Yamaha rx-v2095 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-17-2014, 08:27 PM - Thread Starter
Liked: 0
Yamaha rx-v2095
My friend gave me a old yamaha receiver, model is RX-V2095. im connecting it with 2 rca cables and at the end it has a female type plug where i plug in my 3.5mm aux cord to my phone. i got it to work but it sounds really bad because the sound effect is on. I turn it off and then my speakers stop working??? i really don't know whats going on, is it the rca cable im using? should i be using just a straight rca cable 3.5mm splitter? Any help is appreciated. I attached my rca cable im using and what my current receiver settings are on.
ID:	167353   Click image for larger version
ID:	167361   Click image for larger version
nty69 is offline
post #2 of 4 Old 07-17-2014, 09:26 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
Where are the speakers connected? You failed to show that part. I notice there's a Main A and B plus Front Effects Speaker terminals. You should be using Main A. My guess is you have the speakers connected incorrectly.
Most of those DSP's are useless. Set the mode to stereo
Set the Zone 2/Rec Out to Source/Remote
Use the big knob to select the CD input
Afro GT
afrogt is online now
post #3 of 4 Old 07-17-2014, 09:50 PM - Thread Starter
Liked: 0
Thanks for your response, i could not find where to set it to stereo, but everything else was set on the receiver as you stated.
i uploaded a picture where the speakers are connected, (only have one connected at the moment because i wouldn't want to waste time on trying something that would not work). I also uploaded a picture of the (Effect off) that time talking about, when its pressed the speakers just don't connect anymore.
ID:	167569   Click image for larger version
nty69 is offline
post #4 of 4 Old 07-17-2014, 10:08 PM - Thread Starter
Liked: 0
ok so i changed the connection from front to center and it sounds a lot better but once again when i turn the effect off it does not work, i also changed the input from cd to phono, sounds a little better to but, when other speakers are connected to those other terminals it sounds like crap for those speakers. Not to smart in these types of systems but maybe is it the impedance of the speaker?
nty69 is offline
