Are Separates Worth It? - Page 6 - AVS Forum | Home Theater Discussions And Reviews
 137Likes
Old 07-18-2014, 10:55 AM
Ricoflashback's Avatar
Quoted: 649 Post(s)
Liked: 349
Originally Posted by joehonest View Post
Their really is no need I've proved it to my self many times, its really not that hard to prove. Just compare a AB to D class amps which I did many times in my home. I'm happy to report I heard the changes to my hard to drive magnepan tympani speakers. This is in just simple stereo, so it was very easy to judge, no blind fold was needed!
I have heard the debate about Class AB versus Class D Amps. I've also heard the debate about tube versus solid state. Since I was used to a Class D amp with my Pioneer SC65 - - it was easy for me to move to the Class D Wyred 4 Sound MMC 7.1 (with the observations in my earlier post.) Could an AB amp sound better on my system? Maybe, but the smaller footprint (fits into my rack) and the lower energy cost/watts made it an easy decision for me.
But for the scientific community on this thread - - the bias test, measurements, etc. - - they would say:
  1. There is no audible difference between solid state and tube amps
  2. There is no audible difference between an AVR or using separates - no need for separates
  3. There is no audible difference between a CD and a High Res file
  4. There is no audible difference between Bluray players
  5. There is no difference between hamburger and filet mignon - it's all beef.
Home Theater Setup
Samsung UN65ES8000 LCD/LED & BenQ W1080ST & Vizio M43C1
Pioneer SC65 (Pre-Amp) & Emotive XPA-3, 200 WPC
OPPO 103, Comcast Infinity X1, Darbee Darblet
ALL Paradigm - 7.1 - Studio 60's, V.2 (FL/FR) CC-690, V.5 (C)
ADP 590 V.5 (SS), MilleniaOne 2.0 (BS) - Velodyne 810 Sub
Ricoflashback is offline
Old 07-18-2014, 11:07 AM
joehonest's Avatar
Quoted: 90 Post(s)
Liked: 37
Originally Posted by g_bartman View Post
Okay, those blue meters sure are pretty.
Yes They are
For me the "system" is the amp / speaker combo, better amps handle changing speaker impedance loads of less than 4 ohms, that is the key factor, there other factors too.
joehonest is offline
Old 07-18-2014, 11:13 AM
joehonest's Avatar
Quoted: 90 Post(s)
Liked: 37
Some people will believe anything until they try it out for them selfs
turnne1 likes this.
Old 07-18-2014, 11:16 AM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 148
There can be audible differences between amps. You mention tube amps. There's been some tube amps that measured 10% THD. I would expect them to have a coloration. They don't have massive distortion because they are a tube amp, it's due to their specific design, but I don't know of any solid state amps like that.
There should be no audible difference between blu-ray players sending audio over HDMI. I suspect jitter doesn't matter for HDMI due to the fact all the packets have to be buffered. It's not worth considering IMO. If you connect it with analog cables, I suppose the DAC could have an effect. It doesn't seem like it should, but there's always a possibility.
I would not go as far to say there's no audible difference between amps. But due to a number of blind listening tests over the years, surely it's less, as a general statement than people claim.
"But this one goes up to 11"
MichaelJHuman is offline
Old 07-18-2014, 11:31 AM
joehonest's Avatar
Quoted: 90 Post(s)
Liked: 37
Coloration isn't a bad thing if you like what you hear, clipping thats BAD. All speakers and rooms add some coloration.
Old 07-18-2014, 11:56 AM
Quoted: 266 Post(s)
Liked: 148
This is an article which discusses factors which could cause amplifiers to sound different from a engineer perspective. I can't say I learned much from it, but it's better than guesswork
Overload recovery is something rarely discussed here. Possibly because no review I have seen tests it. It is interesting to note that if an amp does clip, they may not sound the same. It's unfortunate that receivers are not equipped with a clipping detection and warning system.
http://sound.westhost.com/amp-sound.htm
Old 07-18-2014, 12:28 PM
SimpleTheater's Avatar
Quoted: 202 Post(s)
Liked: 94
I heard a difference. Not from the sound output, but the player itself. My neighbor just bought a WalMart special $59 BluRay player and he forgot to buy an HDMI cable. I brought over an extra one and we hooked it up. Then I heard this high pitched whining noise and, you guessed it, when that player began spinning the disc it was loud! Maybe he could have hid the player in a closet, but his setup was all below the flat screen TV. For some crazy reason he still has it. I guess some people just don't care.
Why is there NO perfect equipment, only compromises?
SimpleTheater is offline
Old 07-18-2014, 12:34 PM
turnne1's Avatar
Quoted: 1755 Post(s)
Liked: 410
Something I have noticed here. There's actually two discussions, and it's not always clear which is which
1) Does a preprocessor have audio quality and/or audio fidelity benefits over a receiver used as a pre proc? This is a bit murky as there's a wide price range from Emo to 20k processors. I think the question might be whether having an amp section interferes with the non power amp circuitry?
2) Does having an external amplifier vs. using a receiver's amp section have a benefit? Again there's a bunch of factors such as the fact that the amp is in a different box, or the amp may have more power, or the amp may perform better into lower impedance loads to name some
Realizing this, the discussion is a bit ambiguous. I figure for (1,) people will spend based on their budget. Not everyone can afford expensive processors. Some will shy away from Emo processors, and embrace using an AVR with pre outs as a processor due to their excellent feature vs. price. Whether they have compromised sound due to their budget is a question of sorts. Some just want to know if they should save money they have available by not buying a more expensive dedicated processor. I feel it's fair to suggest they CAN save money. This due to many years of reading up on this topic and coming to this conclusion. I feel a receiver can do the job with at worst a slight loss of fidelity.
The second discussion is more common, and it asks whether buying an external amp can have benefits over AVR amplifiers. Obviously it has a chance to make an effect. As I mentioned before, for $1000 or less on sale, the Outlaw 7125 has a massive transformer you don't see even in high end AVRs. It has 20,000 uf of capacitance which might be better than most AVRs. In general, it's a very well built piece of equipment, and performs excellently into 4 ohms. Not all AVRs do well into lower impedance loads due to a weak power supply or limiting circuitry. So people will say, if you can afford more power, go for it. As for fidelity, it's hard to discuss amplifier fidelity as numerous blind tests have shown amplifiers tend to sound very similar. If you say you can hear the difference, than by all means act on that. But please understand why other people say what they do - there's plenty of evidence only power seems likely to make a difference based on a lot of evidence.
1. The same question would apply to AVR's....since there is a wide price range among brands
some would argue that a $2K receiver sounds no better than their $1K of the same brand
clearly...the lower end you go the better value it represents
also..in regard to pre/pro
do you mean the Asian modeals...Yamaha CX-a5000..Marantz 8801....Onkyo 5509...or do you mean reference pieces like the Anthem statement D2V
There is a big difference in money if you go to the non asian brands
2. generally...I would yes and that has been my experience
Although it depends on the AVR and amp in questions
Warren
Rm 1 Samsung 64F8500 Marantz 8801 prepro Sherbourn 5/1500A amp B&W CM10s..CM2 center...CM5's.rears
Rm 2 Hisense H50C Yamaha A2050 Celestion 305 speaker system
Rm 3 Panasonic 50ST50 Denon4520 Kef 2005.2 speaker system
Rm 4 Samsung 51E8000 Sony DA5400ES Mirage Omni sat speaker system
turnne1 is offline
Old 07-18-2014, 12:44 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Another battle of witts(sic) between the haves and have nots.
True in the sense that it is self evident that this is discussion between those who have technical expertise and those who do not. Look at the nature of the discussions. Who is citing facts, figures, and reliable tests? Who is making unsupported claims. Who is making ad hominem attacks such as is indicted by a face value interpretation of the statement above?
Any idea that personal wealth is a strong influence in these discussions presumes knowledge that the writer above can't possibly have.
If you got the money, buy the best, you earned it.
Life is not that simple. While I am not personally wealthy, I was raised and live in an affluent community whose very name is commonly used as a status symbol. I have friends and acquaintances who are centa and deca millionaires.
In this particular community there far, far more expensive yachts than there are expensive A/V systems. In the lives of my friends and neighbors, if they have the money do to so, they first buy the finest homes and boats.
If your(sic) piss poor, keep telling yourself it all sounds the same.. One day (hopefully) your luck will change and so will your hearing, funny, rich people senses, seeing, hearing, feel and taste, are highly tuned and they got the checkbook to back it up, talk is cheap..
Nobody needs to be wealthy or spend the big bucks in order to have as many opportunities as they need to listen to expensive audio systems. That's why there are high end audio salons, that is why there are high end audio shows.
Compared to an expensive home, automobile, or boat, an expensive audio system costs chump change. I don't think how aware you are of how your opviously poor writing skills suggests cost cutting in the area of education, another area of major expense in my community.
arnyk is offline
Old 07-18-2014, 12:47 PM
FMW
FMW's Avatar
Quoted: 1652 Post(s)
Liked: 1681
I honestly believe nobody is going to post the end all to this, which has not been done, but tried countless times.. If your looking for something and found what you want, than you are happier than most. I feel sorry for the ones who believe and can't handle the fact that some hardware is just better, and most of time costs a hell of a lot more. For those who have capped and limited their mind by not wanting to believe there is better, or/and not willing to work for it, well good luck..
It is a matter of belief vs. test results. You believe whatever you like. I'll stick with the test results. I think there is sometimes a sonic improvement that can be had by spending more on speakers. Not always. I've heard very expensive speakers that sounded horrible to me. In the area of electronics, my test results say spending more money just spends more money. If it soothes the ego or the eye for fashion then that is a positive outcome. It becomes a matter of putting a value on those things.
I, for one, have been a high end audiophile. I've had systems that cost more than my first house. I understand the allure of it. But test results don't lie and they do tend to obviate the beliefs. That's why I'm a former audiophile.
FMW is offline
Old 07-18-2014, 12:53 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Originally Posted by charmerci View Post
What I would have liked to have seen from this study is to have listener A and listener E take a break and then do 10 more tests. (A had 8 of his last 10 correct and listener E got his last 5 correct.)
What I'd like to try is to have a DB test with my system compared to a level matched cheap system. It seems to me that a person who is familiar with the nuances of their particular system would have a better opportunity to pick out differences.
Your problem is obviously a lack of financial resources. Since this thread has turned into class warfare, should I point out that if you were sufficiently well-educated, wealthy or influential you could have had the opportunity to have experience all of the things you have mentioned?
I am not wealthy but I've easily done as many DBTs as my late friend Tom Nousiane, and I've had the opportunity to examine all of those things that you mention. This situation is not marginal. All good amplifiers and CD players measure well enough and when compared are either indistinguishable or have differences so small that they are not strong influences on over all system sound quality.
Look at the world around you! People who are interested in the best possible sound quality are putting the majority of their investment into excellent speaker systems and acoustically treated listening rooms.
marquee-moon likes this.
arnyk is offline
FMW
FMW's Avatar
Liked: 1681
Well said, Arny. It is hard for some people to understand that some people don't spend all the money they can on certain things. The arrogance gets in the way, apparently.
FMW is offline
Old 07-18-2014, 12:54 PM
briansxx's Avatar
Quoted: 96 Post(s)
Liked: 71
If I could hear for myself that it is sonically no better than a $300.00 receiver, I'd sell it tomorrow. Regretfully though, those blue meters sure are pretty.
Did a blind test (set up by a knowledgeable friend with the expertise and equipment) of my NAD separates vs an inexpensive Class D amp. At the levels at which I listen (important emphasis), I could detect no differences, even after extended listening. The NAD components are now in my closet. If you embrace the science, you've gotta live it, too. :-)
Best,
Brian
SimpleTheater and dmarqueset like this.
briansxx is offline
Wahoo_envy's Avatar
Quoted: 30 Post(s)
For me, separates have been worth it. Over ten years ago, I purchased two used American made amplifiers for just under $900--Adcom GFA-555II(1995) and Cinepro 2K5 (1999). I just recently purchased a B stock Emotiva pre/pro and have all the new features I need with my old Outlaw pre/pro delegated for back up, if needed. I made the decision to keep my amps when I learned most of today's $1K receivers are made in China. I still have three receivers in use at my house--Denon AVR-2500(~1994), Yamaha AVR-2500(~2005), and Marantz SR6005(2011). As far as SQ goes?? No comment, my best equipment is in the HT with the separates; however, I would like to hear some JTRs, Lepai T amp, and a smartphone source one day.
Wahoo_envy is offline
Old 07-18-2014, 12:56 PM
FMW
FMW's Avatar
Liked: 1681
That's the only way its going to work at this level, with the good stuff. Its not as easy as picking black or white, you got to know that your looking for so when you find it you just don't pass it by..
It would be fun to watch your face during a bias controlled listening test. I've seen the look before.
SimpleTheater likes this.
FMW is offline
Old 07-18-2014, 12:58 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
clearly...the lower end you go the better value it represents.
Exactly, only you shift the price range down by half and still reach the same conclusion.
And one must ask why, as I can show you pictures of much non-asian brand equipment that says that it was made in asia. Since asian parts producers dominate component manufacturing (resistors, capacitors, semiconductors, transformers, chassis, etc.) even if the piece of audio gear was built in the UK, US or Canada, it was largely manufactured in asia.
arnyk is offline
Old 07-18-2014, 01:03 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
You might do well to speak only for yourself. It is actually quite presumptive to stuff words into the mouths of people that you seem to disrespect.
All of the things you mention may sound different depending on the operational circumstances and the choice of alternatives.
Or not.
arnyk is offline
Old 07-18-2014, 01:08 PM
turnne1's Avatar
Liked: 410
agreed....nothing above the most average product represents a the best value
Walmart corporation has proven that in droves
When I said Asian..I meant where the company was based
OTOH......high end Non-asian brands are not built in Malaysia ......like the majority of the Asians brands production takes place
I dont see a Made in Asia label on the back of Anthem or McIntosh products...for example
Warren
turnne1 is offline
Old 07-18-2014, 01:34 PM
phantom52's Avatar
Quoted: 27 Post(s)
Liked: 84
Right there on the back. Anthem MRX710 made in China.
http://www.anthemav.com/products-cur...0/page=gallery
phantom52 is offline
Old 07-18-2014, 01:41 PM
Quoted: 202 Post(s)
Liked: 94
Warren
Take a look at the new Anthem recievers. made in China.
Old 07-18-2014, 01:48 PM
turnne1's Avatar
Liked: 410
and you pic the low end unit?
I guess I was considering products like the D2V and P5
http://www.anthemav.com/products-cur...d/page=gallery
which is why I would buy products like this in the first place
but...my comment was really intended to spurn discussion about where they were made but rather where the company was based
My own separates...Onkyo 5508 and Sherbourn 5/1500A were made in China
so the majority of their products are make in China?...I was talking their separates...not receivers
I will tell you the d2V..P5 and the other pieces are not
I reference that because this thread was about differences in separates and receivers
Warren
turnne1 is offline
Old 07-18-2014, 01:53 PM
phantom52's Avatar
Quoted: 27 Post(s)
Liked: 84
Warren
The MRX 710 is their top of the line AVR. IF you read the whole thread it really doesn't matter if it's separates or an AVR by many opinions here.
Old 07-18-2014, 01:58 PM
turnne1's Avatar
Liked: 410
I guess I am of the opinion
1. Separates offer higher performance than an AVR...and have stated that earlier
whether or not one will utilize that performance difference is another question
2. IMO...if you are looking at products like Anthem,Krell, mcIntosh etc you are probably not seriously considering an AVR
If you expect that MX710 to peform anywhere near Statement D2V pre-pro/P5 amp combo you are seriously kidding yourself
I can tell you there is a BIG difference in that combo and my Onkyo 5508 and Sherbourn 5/1500A
and btw...I have an Onkyo 5009 AVR, Pioneer SC37 currently...and have had Yamaha A3000...Pnkyo 905 and few others in the past
My separates will outperform any AVR I have owned...the Anthem set will outperform the separates I have
Warren
turnne1 is offline
Old 07-18-2014, 02:02 PM
joehonest's Avatar
Quoted: 90 Post(s)
Liked: 37
It sounds like you guys shorted the market today
Ricoflashback likes this.
Old 07-18-2014, 02:10 PM
Quoted: 266 Post(s)
Liked: 148
Never understood why there's the automatic assumption that stuff built in China is inferior. If I owned an audio company, I would have my own QA to ensure the product was built to the engineering specs. If it was, and the components are of the proper quality, where's the concern?
I would assume the components are almost all Asian made anyway. Resistors, caps, transformers even ASICs. I suppose a US company could try to source as much parts as possible from the US and then build it. But my betting money is on most of the components being from Asia.
Old 07-18-2014, 02:15 PM
MUDCAT45's Avatar
Quoted: 346 Post(s)
Liked: 280
Warren
How did you make the comparison between the D2V/P5 and your Onkyo/Sherbourn?
MUDCAT45 is offline
joehonest's Avatar
Quoted: 90 Post(s)
Liked: 37
Did you mean obviously ?
Old 07-18-2014, 02:17 PM
Quoted: 649 Post(s)
Liked: 349
Or not.
RFB Response: Arny - I haven't disrespected anyone. That's not my point. Did you disagree with any of my 1-4 statements? (Statement 5. was an attempt at humor...)
I'll bet you bottom dollar that you are in agreement with 1 - 4 because I've read your posts. And I read them because I do value the "science" and your background. I completely agree with Statement 3. about High Res files from comparison - - listening to some samples and my old CD's. And, after "Bi-Wiring" with my Pioneer SC65, I determined that it really didn't make any difference and you were right (I tested both ways - - not scientifically, but enough to sh$t can the extra wires.)
It seems the scientific side of this discussion is very binary - - separates are of no value, no audible difference. It's black or white - - period. I can flat tell you that I'm listening at lower levels and it sounds clearer to me with the separate amplifier versus my Pioneer SC65 alone. I can see it on the volume settings. I guess that isn't science but it is a measurable difference.
Multichannel SACD's have more separation - - especially 5.1 with the separate amp.
So in closing, if someone was looking for advice on separates - - the scientific message would be that they do not make a difference and if you think they do, you are wrong. Buy the cheapest AVR you can with 50 to 90 wpc and you're good to go. Buy any Bluray you can because digital is digital. Forget about the "tube sound" because it's just your imagination. Science proves otherwise. I'm not in that camp.
Home Theater Setup
Old 07-18-2014, 02:29 PM
FMW
FMW's Avatar
Liked: 1681
Or not.
To get us to agree with your first 4 statements would require some modifiers. Let me improve them for you.
1. Most tube amplifiers sound audibly different from most solid state amplifiers although there are a few that have been found to be audibly the same as most solid state amplifiers. So I disagree with that statement entirely.
2. There is no audible difference between the amplifiers in an AVR and those in a high fidelity solid state outboard amp as long as they are operating within their design parameters. There are reasons other than sound quality to use an outboard. amp.
3. There is no difference between a CD and a high res file as long as they are two channel and are based on the same master. Most high res files, however, are remastered for the purpose so they do sound different.
4. There is no audible difference between Blu-ray players. I accept that comment as you wrote it. Modern DA converters do their job without any audible influence that I've ever encountered in a bias controlled listening test.
FMW is offline
Old 07-18-2014, 02:41 PM
turnne1's Avatar
Liked: 410
through extensive demo/listening here...
http://www.genesisaudio.com/
years ago....with the Integra clone of my Onkyo preamp
Warren
turnne1 is offline
