Emotiva XMC-1 Owners Only Thread - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 2081Likes
post #31 of 6229 Old 07-30-2014, 05:01 AM
bootman_head_fi's Avatar
Quoted: 535 Post(s)
Liked: 342
Originally Posted by lbrown105 View Post
this is great news and responsiveness on Emo's part. Does any know what the max delay is in either feet or ms?
I read it would be in feet (and in meters).
Can an owner confirm?
bootman_head_fi is offline
post #32 of 6229 Old 07-30-2014, 09:36 AM - Thread Starter
bborzell's Avatar
Quoted: 26 Post(s)
Liked: 58
Looks kinda limited. I could only get it to 327 feet or 99.7 meters.
2nd round OPPO BDP-83 EAP Selectee
bborzell is offline
post #33 of 6229 Old 07-30-2014, 09:37 AM
sticknstones's Avatar
Quoted: 13 Post(s)
Liked: 36
XMC-1 Owner too
Hi everyone,
I had the UMC-1 and UMC-200 and have just taken receipt of the XMC-1. The UMC-1 was a little problematic for me but the UMC-200 and now the XMC-1 are working like a champ.
I like the changes in the GUI which are more like the UMC-1 where inputs are assignable. I did re-cable everything to XLR but the main reason is I like the connection style better than the RCA. I have my unit bi-wired to my 802's with my XPA-2's and the ERC using the Balanced In. The trigger functionality is very comprehensive and I like when I plug in my headphones that it does an auto-standby on the amps and turns them on when I pull the headphone out. I have to listen to low volume music on weekends and really appreciate the Fletcher-Munson volume compensation.
I chose to receive the XMC-1 before Dirac as I had a lot of other things I could do with the processor. I have set my distances manually but will wait patiently for the Dirac for the room correction and do not envision myself getting immersed in the REW or OmniMic ( I have a Sailboat and Golf clubs that demand some attention too).
I have the worst room in the world and so I know my system needs tweaking once Dirac hits my rack. The biggest game changer that I see from us enthusiasts is that now we can focus on feature function talk and start to leverage some applied learning with each other. I am glad you all started this thread.
SticknStones
"I was not born a wise man but I am learning the trade" roo
B&W 802's, Emotiva - XMC-1, (2) XPA-2's bi-wired, XPA-3, ERC-1, XDA-2, (2) Ultra-12 subs, & DSPeaker - antimode 8033c
sticknstones is offline
post #34 of 6229 Old 07-30-2014, 10:21 AM
RUR
Innocent Bystander
RUR's Avatar
Quoted: 392 Post(s)
Liked: 277
I suspect this will be increasingly true once you guys have Dirac up and running. Learning how to do proper setup and target curve tweaking will require time and proper group support.
Something to look forward to.
bootman_head_fi and Bluescale like this.
RUR is offline
post #35 of 6229 Old 07-30-2014, 11:04 AM - Thread Starter
bborzell's Avatar
Quoted: 26 Post(s)
Liked: 58
Yep... I have to admit to having been seduced into the set it up and leave the serious tweaks until later.
One of the design standouts is the seriously vast range of customization that exists within the box while allowing an almost plug and play option to get things up and running.
I did set speaker levels with an SPL meter and distances with a tape measure, but given the options on trigger setting, I just plugged a cable from Trigger #1 output and hooked it to the top mono amp which then goes on to the next and so on. Have not laid out specific speakers for stereo vs. movies in the XMC-1, for example, as I have manual switch up by the fronts because I use different fronts for stereo anyhow. Now that I think about it, it might be good to shut down the center, sides and back amps for stereo listening, so maybe I'll read up on setting the triggers, after all.
bborzell is offline
post #36 of 6229 Old 07-30-2014, 11:54 AM
Quoted: 535 Post(s)
Liked: 342
...and you can do this per input?
If so, nice.
post #37 of 6229 Old 07-30-2014, 12:29 PM - Thread Starter
bborzell's Avatar
Quoted: 26 Post(s)
Liked: 58
If so, nice.
Don't know yet. To find put would drag me further away from my set it and forget it status.
bborzell is offline
post #38 of 6229 Old 07-30-2014, 12:54 PM
Roger Dressler's Avatar
Quoted: 1576 Post(s)
Liked: 761
I hope the update also fixes the pink noise for channel level calibrations. (Needs to be bandlimited for that, not wideband which is for EQ.)
Bluescale likes this.
Deadwood Atmos theater [HTOM]
AV7702 Atmos 7.4.4, SSP-800 PLIIx 7.4
Aerial Acoustics 7B/CC3B fronts, B&W CWM8180 surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
Roger Dressler is online now
post #39 of 6229 Old 07-30-2014, 01:39 PM
Quoted: 13 Post(s)
Liked: 36
If so, nice.
Yes, the triggers have 4 categories; main, input, speakers, headphones. I am using Main and Inputs where my ERC only powers up when I choose that input and you can do the same on the amps based on speakers. It is very comprehensive.
bborzell likes this.
SticknStones
post #40 of 6229 Old 07-30-2014, 01:59 PM
DreamWarrior's Avatar
Quoted: 418 Post(s)
Liked: 295
Do the EQ/level/distance changes happen on-the-fly or do you have to apply them first? In other words, can I measure and tweak real-time or do I have to bump things around a tiny bit, apply, measure, rinse, wash, repeat?
DreamWarrior is offline
post #41 of 6229 Old 07-30-2014, 03:19 PM - Thread Starter
bborzell's Avatar
Quoted: 26 Post(s)
Liked: 58
Are you asking whether you have to close the menu in order to apply/hear your distance changes?
I know that level changes with the white noise tone occur on the fly, but I am not sure how to confirm whether changes occur with distance/delay on the fly. Seems like you would need to have more than one speaker active in order to detect relative delay changes.
bborzell is offline
post #42 of 6229 Old 07-30-2014, 03:30 PM - Thread Starter
bborzell's Avatar
Quoted: 26 Post(s)
Liked: 58
I thought it had that flexibility. What I have not experimented with is whether the speakers are "engaged" through an internal individual channel switch in the XMC-1 or by turning respective amps (I have three monos in front) on and off in keeping with each inputs speaker assignment (all three fronts, sides, rear and subs on for movies and only left/right front for stereo CDs).
My current trigger setting has the processor telling the 1st mono amp to turn on and #1 relays that command to #2 amp and so on.
bborzell is offline
post #43 of 6229 Old 07-30-2014, 04:00 PM
Quoted: 535 Post(s)
Liked: 342
Was that mentioned the the feature request thread there?
post #44 of 6229 Old 07-30-2014, 04:10 PM
Liked: 761
Lonnie acknowledged reading my post on July 24.
post #45 of 6229 Old 07-30-2014, 05:44 PM
Brian-HD's Avatar
Quoted: 46 Post(s)
Liked: 42
Can you calibrate correctly using wideband with SPL meter?
Brian-HD is offline
post #46 of 6229 Old 07-30-2014, 06:03 PM
Liked: 761
The use of a wideband meter is assumed. The idea of the narrow-band noise is to focus the calibration to the most important and most reliable part of the spectrum, thereby preventing the SPL meter from being affected by bass errors, for example. This is why THX and Dolby have required AV processors to have filtered noise since Pro Logic days in late 1980s. Nothing new. Once the XMC-1 gets certified by Dolby, it will presumably have that capability.
post #47 of 6229 Old 07-30-2014, 06:09 PM
Brian-HD's Avatar
Quoted: 46 Post(s)
Liked: 42
What's the process for this?
Brian-HD is offline
post #48 of 6229 Old 07-30-2014, 06:21 PM
Liked: 761
Well, up until I departed Dolby in 2008, manufacturers would submit new models to Dolby for testing. There are ways to self-test but the data still has to be confirmed.
post #49 of 6229 Old 07-30-2014, 06:52 PM
Bluescale's Avatar
Quoted: 729 Post(s)
Liked: 296
I just realized that your excellent post on this topic is in the beta tester thread, not the feature request thread. I'll make sure to document it there as well.
Bluescale is offline
post #50 of 6229 Old 07-30-2014, 08:04 PM
Quoted: 418 Post(s)
Liked: 295
Pretty much -- for example, on my Denon 4311ci, some changes occur immediately, levels for example. I enter the channel level menu, bump the level up, and the measurement immediately shows the difference. On the other hand, crossover frequency doesn't work that way. If I decide I want to move my mains crossover, I first have to select the new crossover value then press return for it to activate the new setting. Worse, after pressing return the sound drops out for a brief moment before the new x-over setting takes effect. So, if I'm trying to decide (while listening) which setting I like best, it's hard due to the dropout. And when I'm measuring, it's inconvenient.
Now, if PEQ settings on the Emotiva worked like the crossover on my Denon, I'd be really annoyed. I'd expect that as I tweak the PEQ I can tweak and hear it on-the-fly, like the levels controls.
I suppose the PEQ is the most important, but I would like all settings to occur on-the-fly because it's easier to a-b different values while listening and more convenient for measuring.
post #51 of 6229 Old 07-30-2014, 08:13 PM
matty1137's Avatar
Quoted: 48 Post(s)
The XMC-1 is not certified by Dolby yet? Could this be the reason there aren't any Dolby (or DTS) logos on the faceplate?
matty1137 is offline
post #52 of 6229 Old 07-30-2014, 08:15 PM
Bluescale's Avatar
Quoted: 729 Post(s)
Liked: 296
Do you adjust the PEQ by ear? I'm pretty new to PEQs, as I've just started using the one in JRiver, but I can't imagine using it without measuring a sweep first. Of course, that might be my lack of experience.
Levels, on the other hand, should absolutely be adjustable on the fly. As you play your test tone, you should be able to see the change register on the SPL meter when you adjust the level. I can understand why crossover wouldn't work that way.
post #53 of 6229 Old 07-30-2014, 08:24 PM
lbrown105's Avatar
Quoted: 522 Post(s)
Liked: 324
ok, well that should do the trick.
thx
lbrown105 is offline
post #54 of 6229 Old 07-30-2014, 08:28 PM
Quoted: 418 Post(s)
Liked: 295
I'd probably do a little of both -- measure, tweak, listen, tweak. Heck, I may even feel inclined to tweak a little for certain tracks or musical styles. Say I wanted a little more punch in a track -- I may fiddle around with a PEQ centered from 60 to 70hz. I'd want to slide the center, Q, and level dynamically while listening to the track to see what feels and sounds best....
Maybe that's just me.....
post #55 of 6229 Old 07-30-2014, 08:39 PM
chalugadp's Avatar
Quoted: 1672 Post(s)
Liked: 1523
Peq is on the fly and instant. There is multiple settings so you can have manual 1 as flat,manual 2 with house curve, and manual 3 with fletcher curve.
On my umc200 I use 6 songs I have heard hundreds of times. They cover the whole musical spectrum. I tweak by ear, measure and then fine tune by ear again.
chalugadp is offline
post #56 of 6229 Old 07-30-2014, 11:34 PM
Liked: 761
I am not saying it is certified or not. Licensees are given time to address what is found, especially when it is a simple firmware matter, as it can come along with other updates.
post #57 of 6229 Old 07-31-2014, 01:10 AM
markus767's Avatar
Quoted: 3987 Post(s)
Liked: 1405
Is it white noise or pink noise?
HTNUT1975 likes this.
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is offline
post #58 of 6229 Old 07-31-2014, 01:30 AM
markus767's Avatar
Liked: 1405
Isn't the idea to have independent delay and level, but summed EQ?
Both.
Best results are achievable with independent level, delay and PEQ. This is what Welti's SFM does. Unfortunately we don't have access to the software and there's no manual process to get this right. So having independent level, delay and PEQ is kind of moot.
A more practical approach is to play around with subwoofer location, delay und level and try to achieve 1) low seat-to-seat variance and 2) minimize non-minimum phase effects at the same time. The latter is often forgotten when people make recommendations about multiple subwoofer setups. It's as crucial as 1)
After that step all subs are equalized as one.
Both approaches require measurements of course.
Markus
post #59 of 6229 Old 07-31-2014, 02:18 AM
matty1137's Avatar
Quoted: 48 Post(s)
Okay, I see. Thanks, Roger.
post #60 of 6229 Old 07-31-2014, 02:24 AM
KurianOfBorg's Avatar
Quoted: 141 Post(s)
Liked: 27
1) Does Dirac Live work for the 7.1 analog input?
2) Does the Dirac Live corrected 7.1 analog input get digitised and output via HDMI?
3) What if I don't have any HDMI video input but only 7.1 analog input? Will the Dirac Live corrected audio still be digitised and output via HDMI to my receiver?
4) Does the HDMI input get converted to analog and the Dirac Live corrected audio output via 7.1 analog to my analog receiver?
5) Why is it unable to perform Dirac Live room correction on DSD? How is this different from performing room correction on Dolby or DTS streams? Either way it has to decode to PCM internally.
I am highly skeptical of any device's ability to perform 3 & 4.
I want to use this to connect my PC to the receiver while using my Sound Blaster Zx since I want hardware OpenAL and the sound card's headphone amp and beam forming microphone. Therefore I cannot use HDMI or USB.
TKNice likes this.
KurianOfBorg is offline
