Cleaning my AV receiver - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-23-2014, 07:00 PM - Thread Starter
Neccros's Avatar
Liked: 0
Sorry if this has been beaten to death on here but I searched unsuccessfully.
I have a Yamaha AV receiver and I have a bit of finger prints/oils on the front aluminum panel around the knobs/buttons.
What can I use to eliminate the oil/prints W/O removing the silk screened lettering on the front??? A clean dry microfiber cloth doesn't seem to do much removing, more spreading it around.
Any suggestions welcome! I tried Crutchfield but all they could give me was suggestions for screen cleaners!!
Neccros is offline
post #2 of 3 Old 07-23-2014, 08:50 PM
Worf's Avatar
Quoted: 534 Post(s)
Liked: 289
Use some soap and water - some liquid soap (dish soap is fine), and a cloth. You don't need a ton of water - moisten the cloth, not dripping wet. Wring it out before you wipe. Not a lot of soap, either.
Then wipe. You shouldn't need too much pressure to clean. The silkscreen lettering requires a bit of force to remove, so as long as you're not trying to rub it out, it should withstand the wipe down just fine.
You just need light pressure - basically just enough to move the cloth around without it slipping away.
Worf is offline
post #3 of 3 Old 07-23-2014, 11:08 PM
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 519
Use a general alcholol based cleaner, telephone sanitiser etc.
fatbottom is offline
