Help me buy a Amp - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-25-2014, 11:58 AM - Thread Starter
Liked: 0
Help me buy a Amp
I currently have MTX TP1200 and I am wanting to know which amplifier I should purchase price is not a factor and maybe one day we'll upgrade to even better speakers. Thanks I just wanna know your thoughts on this.
Frequency Response: 39Hz-20kHz
Power: 150W RMS/ 300W Peak
Impedance: 8Ohms
Sensitivity: 91:4dB
tdmarchetta is offline
post #2 of 4 Old 07-25-2014, 12:26 PM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 151
You want an amplifier or a receiver? Not clear from your details and people don't use the terms consistently
If all you need is a power amp, as it's a pro type speaker, I would get a pro type power amp such as the Crown XLS series.
You might want to clarify if you need something to hook audio, video or both to before the amplification step
"But this one goes up to 11"
MichaelJHuman is offline
post #3 of 4 Old 07-25-2014, 12:31 PM
twitch54's Avatar
your question is way to vague, please elaborate…………..you can spend $500 or since you said $$ are not and issue you could buy a pair of Pass Class A mono blocks for $25,000 and call it a day !
twitch54 is offline
post #4 of 4 Old 07-25-2014, 03:32 PM
SmithandWesson's Avatar
Quoted: 20 Post(s)
Liked: 41
Why do you want to purchase another amp? That's the most important question. Second most important is how loud do you listen to your material.
Main System: SVS Ultra Towers - 15" custom ported subwoofer - SVS PB-1000 - Yamaha RX-A740 Aventage. 122dB @ 16Hz!!!
Computer System: Carnagie Acoustics CSB-1 - 12' Onkyo sealed subwoofer - Pioneer VSX-92 THX
Other speakers owned or auditioned: Aperion T6 - Ascend CBM-170 - Energy RC-10 - Wharfdale 10.1 - Arx A1b
SmithandWesson is offline
