AVR & Amp Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-18-2014, 07:33 PM - Thread Starter
maul528's Avatar
AVR & Amp Question
I have an AVR with Pre outs & an Adcom 7605 5 channel amp. Is it possible to run 2 channels of the Adcom to each front speaker using the Pre outs on the AVR?
I'm trying to double the wattage going to my fronts and still have another channel for the center speaker, letting the AVR amps take care of the surround speakers.
Is this a good idea?
AVR- Yamaha RX-V871
Amp- Adcom GFA 7605 5 Channel
Front Speakers- Infinity IL40
maul528 is offline
post #2 of 3 Old 07-18-2014, 07:53 PM
JHAz's Avatar
Quoted: 305 Post(s)
Liked: 271
If your speakers are biampable it is possible but pointless. If tgey aren't you could just plug ghe two channels directly into each other and wait for the smoke,
Double power is 3dB or about one notch louder. Not likely a big deal. With typucal crosdovers in the 2 KHz range the tweeter only gets ten or twenty percent of total power so you cannot really achieve double power anyway. More lika a 1 dB (barely noticeable) gain.
If you must try it no biggie. Y cable.
JHAz is offline
post #3 of 3 Old 07-18-2014, 09:42 PM - Thread Starter
maul528's Avatar
Thanks JHaz.
They are biampable but like you said, probably not worth it. I think I'll leave things as they are with the Adcom powering the 5 speakers in my 5.1 set up connected to my AVR.
maul528 is offline
