Is it worth spending money on higher end banana plugs? - AVS Forum | Home Theater Discussions And Reviews
 5Likes
  • 2 Post By phantom52
  • 2 Post By KidHorn
  • 1 Post By MichaelJHuman
post #1 of 19 Old 07-23-2014, 12:07 PM - Thread Starter
maigre's Avatar
Quoted: 12 Post(s)
Banana plugs are available for $30 a dozen or $30 apiece. And beyond. Does it matter? Is it worth spending $10 per connector for a home theater system that's has an avr and three speakers worth a total of $1500?
maigre is offline
post #2 of 19 Old 07-23-2014, 12:28 PM
phantom52's Avatar
Quoted: 229 Post(s)
Liked: 236
No it is not. Banana plugs from Monoprice,Sewell Direct, or Bluejeans Cable will work just fine. Anything else is snake oil IMO.
M.T.Nest and 67jason like this.
phantom52 is offline
post #3 of 19 Old 07-23-2014, 12:45 PM
KidHorn's Avatar
Quoted: 1465 Post(s)
Liked: 963
They'll produce the same sound. The difference is in how easy they are to get the wire attached and how sturdy they are. I always buy the $30/dozen kind.
jdcrox and Edllguy like this.
KidHorn is offline
post #4 of 19 Old 07-23-2014, 02:08 PM
afrogt's Avatar
Quoted: 1357 Post(s)
Liked: 940
these are all you need.
http://sewelldirect.com/Sewell-Deadb...gs-12-Pair.asp
They have other styles on the same page.
Afro GT
afrogt is offline
post #5 of 19 Old 07-23-2014, 02:41 PM
audio4life's Avatar
Liked: 300
Plugs with brass content seem to be frowned upon. Personally, I use the wire itself to terminate the speakers on my high end system. YMMV
audio4life is offline
post #6 of 19 Old 07-23-2014, 02:45 PM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 151
Cheapo ones may not fit as well and may be harder to work with/wire up. No sonic difference is expected
Edllguy likes this.
"But this one goes up to 11"
MichaelJHuman is offline
post #7 of 19 Old 07-23-2014, 03:26 PM
Archaea's Avatar
Quoted: 3072 Post(s)
Liked: 2686
no
Archaea is offline
post #8 of 19 Old 07-23-2014, 05:09 PM - Thread Starter
maigre's Avatar
Quoted: 12 Post(s)
maigre is offline
post #9 of 19 Old 07-25-2014, 11:05 AM
Lttrader's Avatar
Quoted: 13 Post(s)
Liked: 27
This may be a repeat, but I highly recommend the banana plugs in the link below. They are reasonably priced, easy to connect to your wiring, connect solidly to the wiring, and make connecting your speaker cables to the AVR or amp a piece of cake. Great investment IMO.
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
Lttrader is offline
post #10 of 19 Old 07-25-2014, 12:40 PM
89grand's Avatar
Quoted: 289 Post(s)
Liked: 163
With in reason, I'd actually say yes, it does matter, but let me clarify, not in sound quality, but I've used some cheap banana jacks that fit way too loose, and I'd have to spread out the strips on the banana jack with something like a knife to get a good contact, whereas the ones I use now from Sewell Direct fit much better even after being unplugged and plugged in numerous times. That's something the real cheapies would not do.
89grand is offline
post #11 of 19 Old 07-25-2014, 12:46 PM
Quoted: 59 Post(s)
Liked: 6
I just grabbed a set of these; http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
A little cheaper than the ones above but will serve as 2 type of connectors in one. Just do not buy the ones from Home Depot.....those will drive you nuts. As for any of the accessories available there is the esoteric cables that run $100 per foot down to the cheapest wires that can be had for 10 cents a foot...........somewhere in between lies what you want or need. I have tried expensive cables and wires and never heard much difference. The important factor to remember when buying cables and wires is to go thicker and better quality as the run gets longer....other than that use your own judgement and save your cash for better electronics or speakers.
audio.hobby is offline
post #12 of 19 Old 07-25-2014, 02:44 PM
audio4life's Avatar
Liked: 300
Your experience reminds me. I had a bulk purchase of the Monoprice plugs, and after a year they started giving me problems. They started fitting loosely, and the strips on the banana jack was starting to collapse. I only noticed it because on one set of speakers, a rattling vibration started occurring on bass notes. It freaked me out, I thought the speakers were blown or something. But upon inspection, it was these plugs getting loose in the socket. After inspecting the rest of them connecting the theater system and finding more loose fitting plugs, I discarded them all and bought the Sewell brand from Amazon. Monoprice is the price beater, but I've had their HDMI cables fail as well.
post #13 of 19 Old 07-25-2014, 02:50 PM
MUDCAT45's Avatar
Quoted: 389 Post(s)
Liked: 289
You must have weak bass if that rattle could be heard over the bass.
MUDCAT45 is online now
post #14 of 19 Old 07-25-2014, 03:09 PM
N8DOGG's Avatar
Quoted: 1103 Post(s)
Liked: 1200
I was thinking the same thing when I read it too. I personally use all Nakamichi plugs but only because I like the 2 screw connection.
N8DOGG is offline
post #15 of 19 Old 07-25-2014, 03:20 PM
BuddTX's Avatar
Quoted: 109 Post(s)
Liked: 82
I just recently got rid of all my Banana Plugs, I like direct speaker wire connections better.
But when I did use Banana Plugs, I liked the ones from Orange County Speaker.
BuddTX is offline
post #16 of 19 Old 07-25-2014, 04:01 PM
audio4life's Avatar
Liked: 300
So, how loud was the rattle? And what was the volume set at? Two things that would determine whether one could hear a rattle or not.
post #17 of 19 Old 07-25-2014, 04:12 PM
Bill Mac's Avatar
Quoted: 1518 Post(s)
Liked: 1754
I never really cared for the type of banana plugs that you had to "fan" out the strands of speaker wire. I recently ordered GLS locking banana plugs from Amazon. The reseller is Orange County Speaker and the prices are a bit less to a similar plug sold by Bluejeans Cable. The GLS plugs have two set screws that hold the speaker wire securely in place. So far the plugs work fine with no issues at all.
http://www.amazon.com/GLS-Audio-Lock...g+banana+plugs
Bill
My SACD collection and HRAudio.net Library, getting larger as my wallet gets smaller ;-).
Emotiva XMC-1, Wyred 4 Sound SX-500s, ST-500, ST-250, Oppo BDP-103/105D, Panasonic TC-P60GT50 plasma, Panamax 5100EX, Salk HT2-TLs, Salk 1801b center, Salk 1801TL (surrounds) and two Rythmik F12SEs.
Bill Mac is online now
post #18 of 19 Old 07-26-2014, 01:34 AM
gene c353's Avatar
Quoted: 153 Post(s)
Liked: 110
I move things around a lot so I use banana plugs on the receiver end but prefer spades like these on the speaker end. Just makes it a little eaiser to disconnect things. I should add that these spade type connectors might not fit all speakers. I've also stuffed banana plugs through the binding post hole and screwed them down on speakers when they become to lose to stay securely in the more normal location. HMM....that alsmost sounds kind a kinky . But it's not .
http://www.ebay.com/itm/Spade-Connec...item232b498cad
Banana plugs will start to losen up after a few installs/removals so I change them out occasionally. The silver ones from Sewell (dual screw) are kind of light-weight compared to the dead-bolt type from GLS/Sewell but they work very well and are quite in-expensive.
I avoid the single screw type.
gene c353 is offline
post #19 of 19 Old 07-26-2014, 04:48 AM
bears t2's Avatar
I use the Sewell Silver Backs with the Sewell 12ga Silver Back wires. They came attached already and have the double screw in them. they fit very snug.
LG 55LW5600 / Roku3 / Logitech 520
Onkyo TX-NR818
Sony BDP-S570 Blu-Ray, Toshiba HD-D3KU HD-DVD
Bowers & Wilkins 683B (mains), HTM61 (center)
Paradigm Titan v3 (Surrounds), Polk F/XiA4 (Rear Surrounds)
HSU VTF-3 MK5 HP
bears t2 is offline
