Marantz 8002 & 7005 HD audio help! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 07-20-2014, 02:04 PM - Thread Starter
gene c353's Avatar
Quoted: 139 Post(s)
Liked: 99
I have these two receivers, the 8002 paired with the 8002 BR player and the 7005 with a 7006 BR player. I can't get either receiver to display TrueHD or Master Audio in the display window. They both say "Multi-Ch" and their PCM symbols are lit up as though the BR players are set to output PCM, which they aren't. The 7006 is set to "Auto" and the 8002 is set to HDMI Normal.
I have a ton of experience with this stuff but I'm pulling my hair out. What in the %$@& am I missing???
As always, thanks a ton.
Gene
gene c353 is offline
post #2 of 9 Old 07-20-2014, 02:07 PM
jdsmoothie's Avatar
Quoted: 12126 Post(s)
Liked: 5522
Set the BD Audio Mode (8002: p. 23 Owner's manual/UD7006: p. 7 Owner's manual) to "HD Audio Output"
jdsmoothie is online now
post #3 of 9 Old 07-20-2014, 03:13 PM - Thread Starter
gene c353's Avatar
Quoted: 139 Post(s)
Liked: 99
I have the 8002's currently connected and it was/is set to "HD Audio Output". any other idea's?. I don't have much hair left.
post #4 of 9 Old 07-20-2014, 03:38 PM
jdsmoothie's Avatar
Liked: 5522
Are you using an HDMI cable for audio? Is the HD audio track on the Blu Ray DVD selected?
post #5 of 9 Old 07-20-2014, 04:06 PM - Thread Starter
gene c353's Avatar
Quoted: 139 Post(s)
Liked: 99
Yes and yes. Should have mentioned that straight-off.
post #6 of 9 Old 07-20-2014, 04:38 PM
jdsmoothie's Avatar
Liked: 5522
Is the firmware on all devices current? Try cycling the BD Audio mode to "Mix Audio Output" to see if there is any change. Then cycle back.
post #7 of 9 Old 07-20-2014, 05:47 PM - Thread Starter
gene c353's Avatar
Quoted: 139 Post(s)
Liked: 99
The disc I was using said "5.1 Uncompressed" in it's menu but not TrueHD or DTS-MA (I think this is the little silly/stupid thing I was looking for). Maybe they didn't want to pay the licensing fee? Anyway, I put a different disc (DTS-MA) in the 8002 setup and while Multi was still on the display the PCM was gone and Digital was lit as well as a small DTS logo. Funny thing, when I switched the audio on-the-fly from LPCM to DTS-MA with the BR's remote the full DTS-Master Audio would appear on the receivers display, but just for a second. I'll swap out the 8002's for the 7005's later and see what happens. I do need to check the firmware, just so I know where I'm at with it. I'm still not 100% positive I'm getting HD audio but at least the PCM has disappeared. I was perfectly happy with LPCM as both BR players have excellent audio sections.
All this is because I want to sell both setups and as you know, everyone wants to see DTS Master Audio on the receivers display or they'll probably walk away from it.
Thanks for the help.
post #8 of 9 Old 07-20-2014, 06:53 PM - Thread Starter
gene c353's Avatar
Quoted: 139 Post(s)
Liked: 99
O.K. JD. You had it right, at least on the 7005 system . The BR player was set to "Mix" and not "HD Audio". That setting is on the main Audio menu on the 8002 but you have to dig a little deeper to find it on the 7006.
I still need to do some more work on the 8002. I still think somethings wrong there.
Thanks again.
Gene
post #9 of 9 Old 07-20-2014, 08:39 PM
jdsmoothie's Avatar
Liked: 5522
Keep in mind that DD and DTS are "compressed" audio tracks that get uncompressed to PCM prior to being played. So if the audio on the disc is already "uncompressed" (ie. PCM), then all you'll see on the AVR is "Mult CH IN"; however, it will still be the same quality as if the AVR had uncompressed it. So bottom line is to make sure you use a disc with either a DD or DTS audio track if you want to see that on the AVR's front panel.
