The "Official" 2014 Denon Atmos+XT32 Model Thread (X4100/X5200/X7200) - Page 18 - AVS Forum | Home Theater Discussions And Reviews
 1507Likes
Old 08-29-2014, 04:11 PM
kbarnes701's Avatar
Quoted: 6740 Post(s)
Liked: 5071
Originally Posted by Kriilin View Post
I guess the million dollar question is will we care about Neo:X after hearing Dolby Surround? I'll be going straight from Dolby 5.1/DTS to Atmos/Dolby Surround, lol!
I don't think I will care much about Neo:X once I have Dolby Surround upmixing to all my overhead speakers. But I don't have Wides and for someone who has gone to the expense and trouble of installing Wides, I'd guess they might want to carry on using them. Personally, I can't see how a couple of Wides will trump 4 ceiling speakers, but that's just me.
Maestro J likes this.
kbarnes701 is offline
Old 08-29-2014, 05:58 PM
chi_guy50's Avatar
Quoted: 1271 Post(s)
Liked: 768
Perhaps not, but as you know my surrounds will necessarily be slightly behind my MLP so the FW's will take on added significance in my circumstance; besides, the wides will only substitute for the TR since the FH will remain in use.
Still, as the saying goes, the proof of the pudding is in the eating. Bring on that Atmos pudding!
chi_guy50 is online now
Old 08-29-2014, 07:54 PM
petetherock's Avatar
Quoted: 1078 Post(s)
Liked: 516
Maybe in a really big listening room, the Wides will help fill in the gaps between the front and sides?
I think in my tiny place, I will skip and save some $$...
petetherock is online now
Old 08-29-2014, 09:25 PM
Kriilin's Avatar
Quoted: 48 Post(s)
Out of curiosity, what size is your HT area? My room is roughly 13'w by 15.5'l by 9.5'h. I am playing with the idea of 7.1.4, but I'm thinking that may be overkill. I'd save $600 (plus two speakers) by going with the 4100W (5.1.4) vs the 5200W.
I see dead pixels.......
Kriilin is offline
Old 08-30-2014, 01:57 AM
nucky's Avatar
Quoted: 106 Post(s)
Liked: 69
Thumbs up
That's me just about ready for Atmos. I will be using 4 Dali phantom kompas 6m in-ceiling Speakers. 5.2.4 just have to pick what amp to go for. Denon 4100 or 5200 bring it on.
W3Rman likes this.
AV Lexicon GX 7,Denon X7200WA, Oppo203, PS4 pro, TV LG C6 OLED, HD projector 106 Jvc X5000 X550, Sub Paradigm signature sub1, Speakers monitor audio platinum PL100 PLC150, Dali phantom ikon in wall & 4 phantom kompas 6m in ceiling speakers,
nucky is offline
Old 08-30-2014, 08:59 AM
toothsavers's Avatar
Quoted: 34 Post(s)
rear surrounds=atmos speakers
I have a 7.1 system in our family room with slanted ceilings conjoined by a center flat ceiling.My rear surrounds are at the rear areas of this slanted ceiling(about 8 ft off the floor).Is it possible to use these rear surrounds (since they are in the slanted ceiling ) as dolby Atmos speakers?.I will use the Dolby Atmos enabled modules on top of my front 2.5 Nht fronts.Technically, I would have reflective sound bouncing off my front slanted ceiling(from my enabled modules) and downward Atmos sound form my rear surrounds.By channeling Dolby Atmos to replace from rear surrounds,what will be the consequences to my surround system?( I can't add any more in ceiling or in wall speakers) Will this create a sound field MESS????.Need your advice and expertise,THX
toothsavers is offline
Old 08-30-2014, 09:44 AM
Selden Ball's Avatar
Quoted: 3093 Post(s)
Liked: 1511
You can mix Dolby Enabled with direct-firing speakers, if that's what you're concerned about.
My understanding is that, as implemented in D&M receivers, Dolby Atmos supports (up to) 4 overhead speakers. The front pair can be any of three types: Front Height, Top Front or Front Dolby Enabled. Similarly, the rear pair can be any of Rear Height, Top Rear or Rear Dolby Enabled. Whether you specify in the receiver whether a pair of direct-firing speakers is Height or Top depends on how close their positions are to the optimal angular placement for that designation. To say it somewhat differently, my understanding is that if their back-to-front position is closer to the seating, then they're Top speakers. If they're farther away, then they should be designated Height speakers.
Does this help?
Here are two relevant screen grabs from the Marantz SR7009 receiver's manual. Sorry, I don't have a 4100 or 5200 manual downloaded. They should be the same, though.
ID:	237210   Click image for larger version
Selden
Selden Ball is offline
Old 08-30-2014, 09:52 AM
Quoted: 34 Post(s)
Thanks for your help.The distance from the rear slanted ceiling speakers is approximately 20 ft. from the front 2.5 NHT speakers. Our sitting area is closer to the rear speakers, about 7 ft. away. Would the fact that we have upward firing and downward firing dolby atoms speakers be a big negative (sound going in two different directions)? Is this situation superior to just having the front dolby enabled modules and keep the rear speakers as rear surrounds instead of dolby atoms downward firing speakers. Your advice please?
Old 08-30-2014, 10:02 AM
Liked: 1511
No. From your seating position, the sounds from both types of speakers will seem to be coming from overhead.
Having four overhead Atmos speakers would be superior to having only two, since that will let Atmos provide front-to-back motion in the overhead sounds. Since your (current) Rear Surround speakers actually are up in the air, I think they'll be more effective when designated as Rear Height, which tells the receiver that they are in fact elevated.
Selden
Old 08-30-2014, 10:33 AM
W3Rman's Avatar
Quoted: 158 Post(s)
Liked: 131
That looks really nice!
I am anxious to hear back from you on the performance of the Atmos and especially DSU tech.
#1 Calibration Disk / Best Support: Ted's LightSpace CMS Calibration Disk
#1 Calibration Software / Best Support: LightSpace CMS - Calibration Comparison
W3Rman is offline
Old 08-30-2014, 01:11 PM - Thread Starter
batpig's Avatar
Quoted: 3577 Post(s)
Liked: 3420
Can you please provide some photos of your room? It would be a lot easier to help if we could visualize the room and layout more accurately.
batpig is offline
Old 08-30-2014, 02:36 PM
jdsmoothie's Avatar
Quoted: 12232 Post(s)
Liked: 5571
Originally Posted by chi_guy50 View Post
Now I'm not saying your analysis is wrong, but if you're right I still don't understand the logic given the AVR's amp-switching abilities (those wonderful clicking relays). Unless this generation has a switching limitation imposed by dint of the addition of Dolby Atmos processing.
I didn't say it was logical. In fact given what we know about the illogical Atmos configuration mode ..... we must simply accept "what is" or at least "what is for now."
chi_guy50 and Stonedcl like this.
jdsmoothie is offline
Old 08-30-2014, 03:05 PM
Quoted: 34 Post(s)
Hi Batpig, thanks for your help. Please review pictures of two fronts and center, two surround rears that are on the sloped ceiling about ten feet above listening area. Please note high surround speakers above bookcase and glass window. We have two sloped ceilings that apex at a flat ceiling with a fan. Is it possible to do two atmos enabled speakers on my two front NHT's and to use my two in-ceiling (circular) speakers at the rear of the back sloped ceiling? So in essence, we would have upward firing atmos in front of the tv and downward firing Atmos in the rear. Would you turn the surround rears into atmos and change my 7.1 to 5.1.4? The distance between the fronts and the rears is about 20 ft. and the listening area which is 7 ft. forward from the rears. Thank you for your expertise.
Old 08-30-2014, 03:16 PM
nucky's Avatar
Quoted: 106 Post(s)
Liked: 69
I think that will be a bit of a problem? But can be done
nucky is offline
Old 08-30-2014, 03:21 PM
joerod's Avatar
Quoted: 612 Post(s)
Liked: 492
So far from our experience that answer is no.
My Sony 5000ES Review PART 2 FINISHED:
http://hstrial-jrodriguez996.homeste...=1462841668379
joerod is offline
Old 08-30-2014, 09:49 PM - Thread Starter
batpig's Avatar
Liked: 3420
Finally had time today to uninstall the X4000 and hook up the new X5200W. Although they look virtually identical and have the same dimensions, I definitely noticed the extra heft of the X5200W lifting it up in comparison. The remotes are virtually identical (the only differences besides slightly different input names are the "InstaPrevue" button being replaced by the "Eco" button and the four "Favorites" buttons being replaced by "Quick Selects") and other than a change from white lettering to gold, the front panels are essentially identical too.
Around the back the extra build quality of the X5200W is more apparent, the gold plated connecters look higher end and the fancier binding posts are much nicer looking and provided a very secure grip on all of my motly assortment of banana plugs from different vendors.
Setup was a breeze of course (I've done this before ) but I appreciate how with each model year the Setup Wizard gets better and better, walking you through setup for speakers, network, inputs, etc. It's pretty foolproof at this point, you don't even have to learn how to assign input through the input menus if you just answer simple questions about what components are hooked up where.
There have been some nice improvements in the on-screen help info for running Audyssey. It warns you to keep mic positioning a good distance (I think 20") away from the back wall, which is a much appreciated addition since many people have their couches against the back wall in a typical living room setup. The inital graphic showing the cluster of 8 mic positions around the couch hews much more closely to the FAQ recommendations and dispels the idea of literally measuring each seat even if it's off axis. And as you move past the first position it specifically tells you to keep each subsequent measurement within 2ft of the first position -- so in addition to the humorously phallic rocket ship graphic, you get good advice about creating a tight cluster of measurements and staying away from room boundaries.
ID:	238185   Click image for larger version
ID:	238201   Click image for larger version
ID:	238209   Click image for larger version
ID:	238217   Click image for larger version
Spizz, aaronwt, SubSolar and 7 others like this.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
Old 08-30-2014, 10:32 PM
willdao's Avatar
Quoted: 24 Post(s)
Liked: 29
Thanks for the play-by-play, Batpig!
willdao is offline
Old 08-30-2014, 10:49 PM - Thread Starter
batpig's Avatar
Liked: 3420
Unfortunately I had only minimal time today to play around with actual listening tests. I mentioned previously that (in the absence of any actual available Atmos modules) I was going to get a little crazy and try sitting a pair of extra speakes on my console, pointed up at the ceiling, and telling the receiver they are Front Dolby enabled speakers. They calibrated fine, but my limited testing confirmed that this is definitely not going to provide the intended effect.
Obvioulsy, I only have Dolby Surround upmixing to experiment with at this point, lacking any real Atmos conent. However, in my limited testing they didn't seem produce any obvious "discrete" sounding overhead effects. Rather, in A/B testing of standard 5.1 vs. 5.1+DSU, it just seemed to produce a vague sense of expanded "tallness" and atmosphere. My test clips were a few scenes from "300" (the best being the one where the Persian armies release a storm of arrows which fall from the sky upon the Spartans) on HD DVD (MultiCH In + DSU), a few scenes from "Gladiator" streamed off of Netflix (5.1 DD plus + DSU), and a bit of 2ch music streamed through Pandora.
I will reserve judgement until I can try more material, and obviously wil not render any firm conclusions until I have actual Atmos modules with which to test. However, I can say that I found the music upmixing to be very pleasant sounding with DSU (with Center Spread ON). I toggled back and forth between DTS Neo:X Music mode (which upmixes to my standard 5.1 speakers) and Dolby Surround (upmixing to 5.1 plus my fake-o upward firing speakers) and the DSU upmix was much more spacious and envelopming thanks to the extra dimension (literally) of the sound. When I would switch back to Neo:X I could feel the "top" of the sound get removed and it collapsed down to the circle of sound around me.
I will be heading out of town for the next few days so won't have much more time for testing. But overall it sounds great, was a snap to set up, and presented no glitches at this point. Once my wife heads to bed I will get to do some testing of late night mode with Dynamic Volume engaged and see if I can get any sense of the DSU height expansion at lower volumes with compressed dynamics.
EDIT for a few more bullet point notes:
- One thing I forgot to mention above about improvements in Audyssey setup are that there is no longer a separate "Calculate" and "Store" step at the end. This is a HUGE improvement in simple workflow because a lot of people screw up at the end and forget to hit "STORE" and then realize too late that they have to re-run the whole thing. Packaging it all into one step when you click "I'm done!" is a small bit of genius that is so subtle most people will never notice. Also while it's calculating it reminds you it's ok to unhook the microphone and also asks if you want to use DEQ / DV.
- One small change is that the "do you want to turn Dynamic Volume on?" question asked at the end of auto setup now defaults to "No". So if you blindly click the OK button through the end of auto setup you will end up with Audyssey Reference target curve, Dynamic EQ on, and Dynamic Volume off.
- A few little thoughts -- remote app connected quickly, web interface was also snappy, and it was easy to log onto Pandora from my iPad since the app allows you to use the iPad keyboard to enter email/password info.
- The Audyssey curve has been renamed as "Reference" and Graphic EQ has been removed from the MultEQ options which was confusing and implied that it allowed you to tweak Audyssey itself. Now the Graphic EQ menu is grayed out unless MultEQ is set to OFF.
Spizz, Kriilin, kbarnes701 and 3 others like this.
Setup Guide and FAQ
batpig is offline
Old 08-30-2014, 10:56 PM
Waboman's Avatar
Quoted: 4607 Post(s)
Liked: 10786
Great pics, bp. Looking forward to your object based thoughts. And keep the pics coming.
Waboman is offline
Old 08-30-2014, 11:03 PM
SubSolar's Avatar
Quoted: 119 Post(s)
Liked: 40
How was the audessey calibration with Atmos?
Samsung 85" 4K, Dolby Atmos 7.1.4 with MartinLogan Theos, Stage, Motion 15, EM-R, Seaton Submersive F2, Denon AVR-X5200W
SubSolar is offline
Old 08-30-2014, 11:28 PM
Skylinestar's Avatar
Quoted: 1061 Post(s)
Liked: 186
@batpig
what is the speaker trim limit? still the same +/-12DB ?
Skylinestar is online now
Old 08-30-2014, 11:30 PM - Thread Starter
batpig's Avatar
Liked: 3420
No different than other calibration. From the perspective of the end user it's just like any other Audyssey run.
Setup Guide and FAQ
batpig is offline
Old 08-30-2014, 11:42 PM - Thread Starter
batpig's Avatar
Liked: 3420
Originally Posted by Skylinestar View Post
@batpig
Yes. Still +/-12db.
But as an FYI there was a complete overhaul of the channel level adjustment concept this year (not just the 5200 but the whole 2014 lineup). For all Denons forever the ch level adjust was per surround mode family; this year the ch level trims are set globally in the speakers menu, and then you can make RELATIVE adjustments BY INPUT, not by surround mode.
The new "relative adjustment" ch level menu is accessed via the Option button and defaults to 0 for all speakers, and then you can tweak any speaker +/-12db more from the global baseline, for that input source.
Setup Guide and FAQ
batpig is offline
sdurani's Avatar
Quoted: 4522 Post(s)
Liked: 2921
How dare you, at a time like this!
Glad you posted some initial thoughts on DSU with 2-channel music. As long as it kept things subtle and didn't create any overhead distractions, it might end up as well liked as the PLII family of modes.
Safe travels.
Sanjay
sdurani is online now
Old 08-31-2014, 12:23 AM - Thread Starter
batpig's Avatar
Liked: 3420
Nice added touch on the on screen Info button graphic, now it shows the MultEQ / Dyn EQ / Dyn Vol audyssey states below the input signal and surround info.
Spizz, esappy and Bigham16 like this.
batpig is offline
Old 08-31-2014, 12:52 AM
Manni01's Avatar
Quoted: 2829 Post(s)
Liked: 2424
Does the EXT in input signal mean Dolby Atmos EXTensions?
Manni01 is offline
Old 08-31-2014, 01:07 AM
esappy's Avatar
Quoted: 158 Post(s)
Liked: 84
I have the same question. Also in the 'active speaker' section what does 'FDL' and 'FDR' stand for? I have a feeling I will have a slap your head moment when you tell me but right now I cant think of what it would stand for. Be gentle.
"One of the penalties for refusing to participate in politics is that you end up being governed by your inferiors." - Plato
esappy is offline
Old 08-31-2014, 01:19 AM
Manni01's Avatar
Liked: 2424
FDL = Front Dolby Left (Front Top Left)
FDR = Front Dolby Right (Front Top Right)
This is because Batpig is using Dolby Surround to make use of his home-made Dolby Speakers extensions, due to the lack of native Atmos content.
Manni01 is offline
Old 08-31-2014, 01:28 AM
esappy's Avatar
Quoted: 158 Post(s)
Liked: 84
Cool, thanks. I did actually mutter that to myself but then I thought it sounded kind of goofy so I convinced myself that couldn't be it. Go figure. I wonder if that would also work for DTS if these receivers can be upgraded with UHD?!?
esappy is offline
Old 08-31-2014, 01:38 AM - Thread Starter
batpig's Avatar
Liked: 3420
Small nitpick but it would say FDL/FDR even with native Atmos content. The key distinction is using "Dolby enabled" upward firing speakers vs physically elevated height speakers.
Setup Guide and FAQ
batpig is offline
(X4100/X5200/X7200) , X4100W , X5200W
