This thread will cover the three 2014 Denon models with Dolby Atmos and Audyssey MultEQ XT32 calibration. Dec 2014 Update: These models now have the option of a PAID upgrade to add the Auro featureset, which includes Auro2D and Auro3D decoding and the "Auro-matic" upmixer.
Please refer discussion of the non-Atmos 2014 S/X-Series models (i.e. AVR-X3100 and below) to the Official 2014 S/X Owner's Thread.
Official Press Release Announcement of AVR-X4100 and AVR-X5200
Denon AVR-X7200W EU/UK Product Sheet
Can someone explain this Dolby Atmos thing to me??
The three Dolby white papers linked below are essential reading for anyone who wants to understand this paradigm shift in home-theater audio, which literally takes movie sound into the third dimension. Everything you need to know is covered well in these three documents.
Dolby Atmos for the Home Theater
Dolby Atmos-Enabled Speaker Technology
Dolby Atmos Home Theater Installation Guide White Paper
Denon AVR-X4100W ($1,399 msrp)
The new AVR-X4100W is basically an X4000 with Atmos, HDMI 2.0, Bluetooth, WiFi, and an extra HDMI input. There are some other minor changes (noted below) but these are the key differences most will care about. In order to support the variety of potential speaker options, the pre-out count has been upped to 13.2 outputs (from 11.2 on the X4000), although note that a maximum of 9 channels can be active at a time regardless of how many external amps you add. The additional pre-outs are for flexibility if you want to have the option of switching between various speaker configurations (e.g. 7.1 + Wides for DTS Neo:X, and 7.1 + In-ceiling speakers for Dolby Atmos).
Denon AVR-X5200W ($1,999 msrp)
The X5200W is basically a Japan-made, souped up X4100W. It adds two more internal amps (9 total) rated at 140W/ch into 8 ohms (up from 125W/ch of the X4100), two more channels of processing capability (can run 11 simultaneously instead of 9 max), and fancier gold plated speaker connectors. Like the X4100W, the X5200W has a full set of 13.2 channel pre-outs, but since it can run 11 channels simultaneously, you can switch on the fly (example) from 11ch Neo:X and 7.1.4 Atmos, provided you have sufficient channels of external amplification to supplement the 9 internal amps. The X5200W also borrows from the higher end 4520CI (and its replacement X7200W) by incoporating a beefier "monolithic discrete amplifier" design with upgraded "Denon High Current Transistors" (DHCT), so it can be assumed it will be much more capabable of handling difficult speaker loads than the lower level models.
Denon AVR-X7200W ($TBD msrp)
The X7200W is the new "flagship" and true successor to the 4520CI, as opposed to the X5200 which is probably more of a logical successor to the older 3808CI level. The X7200W steps up the build quality with a physically larger chassis (a bit over 1 inch deeper and taller), is 8 lbs heavier than the X5200 (39lbs vs 31lbs), and upgrades to full 32-bit processing architecture (32-bit DAC's, D.D.S.C - HD32 processing, AL32 instead of AL24, etc). The "discrete monolithic" amplifier design of the 5200 by is upgraded by separating it into two left/right banks of discrete monolithic amplifier channels for better isolation. It also provides 7.1 EXT IN analog inputs, an extra component video input and a second component video output (output scan be configured for Main Zone or other zones). The X7200W, like its 4520CI and 4810CI predecessors, offers more flexibility with custom Amp Assign options (as opposed to the fixed templates on the lower models). And, unlike the lower level models, the X7200W will have the option of a paid hardware upgrade to the new HDCP2.2 chipset sometime in 2015.
What's else is new this year?
Leaving aside Atmos for a moment, the general differences between last year's models and are discussed more thoroughly in the first few posts of the Official 2014 S/X Owner's Thread.. The biggest (non Atmos) differences that most will care about vs. the outgoing X4000 and 4520CI:
* Upgrade to HDMI 2.0 with 3D, 4:4:4 and 4K/60fps pass through support (note that the HDMI ports are NOT certified for HDCP 2.2 however!)
* ISF Certification (allows different Day/Night video calibration settings per input)
* Bluetooth built in for wireless streaming
* Networking and WiFi built in, with support for DSD and hi-rez (192kHZ) FLAC and WAV files via network stream or USB
* Built-in Spotify interface replaced by "Spotify Connect" for all networked models (i.e. you can only control it from a separate device, not from the receiver directly)
* A new "TV Audio On/Off" setting to defeat the annoying auto switching caused by an HDMI-CEC ARC connection
* Heavily revamped smartphone/tablet remote apps coming in the fall with expanded functionality
* Return of Quick Select buttons on the remote (as opposed to just on the front panel)
* Return of the "Channel Level" on screen menu for on the fly adjustments to all channels (note that for the first time this setting is per input not per surround mode)
* Expanded "Option" menu for on-the-fly audio/video adjustments (the "Setup" menus will now be reserved for more global adjustments)
* HDMI and SPDIF digital audio to Zone 2, and SPDIF (no HDMI) digital audio to Zone 3 (the X4000 already had this but the 4520CI didn't).
Some cool new usability enhancements!
Improved Audyssey calibration inferface: The interface is slicker and easier to use, with better visual feedback. There are also some useful changes to the instructions provided, for example the system warns you to not measure close to the back wall, and after the 1st position it informs you to keep the other measurements within 2 feet of the 1st measurement, ensuring a tight "bubble" of measurements that will yield superior results. Also, there is no longer the confusing separation between the "Calculate" and "Store" steps (with many people forgetting to "Store"!). Now, when you complete Audyssey calibration, it proceeds through the calculation and saving of the filters as one step, with a nice progress bar showing what's happening. In addition, while it's calculating/saving, it lets you know you can unplug the mic, and then asks you if you want to turn on Dynamic EQ (default = yes) and Dynamic Volume (default = no) instead of making you wait until the end. Subtle stuff, but a really nice step forward!
Improved All Zone Stereo implementation: The popular "All Zone Stereo" feature which allows you to synchronize any audio source (including HDMI) across all zones continues, but there are a couple of cool enhancements. First, unlike the previous models, it is no longer a requirement to manually turn on the other zones first before engaging All Zone Stereo. When you start All Zone Stereo, the other zones turn on automatically. Second, it is no longer necessary to use ALL the zones. When you open the "Option" menu to access All Zone Stereo option, each of the other zones listed (Zone 2 and Zone 3) has a little checkbox next to. You can check/uncheck which zones you want to "participate" in the All Zone Stereo output, and then when you engage the modes only those zones checked will turn on and start playing.
A new Channel Level adjustment paradigm: Also accessible from the "Option" menu is a new Channel Level adjustment screen. Previous Denons have had on-the-fly Ch Level adjustment menus, but Denon has changed the way they work with the new 2014 lineup. There are two key changes for this year. First, the adjustment is RELATIVE to the baseline established in the Speaker setup menus. In other words, the "default" setting in this menu is always 0dB, and any changes will be plus or minus from the baseline level set in the Speaker menu. Second, the adjustment is stored PER INPUT. So, for example, you can set your Blu-ray input to be +3dB on the subwoofers and +2dB on the center channels, and it will only affect that input and make those adjustments relative to the balanced levels set during auto setup. If you want to make a GLOBAL change to a speaker channel level, you need to go into the GUI and access the Ch Level test tones via Speakers > Manual Setup > Levels.
