Newbie need help on selecting the right amp for my totem tribe III - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 07-17-2014, 03:11 PM - Thread Starter
mdrx7's Avatar
Hi fellow forum member. I've been a long time reader and now just starting to build my own HT. I purchases 3 Totem Tribe III for front L/R/C and now I am looking to purchase the correct amp to power these guys. I've read some conflicting answer to what amount of power is needed to power these. Some article says to use the exact amount recommended, where other says you should go 150% on the amp for the speakers. As you can see, I am a newbie to all this. So any recommendation to which amp will be greatly appreciate. I've included a link for the specs on the totem.. Thanks.
http://totemacoustic.com/en/hi-fi/on...n-wall-on-wall
mdrx7 is offline
post #2 of 8 Old 07-17-2014, 03:44 PM
BillP's Avatar
Quoted: 258 Post(s)
Liked: 201
They are 4 ohm speakers, so you need an amp that is rated for 4 ohms. You don't give a price range. Parasound amps are well thought of here.
BillP is offline
post #3 of 8 Old 07-17-2014, 06:36 PM - Thread Starter
mdrx7's Avatar
Thanks for your input. Budget wise I would like to stay under 1k if possible but can stretch to 1.5k if need to be. Thanks
mdrx7 is offline
post #4 of 8 Old 07-18-2014, 05:36 AM
Quoted: 73 Post(s)
Liked: 112
Check out Emotiva and Outlaw.
rnatalli is offline
post #5 of 8 Old 07-18-2014, 06:20 AM
jrhooper1963's Avatar
Quoted: 55 Post(s)
Liked: 36
I would look on Audiogon for a used Parasound. Indeed, you do need a 4 ohm capable amp. I would stay away from Emotiva. I bought an amp from them a few years back. It sounded OK at moderate volumes. But the louder you turned it up, the more harsh and fatiguing it sounded. I have a Parasound Halo A 52 in my system now. It's only 125 watts x5. But, it is a high current amp, that is definitely 4 ohm capable, and rated at 225 watts at 4 ohms. Unlike the Emotiva, it never runs out of steam. Unfortunately the A 52 is a discontinued model.
I am giving high consideration to adding the Totem Tribe Threes, to my front three in my system. I would appreciate any feedback you have about these speakers.
jrhooper1963 is offline
post #6 of 8 Old 07-18-2014, 07:45 AM - Thread Starter
mdrx7's Avatar
Thanks for all the feedback..
mdrx7 is offline
post #7 of 8 Old 07-18-2014, 07:54 AM - Thread Starter
mdrx7's Avatar
I've looked at outlaw. My question is how much power should the amp be? I know the speaker says 200w, but through reading different articles, some says your amp should power 50% more then what the speaker can handle so the power is not distorted. I want to make sure I get the right one so I don't ruin these speakers. Thanks.
mdrx7 is offline
post #8 of 8 Old 07-18-2014, 08:08 AM
Quoted: 55 Post(s)
Liked: 36
You want to be sure the amp is four ohm capable. Also, the Tribe Threes have much more bass than your typical 4 inch woofer. The torrent woofer is hand made. There is over 10 hours labor in one woofer! I called Totem and inquired about these speakers. They informed me that one replacement woofer is over $750, should you ever need to replace one, and it is not covered by warranty. Example being abuse, or not buying from an authorized dealer.
On a good note, they also said that these Torrent woofers are virtually bulletproof ! But as we all know, anything has it's limits.
