 dB sensitivity Kef speakers. i'm looking to be able to handle reference which I understand to be 105dB peaks. My current receiver seems to give me this, based on a dB meter in my iPhone (if thats reliable?)
Am I answering my own question - that I don't need one then?
Next year I will go to a 7.1.4 configuration in Atmos and then I will need at least a two channel amp, so when that happens I'll have to invest anyway, but for a different reason.
Still, I'm wondering will i get ANY benefit from say and Emotiva XPA 5 over what my 75wpc Anthem MRX510 does if I bolt it onto my system?
Display : JVC X7000 Projector | SE 103" Enlightor 4k | LG 65B6 OLED |
Sources : Oppo UDP 203 Multizone UHD Player | Apple TV3 | HTPC | Sky Q UHD Satellite | Sonos Connect | Synology 24Tb |
Audio : Marantz 8802A | Genelec 8050 LCR | Monitor Audio IDC Sides & Rears | Seaton Submersive Master/Slave |
Control : Control 4 |
AidenL is online now
Old 08-01-2014, 11:58 AM
Quoted: 266 Post(s)
Liked: 148
14ft is quite some distance! 89 is about par. Presumably 8 ohm speakers?
105 dB is per channel by the way. Each channel needs to hit that peak for true reference level.
You do need more power than the average person due to the distances involved. One calculator says 700+ watts to hit 105 dB peaks, but that calc assumes there's no room effects offsetting distance sound loss effects. Another says 75 watts can manage close to 100 dB with speakers close to the wall.
If you do music listening and are trying to hit high SPL levels, you might want more than 75 watts in my experience. By high I mean pushing or exceeding 100 dB SPL. Which is too loud for hearing health, but that doesn't stop anyone
http://myhometheater.homestead.com/splcalculator.html
AidenL likes this.
Old 08-01-2014, 01:34 PM
AidenL's Avatar
Quoted: 471 Post(s)
Liked: 218
Yep, Kef R700s at 89dB and 8 ohms - exactly right.
I didn't think 14 ft was that far away, I mainly watch movies from that distance, music would be secondary.
My Anthem outputs 100 wpc with 2 channels driven, and 75 wpc with 5 driven. Would that change your thinking?
Can I ask, if you were me, what kind of power outputs would you be trying to gain?
