Receiver that allows Audio / Video Switching - AVS Forum | Home Theater Discussions And Reviews
post #1 of 20 Old 07-24-2014, 10:31 AM - Thread Starter
Liked: 0
I have a Denon A200, but from the looks of it (and my lack of research), cannot simply switch the audio source while keeping the video source the same. Is there a receiver, or roundabout way of doing this? Basically, I have my TV and cable connected to my AVR via HDMI, and have my airport express connected via component. I would simply like to switch between audio sources and play music once in a while without switching the video input as well. I can return the A200, and don't mind buying a new receiver as long as its under ~$275. Any help is appreciated.
turk1 is offline
post #2 of 20 Old 07-24-2014, 03:59 PM - Thread Starter
Liked: 0
Anyone?
turk1 is offline
post #3 of 20 Old 07-24-2014, 08:13 PM
dmb12679's Avatar
Quoted: 518 Post(s)
Liked: 230
Originally Posted by turk1 View Post
Anyone?
Not sure on your denon, but on my HK I could go into source set up where it asks for both video and audio input for each source(normal would be say HDMI 1 for audio AND video), keep my video for that source at HDMI 1 and select another HDMI 2,3 etc or analog whatever, for the audio. I haven't tried it but I'm sure it would work on mine.
Marantz SR6010 -- Marantz MM7025 -- Marantz UD5007
Klipsch RF-7ii's - RC-64ii - RB-51ii's - RS-42ii's - R-112sw(x2)
B&K AVR507
Denon DVD2900
Klipsch RF-7ii's
dmb12679 is offline
post #4 of 20 Old 07-24-2014, 08:27 PM
gene c353's Avatar
Quoted: 139 Post(s)
Liked: 99
I don't think you can switch the audio while holding on to the video but you can set the inputs up any which way you want. You could connect the audio from one source (CD player?) and the video from another (SAT box?) to an un-used input (DVR?). Then you could select the DVR input on the receiver and listen to a cd while watching Sports Center (do you really need to listen to those guys?). Just a thought.
gene c353 is offline
post #5 of 20 Old 07-25-2014, 05:53 AM - Thread Starter
Liked: 0
I've tried various configurations of what ya'll have mentioned. For ex. I was hoping I could set my DVD channel to do something of the sort. Where I would have the video input as my cable/satellite and the music source as something else. I called Denon, and was told that unfortunately, what I am trying to do is not possible via HDMI, and can only be done via component cables.
Really thought that something like this would be an extremely common feature / something people would use often.
turk1 is offline
post #6 of 20 Old 07-25-2014, 06:12 AM
gimpy's Avatar
Quoted: 23 Post(s)
As the above poster said, my old hk 350 would do that. I would watch a baseball game (hdmi cable from cable/sat) but would listen to a CD or DVD. But, as I recall (it's been awhile), the audio could not be thru an hdmi cable. It was thru analog. So, the video was using hdmi source/cable, but the audio was using analog wires.
Unfortunately, my hk has just bit the dust after 5 years.:-[
gimpy is offline
post #7 of 20 Old 07-25-2014, 08:28 AM
67jason's Avatar
Quoted: 79 Post(s)
Liked: 802
i do this all the time with my onkyo 809. i routinely watch video source via hdmi from my sat receiver and listed to music via 2 channel analog input. my older denon 1611 can do this as well.
i am not sure if there is any receiver that will allow you to watch one hdmi source and listen to another hdmi source at the same time though.
I don't need snobs to tell me how to think, thank you!
67jason is offline
post #8 of 20 Old 07-25-2014, 10:28 AM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 148
I thought some receivers allow independent switching of audio. Perhaps look at the latest Denon models as I sort of remember they did, but not sure.
"But this one goes up to 11"
MichaelJHuman is offline
post #9 of 20 Old 07-25-2014, 10:59 AM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
Some receivers have that feature for mixing and matching HDMI video and audio sources. But, it's not common.
BIslander is offline
post #10 of 20 Old 07-25-2014, 02:18 PM - Thread Starter
Liked: 0
Looks like the feature i'd like simply isn't available with Denon. Any idea if all Onkyo's have the mentioned feature?
turk1 is offline
post #11 of 20 Old 07-25-2014, 02:53 PM
Gandu's Avatar
Quoted: 59 Post(s)
Liked: 82
Watch TV and listen to music ? The Denon X-2000 does it Click image for larger version
Name:	Denon X2000 pg96.JPG
From the Denon 2013 "E" and "X" series thread
The 'Official' 2013 Denon "E Series" / "X Series" AVR Model Owner's Thread & FAQ
Gandu is offline
post #12 of 20 Old 07-25-2014, 03:20 PM
gimpy's Avatar
Quoted: 23 Post(s)
Try watching the video first, then changing the audio, if you already haven't. See if that does anything. Otherwise,,,??
gimpy is offline
post #13 of 20 Old 07-25-2014, 03:51 PM - Thread Starter
Liked: 0
Originally Posted by Gandu View Post
Watch TV and listen to music ? The Denon X-2000 does it Attachment 180282
Hm, looks like I would have to go airport express -> AVR via cable / network.
And I have tried changing audio source while watching TV and it unfortunately hasn't worked.
turk1 is offline
post #14 of 20 Old 07-25-2014, 05:06 PM
kikkenit2's Avatar
Quoted: 822 Post(s)
Liked: 303
This is backwards. All denon receivers work the same way. Put the receiver on an analog/network/tuner/usb audio input and then press the option button.
Video select will be on the list. Can't change audio from a digital video input. Doesn't look like the A200 has this feature.
kikkenit2 is offline
post #15 of 20 Old 07-25-2014, 08:15 PM
afrogt's Avatar
Quoted: 1057 Post(s)
Liked: 758
Two simple options:
1. Run HDMI directly from Cable Box to TV. Use optical from cable box to receiver for audio. You'll still get Dolby Digital 5.1 thru optical just like you would with HDMI. Then you can switch to whatever input you want on the AVR if you don't want to listen to cable box audio.
2. Run component video from cable box to TV. Then you can switch to any input you want on receiver since the video is going directly from cable box to TV.
Afro GT
afrogt is offline
post #16 of 20 Old 07-27-2014, 08:50 AM - Thread Starter
Liked: 0
Originally Posted by afrogt View Post
Two simple options:
Tried that and unfortunately doesn't work.
turk1 is offline
post #17 of 20 Old 07-29-2014, 09:00 PM
afrogt's Avatar
Liked: 758
How could that not work? Any basic receiver should let you do that because you're running video straight from the cable box to TV.
All you're doing is using the receiver for audio.
I'm not familiar with the A200 but I can do it with my 3 Denon's and two of them the AVR 591 and 1613 are very entry level.
Afro GT
afrogt is offline
post #18 of 20 Old 07-29-2014, 09:31 PM
Gandu's Avatar
Quoted: 59 Post(s)
Liked: 82
Gandu is offline
post #19 of 20 Old 07-30-2014, 01:46 AM
jdsmoothie's Avatar
Quoted: 12182 Post(s)
Liked: 5549
If what you have is actually the E200 (rather than A200), the Video Select feature only works with the "composite" video inputs. Only the E300 and higher models allow selection of an HDMI video source.
jdsmoothie is offline
post #20 of 20 Old 07-30-2014, 06:26 AM - Thread Starter
Liked: 0
Correct - I had the E200. Am planning on buying the X1000, which I am told will allow switching. Many thanks
turk1 is offline
