Tube amp cracking noise - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 07-18-2014, 06:36 AM - Thread Starter
Liked: 0
Hello everyone,
I'm new here, and don't have a lot of experience with tube amplifiers.
I own a Yarland FV34C tube amp and have a problem with this one.
From time to time it makes an annoying cracking sound, this noise also happens when the volume is completely zero.
It also doesn't matter whether I select the aux, CD or line input.
http://picosong.com/PMJz/
Does anyone have an idea what this can be? If more information is needed, please let me know.
Regards
FlosD is offline
post #2 of 8 Old 07-18-2014, 07:14 AM
DonH50's Avatar
Quoted: 1797 Post(s)
Liked: 1333
Could be any number of things. Bad tube, bad coupling capacitor, noisy rail, etc. Have you contacted Yarland?
Does it appear on both channels? If so, for starters I would swap driver and output tubes between channels since it is independent of the volume and input selector controls (indicating the problem is after those controls). See if it switches channels when you swap tubes around. The catch is that pre-driver and driver stages probably use the same tube for both channels. If you have spare tubes, swap then in and see if the problem goes away. Most tube amp problems are caused by the tubes...
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #3 of 8 Old 07-18-2014, 07:27 AM - Thread Starter
Liked: 0
I mailed them today, will have to wait a while for them to responce (no dealer around here, not anymore...).
It appears on one channel, I'll try to swap them and see if that's the problem.
Thanks for your reply
FlosD is offline
post #4 of 8 Old 07-18-2014, 07:41 AM
DonH50's Avatar
Liked: 1333
NP. I meant to say "If not, for starters..." -- if it is on only one channel, swap the driver tubes and see if the problems follows the tube. Or just replace them. Same with output tubes, but they may be matched pairs (swap them as a set) and you may have to re-bias the amp when you swap the outputs. Chances are it is just a bad tube.
DonH50 is offline
post #5 of 8 Old 07-18-2014, 08:08 AM - Thread Starter
Liked: 0
It seems like the problem follows the (output) tubes .
Thanks for your help!
FlosD is offline
post #6 of 8 Old 07-18-2014, 08:10 AM
DonH50's Avatar
Liked: 1333
Good, now you know what to replace! Replace them as a set; they may (probably do) need to be matched (check your manual). Lots of places sell tubes.
DonH50 is offline
post #7 of 8 Old 07-18-2014, 01:59 PM - Thread Starter
Liked: 0
The manual doesn't say they need to be matched but it do say "bias Voltage State: Self-bias".
Does this mean they don't need to be matched?
Regards
FlosD is offline
post #8 of 8 Old 07-18-2014, 03:46 PM
DonH50's Avatar
Liked: 1333
Probably not.
DonH50 is offline
