5.1 surround sound audio through splitter? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-25-2014, 08:36 PM - Thread Starter
Liked: 0
Hi guys,
So I have these Turtle beach 7.1 surround sound headphones that uses an optical cable to connect. I wanted to use these with my laptop. So doing some research, I bought myself an HDMI splitter. I connect my laptop to this splitter via hdmi. The splitter splits the input into an hdmi stream, and a toslink stream for audio. I connect the hdmi link to my Tv and the toslink optical to my turtle beach:
Laptop ---(hdmi)----> Splitter -----(hdmi)-----> TV
Splitter-------(spdif) -----> 7.1 surround sound stream headphones
However, my problem is that the headphones only output stereo, and looking at my playback devices menu, I get no options for any kind of surround sound stream. The only options are the original laptop speakers and the TV stereo. It would appear that since my TV only has a 2 channel stream for audio, 7.1 is disabled.
Any Ideas on how I can go about getting surround sound with this setup?
Yaqzan Ali is offline
post #2 of 4 Old 07-26-2014, 01:28 AM
Roger Dressler's Avatar
Quoted: 1522 Post(s)
Liked: 710
The disc does not show the separate 5.1 stream used for S/PDIF, it is embedded with the lossless audio. A BD player automatically plays that to the S/PDIF (in bitstream mode). In this case, the PC has no idea of S/PDIF.
The TV may be telling the PC it cannot understand DTS (which is normal), so the PC outputs stereo PCM on the HDMI, and the same goes to the S/PDIF. If you disconnect the TV, and restart the PC and splitter, does the sound from the S/PDIF become 5.1?
If yes, then the challenge is to figure out a way to fool the PC into doing the same even when the TV is connected. If not, you'd need a smarter splitter that can extract the lossy 5.1 bitstream.
Whether yes or no, might just be easier/cheaper to use a normal BD player. It will work perfectly with no splitter.
Deadwood Atmos theater [HTOM]
AV7702 Atmos 7.4.4, SSP-800 PLIIx 7.4
Aerial Acoustics 7B/CC3B fronts, B&W CWM8180 surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
Roger Dressler is offline
post #3 of 4 Old 07-26-2014, 02:33 AM - Thread Starter
Liked: 0
By BD player, do you mean bluray player? I'd be happy to invest in some if it meant surround sound for my laptop.
Anyways, I unplugged my TV and got a new playback device showing up in the menu, but still with stereo audio nonetheless.
With TV:
Without TV:
post #4 of 4 Old 07-26-2014, 10:35 AM
Liked: 710
Yes, a stand-alone Blu-ray player. It would be used to drive the TV and headphone system at same time, with no need for the laptop.
If you feel compelled to explore PC options, you may need a new nVidia graphics driver as this fellow found. But even then, that might only make things work without the TV connected for the reason given above.
